Hello Nordic Team,
My application is cellular asset tracker type and we have design custom pcb using nRF9160 device.
I am using ncs SDK version: v2.8.0 and toolchain version: v2.8.0 and I have flased latest modem firmware nrf9160dk_mfw-1.3.7_sdk-2.8.0 in my PCB.
Now, I am try to flash default example code like asset_tracker_v2,at_monitor,gnss according to my use cases.
I have manage proper build configuration and also added my custom cellular_telemetric_devise.overlay file for change default Uart0 pin to my custom pcb. I have attached file for your reference.
But I can't see log over Uart to TTL. I have also try using RTT enable and try to view NRF log in RTT viewer but not showing any log. I have try same build and .overlay file in nRF9160 dk Kit in that all things working properly it's redirect log default Uart0 to my custom defined Uart1 pin and i can see log and also RTT log on RTT viwer.
Below are main changes made in different example code in default prj.conf file for RTT Log and Uart Log. I have attached asset_tracker_v2 prj.conf file for your reference
### Logger module
CONFIG_USE_SEGGER_RTT=y
CONFIG_RTT_CONSOLE=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG=y
CONFIG_LOG_MODE_DEFERRED=y
CONFIG_LOG_BACKEND_UART=n
CONFIG_LOG_SPEED=y
CONFIG_UART_CONSOLE=n
Meanwhile after flashing I showed Uart log which i share below,
In GNSS example :
All pins have been configured as non-secure
[1;34mBooting TF-M v2.1.1-ncs1[0m
[1;34m[Sec Thread] Secure image initializing![0m
TF-M Float ABI: Hard
Lazy stacking enabled
In at_monitor:
Kindely help me to enable both Uart log and RTT log in my custom PCB. Is there any additional macro add into prj.conf file? or any other changes.
It will really help me to move forward my task.
