sd_ecb_block_encrypt returns error
		nrf_ecb_hal_data_t encryption_parm;
	memset(&encryption_parm, 0, sizeof(encryption_parm));
	 memcpy(encryption_parm.key, encryption_key, sizeof(encryption_key));
	 memcpy(encryption_parm.cleartext, clear_text, sizeof(clear_text));
	 memcpy(encryption_parm.ciphertext, cypher_text, sizeof(cypher_text));
	//encryption_parm
	err_code=sd_ecb_block_encrypt(&encryption_parm);
Above is the code for AES encryption. The code resets when APP_ERROR_CHECK function is executed. Should I set any other parameters or use any function before calling the d_ecb_block_encrypt function. Encryption function is called before initializing the BLE stack.
