Hi Sigurd,
I'm finally using the mcuboot and mcumgr_cli I worked on in summer of 2023. I generated the mcumgr_cli for debian with go lang back then. I'm building my app for a Fanstel BT840F/E/XE (52840) with mcuboot in VScode. The mcumgr commands work and flashes ok only if the "image list" shows "hash: Unavailable". The upload command fails when the hash shows a value.
I've also noticed it seams to fail if the bootloader code is first loaded with J-Link (VScode or Connect Desktop Programmer). Then it fails to load another app. So I can load an older simple bootloader app with J-Link then it will boot-load my latest app and keep working. But if I load it with VScode, it fails??? Please respond with a possible cause and what configuration might be missing?
WORKS:
Feb 6 15:35:25 710-200-9992023 hub3-ble: RUNNING ./mcumgr_cli conn add acm0 type="serial" connstring="dev=/dev/ttymxc2,baud=1000000,mtu=512"
Feb 6 15:35:25 710-200-9992023 hub3-ble: Connection profile acm0 successfully added
Feb 6 15:35:25 710-200-9992023 hub3-ble: RUNNING ./mcumgr_cli -c acm0 image list
Feb 6 15:35:25 710-200-9992023 hub3-ble: Images:
Feb 6 15:35:25 710-200-9992023 hub3-ble: image=0 slot=0
Feb 6 15:35:25 710-200-9992023 hub3-ble: version: 0.0.0.0
Feb 6 15:35:25 710-200-9992023 hub3-ble: bootable: false
Feb 6 15:35:25 710-200-9992023 hub3-ble: flags:
Feb 6 15:35:25 710-200-9992023 hub3-ble: hash: Unavailable
Feb 6 15:35:25 710-200-9992023 hub3-ble: Split status: N/A (0)
Feb 6 15:35:25 710-200-9992023 hub3-ble: RUNNING ./mcumgr_cli -c acm0 image upload /data/fw_dnld/module/module_fw_3.0.2-90.bin
27.18 KiB / 244.32 KiB [===>-----------------------] 9.90% 10.74 KiB/s 00m20s
57.39 KiB / 244.32 KiB [=====>---------------------] 22.13% 11.03 KiB/s 00m16s
71.58 KiB / 244.32 KiB [========>-------------------] 29.30% 9.48 KiB/s 00m18s49% 11.25 KiB/s 00m16s
81.43 KiB / 244.32 KiB [=========>------------------] 32.93% 8.05 KiB/s 00m20s
91.60 KiB / 244.32 KiB [==========>-----------------] 37.22% 7.18 KiB/s 00m21ss
101.11 KiB / 244.32 KiB [===========>---------------] 41.39% 6.62 KiB/s 00m21s----] 37.49% 7.12 KiB/s 00m21s
110.30 KiB / 244.32 KiB [============>--------------] 44.88% 6.17 KiB/s 00m21s
119.49 KiB / 244.32 KiB [=============>-------------] 48.91% 5.85 KiB/s 00m21sB/s 00m21s
129.00 KiB / 244.32 KiB [==============>------------] 52.53% 5.61 KiB/s 00m20s-------------] 49.18% 5.83 KiB/s 00m21s
139.18 KiB / 244.32 KiB [===============>-----------] 56.56% 5.41 KiB/s 00m19s
148.04 KiB / 244.32 KiB [================>----------] 60.59% 5.26 KiB/s 00m18s% 5.41 KiB/s 00m19s
158.21 KiB / 244.32 KiB [=================>---------] 64.35% 5.13 KiB/s 00m16s
167.72 KiB / 244.32 KiB [==================>--------] 68.25% 5.01 KiB/s 00m15s
175.93 KiB / 244.32 KiB [===================>-------] 72.01% 4.90 KiB/s 00m14s-] 68.65% 5.01 KiB/s 00m15s
185.11 KiB / 244.32 KiB [====================>------] 75.37% 4.80 KiB/s 00m12s
194.32 KiB / 244.32 KiB [=====================>-----] 79.13% 4.71 KiB/s 00m10s 00m12s
202.50 KiB / 244.32 KiB [======================>----] 82.62% 4.64 KiB/s 00m09s====>-----] 79.53% 4.71 KiB/s 00m10s
212.35 KiB / 244.32 KiB [=======================>---] 86.65% 4.58 KiB/s 00m07s
221.21 KiB / 244.32 KiB [========================>--] 90.54% 4.53 KiB/s 00m05s.58 KiB/s 00m06s
230.39 KiB / 244.32 KiB [=========================>-] 94.03% 4.48 KiB/s 00m03s
240.24 KiB / 244.32 KiB [==================================] 98.20% 4.44 KiB/s
244.32 KiB / 244.32 KiB [==============================] 100.00% 4.42 KiB/s 55s=====] 98.33% 4.43 KiB/s
Feb 6 15:36:20 710-200-9992023 hub3-ble: Done
Feb 6 15:36:20 710-200-9992023 hub3-ble: RUNNING ./mcumgr_cli -c acm0 reset
FAILS:
Feb 7 16:29:37 710-200-9992023 hub3-ble: RUNNING ./mcumgr_cli conn add acm0 type="serial" connstring="dev=/dev/ttymxc2,baud=1000000,mtu=512"
Feb 7 16:29:37 710-200-9992023 hub3-ble: Connection profile acm0 successfully added
Feb 7 16:29:37 710-200-9992023 hub3-ble: RUNNING ./mcumgr_cli -c acm0 image list
Feb 7 16:29:37 710-200-9992023 hub3-ble: Images:
Feb 7 16:29:37 710-200-9992023 hub3-ble: image=0 slot=0
Feb 7 16:29:37 710-200-9992023 hub3-ble: version: 3.0.2
Feb 7 16:29:37 710-200-9992023 hub3-ble: bootable: false
Feb 7 16:29:37 710-200-9992023 hub3-ble: flags:
Feb 7 16:29:37 710-200-9992023 hub3-ble: hash: 560e0f34b1ac87683cae52d7e6ba2f872a5ff09273df2b15517d1e4407d810e9
Feb 7 16:29:37 710-200-9992023 hub3-ble: Split status: N/A (0)
Feb 7 16:29:37 710-200-9992023 hub3-ble: RUNNING ./mcumgr_cli -c acm0 image upload /data/fw_dnld/module/module_fw_3.0.2-90.bin
0 B / 244.31 KiB [----------------------------------------------------] 0.00%
I thought it might be an SDK incompatibility thing since I was using v2.3.0 when I generated the mcumgr_cli with go and now use v2.5.0. I plan to bump that up when I get everything working. I also noticed this:
CMake Warning at C:/Hub3.0/BLE/module-ble/external/nrf/cmake/partition_manager.cmake:79 (message):
--- WARNING: Using a bootloader without pm_static.yml. ---
--- There are cases where a deployed product can consist of ---
--- multiple images, and only a subset of these images can be ---
--- upgraded through a firmware update mechanism. In such cases, ---
--- the upgradable images must have partitions that are static ---
--- and are matching the partition map used by the bootloader ---
--- programmed onto the device. ---
Bob
