nRF5340 SPI slave doesnt seem to receive
I have ported my already working nRF52840 SPI slave code to a nRF5340, but it doesnt seem to receive any data. I have verified the CS, SCK and MOSI signals, but no MISO from nRF5340.
static const struct spi_config spis_cfg = {
	.operation = SPI_WORD_SET(8) | SPI_TRANSFER_MSB | SPI_OP_MODE_SLAVE | SPI_MODE_CPOL | SPI_MODE_CPHA,
	.slave = 1,
static void spi_slave_init(void)
	spis_dev = DEVICE_DT_GET(MY_SPI_SLAVE);
	if (!device_is_ready(spis_dev)) {
		printk("SPI slave device not ready!\n");
		LOG_INF ("SPI slave ready");
static int spi_slave_check_for_message(void)
	int signaled, result;
	k_poll_signal_check(&spi_slave_done_sig, &signaled, &result);
	if (signaled != 0){
		slave_tx_buffer [0] = 0x01;	// init slave tx buffer
		return 0;
	else return -1;
static int spi_slave_wait_msg(uint8_t txlen, uint8_t rxlen)
	const struct spi_buf s_tx_buf = {
		.buf = slave_tx_buffer,
		.len = txlen
	const struct spi_buf_set s_tx = {
		.buffers = &s_tx_buf,
		.count = 1
	struct spi_buf s_rx_buf = {
		.buf = slave_rx_buffer,
		.len = rxlen
	const struct spi_buf_set s_rx = {
		.buffers = &s_rx_buf,
		.count = 1
	// Reset signal - this flag the next msg check
	k_poll_signal_reset(&spi_slave_done_sig);
	// Start transaction
	int error = spi_transceive_signal(spis_dev, &spis_cfg, &s_tx, &s_rx, &spi_slave_done_sig);	// once a cycle is complete, the 'spi_slave_done_sig' will get signelled
	if(error != 0){
		LOG_ERR("SPI slave transceive error: %i\n", error);
		return error;
	return 0;
static void spis_handler (struct k_work *item) {
static uint8_t txlen, rxlen;
int8_t i=0, loopCnt=0;
static uint8_t startRec=0;
uint16_t hostFWRev;
	if (spi_slave_check_for_message() == 0){
		LOG_INF ("---- Received SPI msg -----");
		switch (slave_rx_buffer [0]) {
			case 'V':	// Feature 7
				hostFWRev = EncVerString ();
				LOG_INF ("Host radio FW : %04x", hostFWRev);
				slave_tx_buffer[0] = 'A';
				slave_tx_buffer[1] = (uint8_t)(hostFWRev >> 8);
				slave_tx_buffer[2] = (uint8_t)(hostFWRev & 0x00ff);
				txlen = 3;
				rxlen = 1;
			case 'A':	// ACK/NAK request. This is the second byte send by host after the command. Only thing we need is to send the ACK/NAK of last command
				//LOG_INF ("ACK/NAK command");
			default :
				LOG_ERR ("default %x, %c", slave_rx_buffer [0], slave_rx_buffer [0]);
				slave_tx_buffer[0] = 'K';
				txlen = 1;
				rxlen = 1;
		// Prepare the next SPI slave transaction -  this means the ACK/NAK doesnt get send immediately, but in next rx cycle.
		// This means we have to either send same command twice or have a ACK/NAK request command, which is send after each command
		spi_slave_wait_msg(txlen, rxlen);
	k_msleep (1);
	k_work_submit (item);
void main(void)
	spi_slave_init ();
	spi_slave_wait_msg (1, 1);	// this starts the k_poll event to wait for next spi rx
	k_work_init(&spis_work, spis_handler);		// spis handling is done in system queue to avoid issues with spi async transfers
	k_work_submit (&spis_work);
I get 'SPI slave ready' as a result of invoking spi_slave_init () function.
I can see the spis_handler () is invoked repeatedly, but 'spi_slave_check_for_message() == 0' seems to fail all the time.
I use nordic SDK 2.9.0.
I saw in the nRF5340 user guide that there is a hardware semaphore for accessing spi buffers, which was not available in nRF52840. Is there anything I need to implement in the application level to do that?
I have tried all I can think of and need some help urgently.
Kaushalya
  • Hi Kenneth,
    Yes we use NS+TF-M. When I add ' CONFIG_TFM_LOG_LEVEL_SILENCE=y' to my prj.conf, I get
    d:/Projects/nrf/zm2hostradiofw/prj.conf:89: warning: ignoring malformed line ' CONFIG_TFM_LOG_LEVEL_SILENCE=y'
    It seems I have not built TF-M with my application. So I added CONFIG_BUILD_WITH_TFM=y and then the project got built, but then the app doesnt seem to run. (I have disabled UART1 from my overlay as explained in https://docs.nordicsemi.com/bundle/ncs-2.9.0/page/nrf/security/tfm.html#building
    Apparently TF-M uses UART1. I have tried assigning different pins to the UART1 in my overlay as follows.
        uart1_default: uart1_default {
            group1 {
                psels = <NRF_PSEL(UART_TX, 1, 5)>,
                    <NRF_PSEL(UART_RTS, 0, 11)>;
            group2 {
                psels = <NRF_PSEL(UART_RX, 1, 0)>,
                    <NRF_PSEL(UART_CTS, 0, 10)>;
                bias-pull-up;
        uart1_sleep: uart1_sleep {
            group1 {
                    <NRF_PSEL(UART_RTS, 0, 11)>,
                low-power-enable;
    But still P0.01 doesnt seem to work for SPI slave.
    My time limit for this project has almost finished. So any help is much appreciated.
    Cheers,
    Kaushalya
  • Can you at least make sure it works without TF-M?
    The overlay you refer to , what is the name of that file?
    Kenneth
