I've had trouble getting the MCUboot to compile for our application which runs on the nRF7002DK board, and I have similar trouble with the Lesson 8 examples on the nRF7002DK board. They worked fine on an nRF52833 board (except for the lack of a serial Flash). I am using NCS v2.6.1.
Why can't I even get your solutions to compile for this board?
Here is the output when I build the exercise 2 solution from Nordic for an nrf7002dk_nrf5340_cpuapp target:
* Executing task: nRF Connect: Build [pristine]: inter_less8_exer2_solution/build (active) Building inter_less8_exer2_solution west build --build-dir /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution --pristine --board nrf7002dk_nrf5340_cpuapp -- -DNCS_TOOLCHAIN_VERSION=NONE -DBOARD_ROOT=/Users/Glen/Projects/nordic/my_boards;/Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution -- west build: generating a build system Loading Zephyr default modules (Zephyr base). -- Application: /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution -- CMake version: 3.21.0 -- Found Python3: /opt/nordic/ncs/toolchains/580e4ef81c/opt/[email protected]/bin/python3.9 (found suitable version "3.9.6", minimum required is "3.8") found components: Interpreter -- Cache files will be written to: /Users/Glen/Library/Caches/zephyr -- Zephyr version: 3.5.99 (/opt/nordic/ncs/v2.6.1/zephyr) -- Found west (found suitable version "1.2.0", minimum required is "0.14.0") -- Board: nrf7002dk_nrf5340_cpuapp -- Found host-tools: zephyr 0.16.5 (/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk) -- Found toolchain: zephyr 0.16.5 (/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk) -- Found Dtc: /opt/nordic/ncs/toolchains/580e4ef81c/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6") -- Found BOARD.dts: /opt/nordic/ncs/v2.6.1/nrf/boards/arm/nrf7002dk_nrf5340/nrf7002dk_nrf5340_cpuapp.dts -- Found devicetree overlay: /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/app.overlay -- Generated zephyr.dts: /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build/zephyr/zephyr.dts -- Generated devicetree_generated.h: /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build/zephyr/include/generated/devicetree_generated.h -- Including generated dts.cmake file: /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build/zephyr/dts.cmake Parsing /opt/nordic/ncs/v2.6.1/zephyr/Kconfig Loaded configuration '/opt/nordic/ncs/v2.6.1/nrf/boards/arm/nrf7002dk_nrf5340/nrf7002dk_nrf5340_cpuapp_defconfig' Merged configuration '/Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/prj.conf' Configuration saved to '/Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build/zephyr/.config' Kconfig header saved to '/Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build/zephyr/include/generated/autoconf.h' -- Found GnuLd: /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd (found version "2.38") -- The C compiler identification is GNU 12.2.0 -- The CXX compiler identification is GNU 12.2.0 -- The ASM compiler identification is GNU -- Found assembler: /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc CMake Warning at /opt/nordic/ncs/v2.6.1/zephyr/subsys/usb/device/CMakeLists.txt:22 (message): CONFIG_USB_DEVICE_VID has default value 0x2FE3. This value is only for testing and MUST be configured for USB products. CMake Warning at /opt/nordic/ncs/v2.6.1/zephyr/subsys/usb/device/CMakeLists.txt:28 (message): CONFIG_USB_DEVICE_PID has default value 0x100. This value is only for testing and MUST be configured for USB products. -- Found Python3: /opt/nordic/ncs/toolchains/580e4ef81c/opt/[email protected]/bin/python3.9 (found version "3.9.6") found components: Interpreter === child image mcuboot - begin === loading initial cache file /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build/mcuboot/child_image_preload.cmake Loading Zephyr default modules (Zephyr base). -- Application: /opt/nordic/ncs/v2.6.1/bootloader/mcuboot/boot/zephyr -- CMake version: 3.21.0 -- Found Python3: /opt/nordic/ncs/toolchains/580e4ef81c/opt/[email protected]/bin/python3.9 (found suitable version "3.9.6", minimum required is "3.8") found components: Interpreter -- Cache files will be written to: /Users/Glen/Library/Caches/zephyr -- Zephyr version: 3.5.99 (/opt/nordic/ncs/v2.6.1/zephyr) -- Found west (found suitable version "1.2.0", minimum required is "0.14.0") -- Board: nrf7002dk_nrf5340_cpuapp -- Found host-tools: zephyr 0.16.5 (/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk) -- Found toolchain: zephyr 0.16.5 (/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk) -- Found Dtc: /opt/nordic/ncs/toolchains/580e4ef81c/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6") -- Found BOARD.dts: /opt/nordic/ncs/v2.6.1/nrf/boards/arm/nrf7002dk_nrf5340/nrf7002dk_nrf5340_cpuapp.dts -- Found devicetree overlay: /opt/nordic/ncs/v2.6.1/nrf/modules/mcuboot/flash_sim.overlay -- Found devicetree overlay: /opt/nordic/ncs/v2.6.1/nrf/modules/mcuboot/usb.overlay -- Found devicetree overlay: /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/child_image/mcuboot/boards/nrf7002dk_nrf5340_cpuapp.overlay -- Found devicetree overlay: /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/child_image/mcuboot.overlay -- Generated zephyr.dts: /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build/mcuboot/zephyr/zephyr.dts -- Generated devicetree_generated.h: /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build/mcuboot/zephyr/include/generated/devicetree_generated.h -- Including generated dts.cmake file: /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build/mcuboot/zephyr/dts.cmake warning: NORDIC_QSPI_NOR (defined at /opt/nordic/ncs/v2.6.1/nrf/Kconfig.nrf:99, drivers/flash/Kconfig.nordic_qspi_nor:4) was assigned the value 'y' but got the value 'n'. See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_NORDIC_QSPI_NOR and/or look up NORDIC_QSPI_NOR in the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too. Parsing /opt/nordic/ncs/v2.6.1/bootloader/mcuboot/boot/zephyr/Kconfig Loaded configuration '/opt/nordic/ncs/v2.6.1/nrf/boards/arm/nrf7002dk_nrf5340/nrf7002dk_nrf5340_cpuapp_defconfig' Merged configuration '/Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/child_image/mcuboot/boards/nrf7002dk_nrf5340_cpuapp.conf' Merged configuration '/opt/nordic/ncs/v2.6.1/nrf/subsys/partition_manager/ext_flash_mcuboot_secondary.conf' Merged configuration '/opt/nordic/ncs/v2.6.1/nrf/subsys/partition_manager/partition_manager_enabled.conf' Merged configuration '/Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/child_image/mcuboot.conf' Merged configuration '/Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf' Configuration saved to '/Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build/mcuboot/zephyr/.config' Kconfig header saved to '/Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build/mcuboot/zephyr/include/generated/autoconf.h' -- Found GnuLd: /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd (found version "2.38") -- The C compiler identification is GNU 12.2.0 -- The CXX compiler identification is GNU 12.2.0 -- The ASM compiler identification is GNU -- Found assembler: /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc CMake Warning at /opt/nordic/ncs/v2.6.1/zephyr/subsys/usb/device/CMakeLists.txt:22 (message): CONFIG_USB_DEVICE_VID has default value 0x2FE3. This value is only for testing and MUST be configured for USB products. CMake Warning at /opt/nordic/ncs/v2.6.1/zephyr/subsys/usb/device/CMakeLists.txt:28 (message): CONFIG_USB_DEVICE_PID has default value 0x100. This value is only for testing and MUST be configured for USB products. -- Using ccache: /opt/nordic/ncs/toolchains/580e4ef81c/bin/ccache CMake Warning at /opt/nordic/ncs/v2.6.1/zephyr/CMakeLists.txt:862 (message): No SOURCES given to Zephyr library: drivers__console Excluding target from build. MCUBoot bootloader key file: /opt/nordic/ncs/v2.6.1/bootloader/mcuboot/root-rsa-2048.pem -- Configuring done -- Generating done -- Build files have been written to: /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build/mcuboot === child image mcuboot - end === CMake Warning at /opt/nordic/ncs/v2.6.1/nrf/modules/mcuboot/CMakeLists.txt:382 (message): --------------------------------------------------------- --- WARNING: Using default MCUBoot key, it should not --- --- be used for production. --- --------------------------------------------------------- -- Using ccache: /opt/nordic/ncs/toolchains/580e4ef81c/bin/ccache CMake Warning at /opt/nordic/ncs/v2.6.1/nrf/cmake/partition_manager.cmake:79 (message): --------------------------------------------------------------------- --- WARNING: Using a bootloader without pm_static.yml. --- --- There are cases where a deployed product can consist of --- --- multiple images, and only a subset of these images can be --- --- upgraded through a firmware update mechanism. In such cases, --- --- the upgradable images must have partitions that are static --- --- and are matching the partition map used by the bootloader --- --- programmed onto the device. --- --------------------------------------------------------------------- Call Stack (most recent call first): /opt/nordic/ncs/v2.6.1/zephyr/cmake/modules/kernel.cmake:248 (include) /opt/nordic/ncs/v2.6.1/zephyr/cmake/modules/zephyr_default.cmake:138 (include) /opt/nordic/ncs/v2.6.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include) /opt/nordic/ncs/v2.6.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate) CMakeLists.txt:7 (find_package) CMake Warning at /opt/nordic/ncs/v2.6.1/nrf/cmake/partition_manager.cmake:601 (message): Could not find memory mapped address for XIP. Generated update hex files will not have the correct base address. Hence they can not be programmed directly to the external flash Call Stack (most recent call first): /opt/nordic/ncs/v2.6.1/zephyr/cmake/modules/kernel.cmake:248 (include) /opt/nordic/ncs/v2.6.1/zephyr/cmake/modules/zephyr_default.cmake:138 (include) /opt/nordic/ncs/v2.6.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include) /opt/nordic/ncs/v2.6.