SDK: nRF Connect SDK Toolchain v2.9.0-nRF54H20-rc1 + DK board(0.9.1)
call bt_id_create error.
/* STEP 4.2 - Change the random static address */
bt_addr_le_t addr;
err = bt_addr_le_from_str("AA:BB:CC:DD:BB:AA", "public", &addr);
if (err) {
printk("Invalid BT address (err %d)\n", err);
printk("AA:BB:CC:DD:BB:AA 1\n");
err = bt_id_create(&addr, NULL);
if (err < 0) {
printk("Creating new ID failed (err %d)\n", err);
err = bt_enable(NULL);
if (err) {
printk("Bluetooth init failed (err %d)\n", err);
return 0;
printk("Bluetooth initialized\n"); log:
[2025-01-26 15:42:13.604]# RECV ASCII>
*** Booting My Application v2.8.99-24e6f3802b37 ***
*** Using nRF Connect SDK v2.9.0-nRF54H20-rc1-4df6ce63408b ***
*** Using Zephyr OS v3.7.99-f5efb381b8af ***
Starting Bluetooth Peripheral LBS example
AA:BB:CC:DD:BB:AA 1
E: Only random static identity address supported
Creating new ID failed (err -22)
I: 8 Sectors of 4096 bytes
I: alloc wra: 0, f90
I: data wra: 0, 10
[2025-01-26 15:42:13.727]# RECV ASCII>
I: HW Platform: Nordic Semiconductor (0x0002)
I: HW Variant: nRF54Hx (0x0004)
I: Firmware: Standard Bluetooth controller (0x00) Version 94.16521 Build 3607747417
I: No ID address. App must call settings_load()
I: Identity: F0:02:69:E2:FA:AD (random)
I: HCI: version 6.0 (0x0e) revision 0x4063, manufacturer 0x0059
I: LMP: version 6.0 (0x0e) subver 0x4063
Advertising successfully started
AA:BB:CC:DD:BB:AA 1
I: data wra: 0, 10
int blink_status = 0;
int err;
printk("Starting Bluetooth Peripheral LBS example\n");
// err = dk_leds_init();
// if (err) {
// printk("LEDs init failed (err %d)\n", err);
// return 0;
// err = init_button();
// if (err) {
// printk("Button init failed (err %d)\n", err);
// return 0;
if (IS_ENABLED(CONFIG_BT_LBS_SECURITY_ENABLED)) {
err = bt_conn_auth_cb_register(&conn_auth_callbacks);
if (err) {
printk("Failed to register authorization callbacks.\n");
return 0;
err = bt_conn_auth_info_cb_register(&conn_auth_info_callbacks);
if (err) {
printk("Failed to register authorization info callbacks.\n");
return 0;
bt_addr_le_t addr;
err = bt_addr_le_from_str("AA:BB:CC:DD:BB:AA", "random", &addr);
if (err) {
printk("AA:BB:CC:DD:BB:AA test2\n");
if (err < 0) {
// bt_addr_le_t addr={.type=BT_ADDR_LE_PUBLIC
// ,.a.val[0]=1,.a.val[1]=2,.a.val[2]=3,.a.val[3]=4,.a.val[4]=5,.a.val[5]=6,
// bt_addr_le_create_static(&addr);
if (err) {
return 0;
if (IS_ENABLED(CONFIG_SETTINGS)) {
settings_load();
// err = bt_lbs_init(&lbs_callbacs);
// if (err) {
// printk("Failed to init LBS (err:%d)\n", err);
// return 0;
err = bt_le_adv_start(adv_param, ad, ARRAY_SIZE(ad),
NULL, 0);
if (err) {
printk("Advertising failed to start (err %d)\n", err);
return 0;
printk("Advertising successfully started\n");
for (;;) {
my_lbs_send_sensor_notify();
//dk_set_led(RUN_STATUS_LED, (++blink_status) % 2);
k_sleep(K_MSEC(RUN_LED_BLINK_INTERVAL));
log:
[*** Booting My Application v2.8.99-24e6f3802b37 ***
I: alloc wra: 0, fc0
I: data wra: 0, 0
[2025-01-26 16:35:57.019]# RECV ASCII>
I: data wra: 0, 0
