Not able to flash nrf52840 DK unless the reset pin tied to NRF_VDD
I'm going through the Academy courses and somewhere around Lesson 3, I could no longer flash firmware to the nrf52840 DK.
I browsed the forum and found some notes around erasing the UICR (nrfjprog --eraseuicr   / nrfjprog --recover) that run successfully with P0.18 tied to VDD but I still can't flash the board without P0.18 tied to VDD.
I was trying some other 3rd-party firmware examples in between all of this, which I believe caused the issue but I can't seem to get back to the factory config for the board and continue with the Academy course!
Any help is appreciated.
  • Did some additional digging...
    I had the power profiler 2 connected to the nrf52840-dk in ampere/current mode.  I've removed that and jumpered P22 and now everything is working as expected!
    I know I had installed a few firmwares in this config and everything worked.  Not sure why it decided to stop working.
    I see one note that references this in the PP2 docs:
    "To reprogram the nRF52840 SoC while the DK is prepared for current measurements, remove measurement devices from P22, and then connect the USB cable."
    So I guess this is normal and what I initially saw was a fluke?
    Anyway, back to the academy courses.