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate) CMakeLists.txt:7 (find_package) -- Configuring done -- Generating done -- Build files have been written to: /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build -- west build: building application [1/225] Preparing syscall dependency handling [3/225] Generating include/generated/version.h -- Zephyr version: 3.5.99 (/opt/nordic/ncs/v2.6.1/zephyr), build: v3.5.99-ncs1-1-1-gef358de7de84 [1/327] Preparing syscall dependency handling [4/327] Generating include/generated/version.h -- Zephyr version: 3.5.99 (/opt/nordic/ncs/v2.6.1/zephyr), build: v3.5.99-ncs1-1-1-gef358de7de84 [322/327] Linking C executable zephyr/zephyr_pre0.elf FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build/mcuboot/zephyr/zephyr_pre0.map : && ccache /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj -fuse-ld=bfd -T zephyr/linker_zephyr_pre0.cmd -Wl,-Map=/Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build/mcuboot/zephyr/zephyr_pre0.map -Wl,--whole-archive app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/libarch__arm__core.a zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a zephyr/arch/arch/arm/core/cortex_m/cmse/libarch__arm__core__cortex_m__cmse.a zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a zephyr/lib/libc/minimal/liblib__libc__minimal.a zephyr/lib/libc/common/liblib__libc__common.a zephyr/soc/soc/arm/nordic_nrf/libsoc__arm__nordic_nrf.a zephyr/drivers/usb/device/libdrivers__usb__device.a zephyr/drivers/usb/common/nrf_usbd_common/libdrivers__usb__common__nrf_usbd_common.a zephyr/drivers/clock_control/libdrivers__clock_control.a zephyr/drivers/flash/libdrivers__flash.a zephyr/drivers/gpio/libdrivers__gpio.a zephyr/drivers/hwinfo/libdrivers__hwinfo.a zephyr/drivers/mbox/libdrivers__mbox.a zephyr/drivers/pinctrl/libdrivers__pinctrl.a zephyr/drivers/serial/libdrivers__serial.a zephyr/drivers/spi/libdrivers__spi.a zephyr/drivers/timer/libdrivers__timer.a modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a modules/nrf/drivers/hw_cc3xx/lib..__nrf__drivers__hw_cc3xx.a modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a modules/mbedtls/libmbedTLSBase.a modules/mbedtls/libmbedTLSCrypto.a modules/mbedtls/libmbedTLSX509.a modules/mbedtls/libmodules__mbedtls.a modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a modules/zcbor/libmodules__zcbor.a -Wl,--no-whole-archive zephyr/kernel/libkernel.a -L"/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v8-m.main/nofp" -L/Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build/mcuboot/zephyr -lgcc zephyr/arch/common/libisr_tables.a modules/mbedtls/libmbedTLSBase.a modules/mbedtls/libmbedTLSCrypto.a modules/mbedtls/libmbedTLSX509.a -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -Wl,-u,_OffsetAbsSyms -Wl,-u,_ConfigAbsSyms -nostdlib -static -Wl,-X -Wl,-N -Wl,--orphan-handling=warn -Wl,-no-pie /opt/nordic/ncs/v2.6.1/nrfxlib/crypto/nrf_cc312_platform/lib/cortex-m33/soft-float/no-interrupts/libnrf_cc312_platform_0.9.19.a && cd /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build/mcuboot/zephyr && /opt/nordic/ncs/toolchains/580e4ef81c/Cellar/cmake/3.21.0/bin/cmake -E true /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/zephyr_pre0.elf section `rodata' will not fit in region `FLASH' /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: region `FLASH' overflowed by 11036 bytes collect2: error: ld returned 1 exit status ninja: build stopped: subcommand failed. [206/225] Linking C static library zephyr/drivers/flash/libdrivers__flash.a FAILED: modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build mcuboot/zephyr/zephyr.hex mcuboot/zephyr/zephyr.elf /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build/modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build/mcuboot/zephyr/zephyr.hex /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build/mcuboot/zephyr/zephyr.elf cd /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build/mcuboot && /opt/nordic/ncs/toolchains/580e4ef81c/Cellar/cmake/3.21.0/bin/cmake --build . -- [208/225] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_spim.c.obj ninja: build stopped: subcommand failed. FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/580e4ef81c/bin/cmake --build /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build * The terminal process terminated with exit code: 1. * Terminal will be reused by tasks, press any key to close it.
And here is the output when I build for an nrf7002dk_nrf5340_cpuapp_ns target.
* Executing task: nRF Connect: Build [pristine]: inter_less8_exer2_solution/build_1 (active) Building inter_less8_exer2_solution west build --build-dir /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build_1 /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution --pristine --board nrf7002dk_nrf5340_cpuapp_ns -- -DNCS_TOOLCHAIN_VERSION=NONE -DBOARD_ROOT=/Users/Glen/Projects/nordic/my_boards;/Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution -- west build: generating a build system Loading Zephyr default modules (Zephyr base). -- Application: /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution -- CMake version: 3.21.0 -- Found Python3: /opt/nordic/ncs/toolchains/580e4ef81c/opt/[email protected]/bin/python3.9 (found suitable version "3.9.6", minimum required is "3.8") found components: Interpreter -- Cache files will be written