This case don't happen when i merged net_core and app_core to burn. I used to burn only one core.
What causes this?
Now I have a new question.I use one nrf5340 as CIS client to conncect Galaxy Buds2 Pro but the voice i hear is bad because the cpu usage is high.
So i try to reduce the sampling rate used by codec.
CONFIG_LC3_ENC_SAMPLE_RATE_8KHZ_SUPPORT=y CONFIG_LC3_ENC_SAMPLE_RATE_16KHZ_SUPPORT=y CONFIG_LC3_ENC_SAMPLE_RATE_24KHZ_SUPPORT=y CONFIG_LC3_ENC_SAMPLE_RATE_32KHZ_SUPPORT=n CONFIG_LC3_ENC_SAMPLE_RATE_441KHZ_SUPPORT=n CONFIG_LC3_ENC_SAMPLE_RATE_48KHZ_SUPPORT=n # end of Encoder sample rates # # Decoder sample rates # CONFIG_LC3_DEC_SAMPLE_RATE_8KHZ_SUPPORT=y CONFIG_LC3_DEC_SAMPLE_RATE_16KHZ_SUPPORT=y CONFIG_LC3_DEC_SAMPLE_RATE_24KHZ_SUPPORT=n CONFIG_LC3_DEC_SAMPLE_RATE_32KHZ_SUPPORT=n CONFIG_LC3_DEC_SAMPLE_RATE_441KHZ_SUPPORT=n CONFIG_LC3_DEC_SAMPLE_RATE_48KHZ_SUPPORT=n
Use this cfg to init encode success but decode sample rate is selected 48k, this causes
HL [00:00:23.566,131] [1;31m<err> sw_codec_select: ret:-5009 HL [00:00:23.566,192] [1;31m<err> audio_system: Failed to set up codec HL [00:00:23.566,192] [1;31m<err> audio_system: ERR_CHK Err_code: [-5009] @ line: 490
Can i set decode sample rate in client and inform headset use the same cfg?
Thanks!
