nrf5340 fs_sample on custom GPIOs
I built a custom board with the nrf5340 and a SD card connected to non-standard gpios. My SD card is connected via SPI over the P0.14, P0.15, P0.16, P0.17, respectively for CS, MISO, MOSI, CLK. Since I was not able to mount the SD card on my custom board, I moved to the evaluation kit nrf5340dk.
On the nrf5340dk I was able to succesfully exectue the example fs_sample on default pins, but when I move to P0.14, P0.15, P0.16, P0.1 there is no way I can make the fs driver to work.
Here my configuration (I tried several):
Zephyr version: 4.0.99
	spi4_default: spi4_default {
		group1 {
			psels = <NRF_PSEL(SPIM_SCK, 0, 17)>,
				<NRF_PSEL(SPIM_MISO, 0, 15)>,
				<NRF_PSEL(SPIM_MOSI, 0, 16)>;
			//bias-pull-up;
			//nordic,drive-mode = <NRF_DRIVE_H0H1>;
	spi4_sleep: spi4_sleep {
		group1 {
			low-power-enable;
then I have an overlay file for the fs_sample
&spi4 {
	status = "okay";
	cs-gpios = <&gpio0 14 GPIO_ACTIVE_LOW>; /* D10 */
	pinctrl-0 = <&spi4_default>;
	pinctrl-1 = <&spi4_sleep>;
	sdhc0: sdhc@0 {
		compatible = "zephyr,sdhc-spi-slot";
		reg = <0>;
		status = "okay";
		mmc {
			compatible = "zephyr,sdmmc-disk";
			disk-name = "SD";
			status = "okay";
		spi-max-frequency = <4000000>;
/* Enable high drive mode for the SPI3 pins to get a square signal at 8 MHz */
&spi4_default {
	group1 {
I didn't find any PIN conflict between the network and app cores, and following the documentation and previous posts on the forum I don't find any other possible configuration to add.
Thanks in advance for the support.