to: /Users/Glen/Library/Caches/zephyr -- Zephyr version: 3.5.99 (/opt/nordic/ncs/v2.6.1/zephyr) -- Found west (found suitable version "1.2.0", minimum required is "0.14.0") -- Board: nrf7002dk_nrf5340_cpuapp_ns -- Found host-tools: zephyr 0.16.5 (/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk) -- Found toolchain: zephyr 0.16.5 (/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk) -- Found Dtc: /opt/nordic/ncs/toolchains/580e4ef81c/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6") -- Found BOARD.dts: /opt/nordic/ncs/v2.6.1/nrf/boards/arm/nrf7002dk_nrf5340/nrf7002dk_nrf5340_cpuapp_ns.dts -- Found devicetree overlay: /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/app.overlay -- Generated zephyr.dts: /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build_1/zephyr/zephyr.dts -- Generated devicetree_generated.h: /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build_1/zephyr/include/generated/devicetree_generated.h -- Including generated dts.cmake file: /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build_1/zephyr/dts.cmake Parsing /opt/nordic/ncs/v2.6.1/zephyr/Kconfig Loaded configuration '/opt/nordic/ncs/v2.6.1/nrf/boards/arm/nrf7002dk_nrf5340/nrf7002dk_nrf5340_cpuapp_ns_defconfig' Merged configuration '/Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/prj.conf' Configuration saved to '/Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build_1/zephyr/.config' Kconfig header saved to '/Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build_1/zephyr/include/generated/autoconf.h' -- Found GnuLd: /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd (found version "2.38") -- The C compiler identification is GNU 12.2.0 -- The CXX compiler identification is GNU 12.2.0 -- The ASM compiler identification is GNU -- Found assembler: /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc CMake Warning at /opt/nordic/ncs/v2.6.1/zephyr/subsys/usb/device/CMakeLists.txt:22 (message): CONFIG_USB_DEVICE_VID has default value 0x2FE3. This value is only for testing and MUST be configured for USB products. CMake Warning at /opt/nordic/ncs/v2.6.1/zephyr/subsys/usb/device/CMakeLists.txt:28 (message): CONFIG_USB_DEVICE_PID has default value 0x100. This value is only for testing and MUST be configured for USB products. -- Found Python3: /opt/nordic/ncs/toolchains/580e4ef81c/opt/[email protected]/bin/python3.9 (found version "3.9.6") found components: Interpreter Changed board to secure nrf7002dk_nrf5340_cpuapp (NOT NS) === child image mcuboot - begin === loading initial cache file /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build_1/mcuboot/child_image_preload.cmake Loading Zephyr default modules (Zephyr base). -- Application: /opt/nordic/ncs/v2.6.1/bootloader/mcuboot/boot/zephyr -- CMake version: 3.21.0 -- Found Python3: /opt/nordic/ncs/toolchains/580e4ef81c/opt/[email protected]/bin/python3.9 (found suitable version "3.9.6", minimum required is "3.8") found components: Interpreter -- Cache files will be written to: /Users/Glen/Library/Caches/zephyr -- Zephyr version: 3.5.99 (/opt/nordic/ncs/v2.6.1/zephyr) -- Found west (found suitable version "1.2.0", minimum required is "0.14.0") -- Board: nrf7002dk_nrf5340_cpuapp -- Found host-tools: zephyr 0.16.5 (/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk) -- Found toolchain: zephyr 0.16.5 (/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk) -- Found Dtc: /opt/nordic/ncs/toolchains/580e4ef81c/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6") -- Found BOARD.dts: /opt/nordic/ncs/v2.6.1/nrf/boards/arm/nrf7002dk_nrf5340/nrf7002dk_nrf5340_cpuapp.dts -- Found devicetree overlay: /opt/nordic/ncs/v2.6.1/nrf/modules/mcuboot/flash_sim.overlay -- Found devicetree overlay: /opt/nordic/ncs/v2.6.1/nrf/modules/mcuboot/usb.overlay -- Found devicetree overlay: /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/child_image/mcuboot/boards/nrf7002dk_nrf5340_cpuapp.overlay -- Found devicetree overlay: /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/child_image/mcuboot.overlay -- Generated zephyr.dts: /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build_1/mcuboot/zephyr/zephyr.dts -- Generated devicetree_generated.h: /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build_1/mcuboot/zephyr/include/generated/devicetree_generated.h -- Including generated dts.cmake file: /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build_1/mcuboot/zephyr/dts.cmake warning: NORDIC_QSPI_NOR (defined at /opt/nordic/ncs/v2.6.1/nrf/Kconfig.nrf:99, drivers/flash/Kconfig.nordic_qspi_nor:4) was assigned the value 'y' but got the value 'n'. See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_NORDIC_QSPI_NOR and/or look up NORDIC_QSPI_NOR in the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too. Parsing /opt/nordic/ncs/v2.6.1/bootloader/mcuboot/boot/zephyr/Kconfig Loaded configuration '/opt/nordic/ncs/v2.6.1/nrf/boards/arm/nrf7002dk_nrf5340/nrf7002dk_nrf5340_cpuapp_defconfig' Merged configuration '/Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/child_image/mcuboot/boards/nrf7002dk_nrf5340_cpuapp.conf' Merged configuration '/opt/nordic/ncs/v2.6.1/nrf/subsys/partition_manager/ext_flash_mcuboot_secondary.conf' Merged configuration '/opt/nordic/ncs/v2.6.1/nrf/modules/mcuboot/tfm.conf' Merged configuration '/opt/nordic/ncs/v2.6.1/nrf/modules/mcuboot/fih_low_enable.conf' Merged configuration '/opt/nordic/ncs/v2.6.1/nrf/subsys/partition_manager/partition_manager_enabled.conf' Merged configuration '/Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/child_image/mcuboot.conf' Merged configuration '/Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build_1/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf' Configuration saved to '/Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build_1/mcuboot/zephyr/.config' Kconfig header saved to '/Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build_1/mcuboot/zephyr/include/generated/autoconf.h' -- Found GnuLd: /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd (found version "2.38") -- The C compiler identification is GNU 12.2.0 -- The CXX compiler identification is GNU 12.2.0 -- The ASM compiler identification is GNU -- Found assembler: /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc CMake Warning at /opt/nordic/ncs/v2.6.1/zephyr/subsys/usb/device/CMakeLists.txt:22 (message): CONFIG_USB_DEVICE_VID has default value 0x2FE3. This value is only for testing and MUST be configured for USB products. CMake Warning at /opt/nordic/ncs/v2.6.1/zephyr/subsys/usb/device/CMakeLists.txt:28 (message): CONFIG_USB_DEVICE_PID has default value 0x100. This value is only for testing and MUST be configured for USB products. -- Using ccache: /opt/nordic/ncs/toolchains/580e4ef81c/bin/ccache CMake Warning at /opt/nordic/ncs/v2.6.1/zephyr/CMakeLists.txt:862 (message): No SOURCES given to Zephyr library: drivers__console Excluding target from build. MCUBoot bootloader key file: /opt/nordic/ncs/v2.6.1/bootloader/mcuboot/root-rsa-2048.pem -- Configuring done -- Generating done -- Build files have been written to: /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build_1/mcuboot === child image mcuboot - end === CMake Warning at /opt/nordic/ncs/v2.6.1/nrf/modules/mcuboot/CMakeLists.txt:382 (message): --------------------------------------------------------- --- WARNING: Using default MCUBoot key, it should not --- --- be used for production. --- --------------------------------------------------------- -- Using ccache: /opt/nordic/ncs/toolchains/580e4ef81c/bin/ccache CMake Warning at /opt/nordic/ncs/v2.6.1/nrf/cmake/partition_manager.cmake:79 (message): --------------------------------------------------------------------- --- WARNING: Using a bootloader without pm_static.yml. --- --- There are cases where a deployed product can consist of --- --- multiple images, and only a subset of these images can be --- --- upgraded through a firmware update mechanism. In such cases, --- --- the upgradable images must have partitions that are static --- --- and are matching the partition map used by the bootloader --- --- programmed onto the device. --- --------------------------------------------------------------------- Call Stack (most recent call first): /opt/nordic/ncs/v2.6.1/zephyr/cmake/modules/kernel.cmake:248 (include) /opt/nordic/ncs/v2.6.1/zephyr/cmake/modules/zephyr_default.cmake:138 (include) /opt/nordic/ncs/v2.6.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include) /opt/nordic/ncs/v2.6.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate) CMakeLists.txt:7 (find_package) Dropping partition 'nonsecure_storage' since it is empty. CMake Warning at /opt/nordic/ncs/v2.6.1/nrf/cmake/partition_manager.cmake:601 (message): Could not find memory mapped address for XIP. Generated update hex files will not have the correct base address. Hence they can not be programmed directly to the external flash Call Stack (most recent call first): /opt/nordic/ncs/v2.6.1/zephyr/cmake/modules/kernel.cmake:248 (include) /opt/nordic/ncs/v2.6.1/zephyr/cmake/modules/zephyr_default.cmake:138 (include) /opt/nordic/ncs/v2.6.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include) /opt/nordic/ncs/v2.6.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate) CMakeLists.txt:7 (find_package) -- Configuring done -- Generating done -- Build files have been written to: /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build_1 -- west build: building application [1/302] Preparing syscall dependency handling [6/302] Generating include/generated/version.h -- Zephyr version: 3.5.99 (/opt/nordic/ncs/v2.6.1/zephyr), build: v3.5.99-ncs1-1-1-gef358de7de84 [1/322] Preparing syscall dependency handling [4/322] Generating include/generated/version.h -- Zephyr version: 3.5.99 (/opt/nordic/ncs/v2.6.1/zephyr), build: v3.5.99-ncs1-1-1-gef358de7de84 [317/322] Linking C executable zephyr/zephyr_pre0.elf FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build_1/mcuboot/zephyr/zephyr_pre0.map : && ccache /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj -fuse-ld=bfd -T zephyr/linker_zephyr_pre0.cmd -Wl,-Map=/Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build_1/mcuboot/zephyr/zephyr_pre0.map -Wl,--whole-archive app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/libarch__arm__core.a zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a zephyr/arch/arch/arm/core/cortex_m/cmse/libarch__arm__core__cortex_m__cmse.a zephyr/lib/libc/minimal/liblib__libc__minimal.a zephyr/lib/libc/common/liblib__libc__common.a zephyr/soc/soc/arm/nordic_nrf/libsoc__arm__nordic_nrf.a zephyr/drivers/usb/device/libdrivers__usb__device.a zephyr/drivers/usb/common/nrf_usbd_common/libdrivers__usb__common__nrf_usbd_common.a zephyr/drivers/clock_control/libdrivers__clock_control.a zephyr/drivers/flash/libdrivers__flash.a zephyr/drivers/gpio/libdrivers__gpio.a zephyr/drivers/hwinfo/libdrivers__hwinfo.a zephyr/drivers/mbox/libdrivers__mbox.a zephyr/drivers/pinctrl/libdrivers__pinctrl.a zephyr/drivers/serial/libdrivers__serial.a zephyr/drivers/spi/libdrivers__spi.a zephyr/drivers/timer/libdrivers__timer.a modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a modules/nrf/drivers/hw_cc3xx/lib..__nrf__drivers__hw_cc3xx.a modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a modules/mbedtls/libmbedTLSBase.a modules/mbedtls/libmbedTLSCrypto.a modules/mbedtls/libmbedTLSX509.a modules/mbedtls/libmodules__mbedtls.a modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a modules/zcbor/libmodules__zcbor.a -Wl,--no-whole-archive zephyr/kernel/libkernel.a -L"/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v8-m.main/nofp" -L/Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build_1/mcuboot/zephyr -lgcc zephyr/arch/common/libisr_tables.a modules/mbedtls/libmbedTLSBase.a modules/mbedtls/libmbedTLSCrypto.a modules/mbedtls/libmbedTLSX509.a -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -Wl,-u,_OffsetAbsSyms -Wl,-u,_ConfigAbsSyms -nostdlib -static -Wl,-X -Wl,-N -Wl,--orphan-handling=warn -Wl,-no-pie /opt/nordic/ncs/v2.6.1/nrfxlib/crypto/nrf_cc312_platform/lib/cortex-m33/soft-float/no-interrupts/libnrf_cc312_platform_0.9.19.a && cd /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build_1/mcuboot/zephyr && /opt/nordic/ncs/toolchains/580e4ef81c/Cellar/cmake/3.21.0/bin/cmake -E true /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/zephyr_pre0.elf section `rodata' will not fit in region `FLASH' /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/zephyr_pre0.elf section `bss' will not fit in region `RAM' /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: region `FLASH' overflowed by 10092 bytes /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: region `RAM' overflowed by 268464 bytes collect2: error: ld returned 1 exit status ninja: build stopped: subcommand failed. [14/302] Generating ../../tfm/CMakeCache.txt CMake Warning at cmake/version.cmake:22 (message): Actual TF-M version is not available from Git repository. Settled to v2.0.0 Call Stack (most recent call first): CMakeLists.txt:22 (include) -- Found Git: /opt/nordic/ncs/toolchains/580e4ef81c/bin/git (found version "2.37.3") -- The C compiler identification is GNU 12.2.0 -- The CXX compiler identification is GNU 12.2.0 -- The ASM compiler identification is GNU -- Found assembler: /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -- Found Python3: /opt/nordic/ncs/toolchains/580e4ef81c/opt/[email protected]/bin/python3.9 (found version "3.9.6") found components: Interpreter CMake Deprecation Warning at /opt/nordic/ncs/v2.6.1/zephyr/cmake/modules/FindDeprecated.cmake:121 (message): 'PYTHON_PREFER' variable is deprecated. Please use Python3_EXECUTABLE instead. Call Stack (most recent call first): /opt/nordic/ncs/v2.6.1/zephyr/cmake/modules/python.cmake:16 (find_package) /opt/nordic/ncs/v2.6.1/zephyr/cmake/modules/user_cache.cmake:30 (include) /opt/nordic/ncs/v2.6.1/zephyr/cmake/modules/extensions.cmake:5 (include) /opt/nordic/ncs/v2.6.1/nrf/subsys/nrf_security/tfm/CMakeLists.txt:38 (include) -- Found Python3: /opt/nordic/ncs/toolchains/580e4ef81c/opt/[email protected]/bin/python3.9 (found suitable version "3.9.6", minimum required is "3.8") found components: Interpreter -- Cache files will be written to: /Users/Glen/Library/Caches/zephyr -- Configuring done -- Generating done CMake Warning: Manually-specified variables were not used by the project: CRYPTO_RNG_MODULE_ENABLED MBEDTLS_PSA_CRYPTO_USER_CONFIG_FILE PYTHON_PREFER -- Build files have been written to: /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build_1/tfm [19/302] No configure step for 'tfm' FAILED: modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build mcuboot/zephyr/zephyr.hex mcuboot/zephyr/zephyr.elf /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build_1/modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build_1/mcuboot/zephyr/zephyr.hex /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build_1/mcuboot/zephyr/zephyr.elf cd /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build_1/mcuboot && /opt/nordic/ncs/toolchains/580e4ef81c/Cellar/cmake/3.21.0/bin/cmake --build . -- ninja: build stopped: subcommand failed. FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/580e4ef81c/bin/cmake --build /Users/Glen/Projects/Opus/workspace/inter_less8_exer2_solution/build_1 * The terminal process terminated with exit code: 1. * Terminal will be reused by tasks, press any key to close it.
