hci_uart with Channel Sounding feature enabled
I am building a Bluetooth controller with channel sounding feature enabled. The project uses an external Bluetooth host along with the hci_uart example. The prj.conf file was modified to enable CONFIG_BT_CHANNEL_SOUNDING.
However, when I try to send the bt_le_cs_read_local_supported_capabilities command, I receive a status of "Command Disallowed".
Below are the hex commands exchanged:
  • Command sent (HCI Command Packet):
    01 89 20 00
  • Response received (HCI Event Packet):
    04 0e 20 01 89 20 0c 00 00 00 00 00 00 90 0a 00 00 e4 00 0c 00 28 22 c0 00 00 00 e0 00 04 18 82 f7 ff ff
Could you please advise if I am doing something wrong? Does this command require any preconditions or additional configuration steps?
Thank you for your assistance.
