I am trying to create a custom mesh sensor-sever for my icm20948 sensor. Can I transfer 9 16-bit floating point data at a time and how?
I am trying to transferring 9 16-bit floating point data(acceleratometer, gyro, magnetometer * x, y, z) fetched from icm20948 sensor by BLE Mesh, using nrf54l15dk. I changed the sensor server struct based on the "sample/bluetooth/meth/sensor_server" sample. It gives 5 elements for 5 kinds of sensors, and I changed the bt_mesh_sensor_type "people count", by adding more bt_mesh_sensor_channel channels. Then I built it and flashed it to my nrf54l15dk and tried to fetch data on nrf mesh mobile app, then I got the kernel panic error.
My code:
static const struct bt_mesh_sensor_unit people_count_sensor_unit = {
	.name = "people_count_sensor_data",
	.symbol = "none",
static const struct bt_mesh_sensor_format people_count_sensor_format = {
	.size = 2,
	.unit = &people_count_sensor_unit,
static const struct bt_mesh_sensor_channel people_count_sensor_channels[] = { {
		.format = &people_count_sensor_format,
		.name = "channel_1",
		.name = "channel_2",
static const struct bt_mesh_sensor_type people_count_sensor_type_new = {
	.id = BT_MESH_PROP_ID_CUSTOM_ICM20948,
	.channel_count = 2,
	.channels = people_count_sensor_channels,
static const struct bt_mesh_sensor_value people_count_sensor_value_new = {
// 人数传感器数据获取函数
static int people_count_get(struct bt_mesh_sensor_srv *srv,
				 struct bt_mesh_sensor *sensor,
				 struct bt_mesh_msg_ctx *ctx,
				 struct bt_mesh_sensor_value *rsp)
	int err;
	err = bt_mesh_sensor_value_from_micro(sensor->type->channels[0].format, BASE_UNITS_TO_MICRO(dummy_people_count_value_1), &rsp[0]);
	err = bt_mesh_sensor_value_from_micro(sensor->type->channels[1].format, BASE_UNITS_TO_MICRO(dummy_people_count_value_2), &rsp[1]);
	// 将虚拟数据dummy(整数)转换为sensor_value结构体
	if (err && err != -ERANGE) {
		printk("Error encoding people count (%d)", err);
		return err;
	return 0;
static struct bt_mesh_sensor people_count_sensor = { // 人数传感器定义
	.type = &people_count_sensor_type_new, // 工具包自带人数传感器数据类型
	.get = people_count_get,
Error occurred:
<err> os: r0/a1:  0x00000004  r1/a2:  0x00000458  r2/a3:  0x20005ac0
[00:02:23.457,039] <err> os: r3/a4:  0x00000004 r12/ip:  0x20000e68 r14/lr:  0x0001c02b
[00:02:23.457,047] <err> os:  xpsr:  0x01100000
[00:02:23.457,055] <err> os: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0x0004000b
[00:02:23.457,064] <err> os: s[ 4]:  0x00000000  s[ 5]:  0x00000000  s[ 6]:  0x0004c2e9  s[ 7]:  0x2000ab74
[00:02:23.457,073] <err> os: s[ 8]:  0x00000000  s[ 9]:  0x0003f3eb  s[10]:  0x0004c2e9  s[11]:  0x2000ab74
[00:02:23.457,081] <err> os: s[12]:  0x00000458  s[13]:  0x0001c021  s[14]:  0x0004c2e9  s[15]:  0x0004cca6
[00:02:23.457,087] <err> os: fpscr:  0x00000458
[00:02:23.457,092] <err> os: Faulting instruction address (r15/pc): 0x0003f3d8
[00:02:23.457,124] <err> os: >>> ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0
[00:02:23.457,140] <err> os: Current thread: 0x20005ac0 (unknown)
*** Booting Mesh Sensor v2.9.0-687260cfb136 *** system
In the code I shown above I simply add one more channel in bt_mesh_sensor_channel structure. Can I transfer more data using this way? If not, what else method should I use?
Thank you!