I am focused on Exercise 2 because we want to use USB for the DFU. But even the solution for Exercise 1 for a UART DFU fails to compile:
* Executing task: nRF Connect: Generate config nrf7002dk_nrf5340_cpuapp for /Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution Building inter_less8_exer1_solution west build --build-dir /Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution/build /Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution --pristine --board nrf7002dk_nrf5340_cpuapp -- -DNCS_TOOLCHAIN_VERSION=NONE -DBOARD_ROOT=/Users/Glen/Projects/nordic/my_boards -- west build: generating a build system Loading Zephyr default modules (Zephyr base). -- Application: /Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution -- CMake version: 3.21.0 -- Found Python3: /opt/nordic/ncs/toolchains/580e4ef81c/opt/[email protected]/bin/python3.9 (found suitable version "3.9.6", minimum required is "3.8") found components: Interpreter -- Cache files will be written to: /Users/Glen/Library/Caches/zephyr -- Zephyr version: 3.5.99 (/opt/nordic/ncs/v2.6.1/zephyr) -- Found west (found suitable version "1.2.0", minimum required is "0.14.0") -- Board: nrf7002dk_nrf5340_cpuapp -- Found host-tools: zephyr 0.16.5 (/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk) -- Found toolchain: zephyr 0.16.5 (/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk) -- Found Dtc: /opt/nordic/ncs/toolchains/580e4ef81c/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6") -- Found BOARD.dts: /opt/nordic/ncs/v2.6.1/nrf/boards/arm/nrf7002dk_nrf5340/nrf7002dk_nrf5340_cpuapp.dts -- Generated zephyr.dts: /Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution/build/zephyr/zephyr.dts -- Generated devicetree_generated.h: /Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution/build/zephyr/include/generated/devicetree_generated.h -- Including generated dts.cmake file: /Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution/build/zephyr/dts.cmake Parsing /opt/nordic/ncs/v2.6.1/zephyr/Kconfig Loaded configuration '/opt/nordic/ncs/v2.6.1/nrf/boards/arm/nrf7002dk_nrf5340/nrf7002dk_nrf5340_cpuapp_defconfig' Merged configuration '/Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution/prj.conf' Configuration saved to '/Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution/build/zephyr/.config' Kconfig header saved to '/Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution/build/zephyr/include/generated/autoconf.h' -- Found GnuLd: /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd (found version "2.38") -- The C compiler identification is GNU 12.2.0 -- The CXX compiler identification is GNU 12.2.0 -- The ASM compiler identification is GNU -- Found assembler: /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -- Found Python3: /opt/nordic/ncs/toolchains/580e4ef81c/opt/[email protected]/bin/python3.9 (found version "3.9.6") found components: Interpreter === child image mcuboot - begin === loading initial cache file /Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution/build/mcuboot/child_image_preload.cmake Loading Zephyr default modules (Zephyr base). -- Application: /opt/nordic/ncs/v2.6.1/bootloader/mcuboot/boot/zephyr -- CMake version: 3.21.0 -- Found Python3: /opt/nordic/ncs/toolchains/580e4ef81c/opt/[email protected]/bin/python3.9 (found suitable version "3.9.6", minimum required is "3.8") found components: Interpreter -- Cache files will be written to: /Users/Glen/Library/Caches/zephyr -- Zephyr version: 3.5.99 (/opt/nordic/ncs/v2.6.1/zephyr) -- Found west (found suitable version "1.2.0", minimum required is "0.14.0") -- Board: nrf7002dk_nrf5340_cpuapp -- Found host-tools: zephyr 0.16.5 (/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk) -- Found toolchain: zephyr 0.16.5 (/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk) -- Found Dtc: /opt/nordic/ncs/toolchains/580e4ef81c/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6") -- Found BOARD.dts: /opt/nordic/ncs/v2.6.1/nrf/boards/arm/nrf7002dk_nrf5340/nrf7002dk_nrf5340_cpuapp.dts -- Found devicetree overlay: /opt/nordic/ncs/v2.6.1/nrf/modules/mcuboot/usb.overlay -- Found devicetree overlay: /Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution/child_image/mcuboot.overlay -- Generated zephyr.dts: /Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution/build/mcuboot/zephyr/zephyr.dts -- Generated devicetree_generated.h: /Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution/build/mcuboot/zephyr/include/generated/devicetree_generated.h -- Including generated dts.cmake file: /Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution/build/mcuboot/zephyr/dts.cmake Parsing /opt/nordic/ncs/v2.6.1/bootloader/mcuboot/boot/zephyr/Kconfig Loaded configuration '/opt/nordic/ncs/v2.6.1/nrf/boards/arm/nrf7002dk_nrf5340/nrf7002dk_nrf5340_cpuapp_defconfig' Merged configuration '/opt/nordic/ncs/v2.6.1/bootloader/mcuboot/boot/zephyr/prj.conf' Merged configuration '/opt/nordic/ncs/v2.6.1/nrf/subsys/partition_manager/partition_manager_enabled.conf' Merged configuration '/Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution/child_image/mcuboot.conf' Merged configuration '/Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution/build/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf' Configuration saved to '/Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution/build/mcuboot/zephyr/.config' Kconfig header saved to '/Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution/build/mcuboot/zephyr/include/generated/autoconf.h' -- Found GnuLd: /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd (found version "2.38") -- The C compiler identification is GNU 12.2.0 -- The CXX compiler identification is GNU 12.2.0 -- The ASM compiler identification is GNU -- Found assembler: /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -- Using ccache: /opt/nordic/ncs/toolchains/580e4ef81c/bin/ccache CMake Warning at /opt/nordic/ncs/v2.6.1/zephyr/CMakeLists.txt:862 (message): No SOURCES given to Zephyr library: drivers__console Excluding target from build. CMake Warning at /opt/nordic/ncs/v2.6.1/zephyr/CMakeLists.txt:862 (message): No SOURCES given to Zephyr library: drivers__spi Excluding target from build. MCUBoot bootloader key file: /opt/nordic/ncs/v2.6.1/bootloader/mcuboot/root-rsa-2048.pem -- Configuring done -- Generating done -- Build files have been written to: /Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution/build/mcuboot === child image mcuboot - end === CMake Warning at /opt/nordic/ncs/v2.6.1/nrf/modules/mcuboot/CMakeLists.txt:382 (message): --------------------------------------------------------- --- WARNING: Using default MCUBoot key, it should not --- --- be used for production. --- --------------------------------------------------------- -- Using ccache: /opt/nordic/ncs/toolchains/580e4ef81c/bin/ccache CMake Warning at /opt/nordic/ncs/v2.6.1/nrf/cmake/partition_manager.cmake:79 (message): --------------------------------------------------------------------- --- WARNING: Using a bootloader without pm_static.yml. --- --- There are cases where a deployed product can consist of --- --- multiple images, and only a subset of these images can be --- --- upgraded through a firmware update mechanism. In such cases, --- --- the upgradable images must have partitions that are static --- --- and are matching the partition map used by the bootloader --- --- programmed onto the device. --- --------------------------------------------------------------------- Call Stack (most recent call first): /opt/nordic/ncs/v2.6.1/zephyr/cmake/modules/kernel.cmake:248 (include) /opt/nordic/ncs/v2.6.1/zephyr/cmake/modules/zephyr_default.cmake:138 (include) /opt/nordic/ncs/v2.6.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include) /opt/nordic/ncs/v2.6.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate) CMakeLists.txt:4 (find_package) -- Configuring done -- Generating done -- Build files have been written to: /Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution/build -- west build: building application [1/209] Preparing syscall dependency handling [5/209] Generating include/generated/version.h -- Zephyr version: 3.5.99 (/opt/nordic/ncs/v2.6.1/zephyr), build: v3.5.99-ncs1-1-1-gef358de7de84 [1/288] Preparing syscall dependency handling [4/288] Generating include/generated/version.h -- Zephyr version: 3.5.99 (/opt/nordic/ncs/v2.6.1/zephyr), build: v3.5.99-ncs1-1-1-gef358de7de84 [283/288] Linking C executable zephyr/zephyr_pre0.elf FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map /Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution/build/mcuboot/zephyr/zephyr_pre0.map : && ccache /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj -fuse-ld=bfd -T zephyr/linker_zephyr_pre0.cmd -Wl,-Map=/Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution/build/mcuboot/zephyr/zephyr_pre0.map -Wl,--whole-archive app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/libarch__arm__core.a zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a zephyr/arch/arch/arm/core/cortex_m/cmse/libarch__arm__core__cortex_m__cmse.a zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a zephyr/lib/libc/minimal/liblib__libc__minimal.a zephyr/lib/libc/common/liblib__libc__common.a zephyr/soc/soc/arm/nordic_nrf/libsoc__arm__nordic_nrf.a zephyr/drivers/clock_control/libdrivers__clock_control.a zephyr/drivers/flash/libdrivers__flash.a zephyr/drivers/gpio/libdrivers__gpio.a zephyr/drivers/pinctrl/libdrivers__pinctrl.a zephyr/drivers/serial/libdrivers__serial.a zephyr/drivers/timer/libdrivers__timer.a modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a modules/nrf/drivers/hw_cc3xx/lib..__nrf__drivers__hw_cc3xx.a modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a modules/mbedtls/libmbedTLSBase.a modules/mbedtls/libmbedTLSCrypto.a modules/mbedtls/libmbedTLSX509.a modules/mbedtls/libmodules__mbedtls.a modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a modules/zcbor/libmodules__zcbor.a -Wl,--no-whole-archive zephyr/kernel/libkernel.a -L"/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v8-m.main/nofp" -L/Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution/build/mcuboot/zephyr -lgcc zephyr/arch/common/libisr_tables.a modules/mbedtls/libmbedTLSBase.a modules/mbedtls/libmbedTLSCrypto.a modules/mbedtls/libmbedTLSX509.a -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -Wl,-u,_OffsetAbsSyms -Wl,-u,_ConfigAbsSyms -nostdlib -static -Wl,-X -Wl,-N -Wl,--orphan-handling=warn -Wl,-no-pie /opt/nordic/ncs/v2.6.1/nrfxlib/crypto/nrf_cc312_platform/lib/cortex-m33/soft-float/no-interrupts/libnrf_cc312_platform_0.9.19.a && cd /Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution/build/mcuboot/zephyr && /opt/nordic/ncs/toolchains/580e4ef81c/Cellar/cmake/3.21.0/bin/cmake -E true /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/drivers/flash/libdrivers__flash.a(spi_nor.c.obj): in function `k_sleep': /Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution/build/mcuboot/zephyr/include/generated/syscalls/kernel.h:135: undefined reference to `z_impl_k_sleep' /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution/build/mcuboot/zephyr/include/generated/syscalls/kernel.h:135: undefined reference to `z_impl_k_sleep' /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/drivers/flash/libdrivers__flash.a(spi_nor.c.obj):(.rodata.spi_nor_config_0+0x0): undefined reference to `__device_dts_ord_143' collect2: error: ld returned 1 exit status ninja: build stopped: subcommand failed. [197/209] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj FAILED: modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build mcuboot/zephyr/zephyr.hex mcuboot/zephyr/zephyr.elf /Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution/build/modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build /Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution/build/mcuboot/zephyr/zephyr.hex /Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution/build/mcuboot/zephyr/zephyr.elf cd /Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution/build/mcuboot && /opt/nordic/ncs/toolchains/580e4ef81c/Cellar/cmake/3.21.0/bin/cmake --build . -- [199/209] Linking C executable zephyr/zephyr.elf Memory region Used Size Region Size %age Used FLASH: 45940 B 491008 B 9.36% RAM: 12720 B 448 KB 2.77% IDT_LIST: 0 GB 32 KB 0.00% ninja: build stopped: subcommand failed. FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/580e4ef81c/bin/cmake --build /Users/Glen/Projects/Opus/workspace/inter_less8_exer1_solution/build * The terminal process terminated with exit code: 1. * Terminal will be reused by tasks, press any key to close it.
Why do these work for the nRF52833DK, but not the nRF7002DK? The nRF7002DK is listed as a board that should work since it has USB.
