The DFU operation scenario.
HI.
nRF51 is inexperienced users.
I've downloaded using nRFgo Studio.
Preparation before the test to dfu.
  1. nRF51_SDK_10.0.0
    1. Components\softdevice\s110\hex
      • s110_nrf51_8.0.0_softdevice.hex
    2. dfu\bootloader\pca10028\dual_bank_ble_s110\arm4_build
      • nrf51422_xxac.hex
    3. After building the application, it has been downloaded(using nRFgo Studio).
      • ble_app_uart_dfu.hex
    4. I have created a zip file that want to upgrade.
      • Creating an image file
    5. nRF Toolbox
      • When the button is pressed(SELECT DEVICE), The name seemed "DfuTarg". Finally, I downloaded a uart application(ble_app_uart_dfu.hex), I think there seems to be marked with the "Nordic_UART". Why does this name does not look Nordic_UART?
Thank you.
  • Short answer: Things get cached a lot with BLE. You will notice this all the time when you develop. Maybe you change the device name, advertising data, service info etc.. and it will still have old value.
    Really the only way I've found to workaround this is to disable and re enable BLE (when using phone applications). With master control panel PC application this isn't a problem because you can reset your usb dongle and re discover services as you need to.
    Maybe someone has a better answer.. But i see this a lot and haven't found a great way with the smart phone aps.
  • hi.
    The reason that shows "DfuTarg" It looks like one caused by downloading the bootloader(nrf51422_xxac.hex).
    Finally I downloaded a uart application(ble_app_uart_dfu.hex), Why did the name come "DfuTarg" ?
  • This is because of caching occurring on the smartphone application. I'm guessing you are either using android or iOS Master Control Panel. Try closing master control panel, disabling bluetooth, re enabling it and then starting master control panel again and scanning for the uart application. Now you should see the name is Nordic_UART.
    If you use PC Master Control Panel you probably won't see this problem.
  • Dear Michael Dietz .
    •If only the binary download s110_nrf51_8.0.0_softdevice.hex + ble_app_uart_dfu.hex
    -> The lights turn on led 1.
    -> Nordic_UART display.
    • s110_nrf51_8.0.0_softdevice.hex (softdevice) + nrf51422_xxac.hex(bootloader) +
      ble_app_uart_dfu.hex(application) -> When downloading sequentially, The lights turn on led 1 and Led 2. -> DfuTarg display.
    thank you.
  • OK. That means your bootloader application is running and not the UART app. When bootloader app is advertising LED1 and LED3 are lit. When it is connected LED1 and LED2 are lit.
    You probably want the UART application to be running and have your bootloader there if you want to do a DFU update. Note that you cannot just flash solftdevice+bootloader+application as normal. You need to flash softdevice then bootloader and then run in bootloader mode (LED1 and LED3 lit). then you connect to DFU Targ and you need to program the ble_app_uart application by DFU. Then after you do this you will see your uart app run.
    There is alot on this. it is possible to flash teh application with sd+bl like normal but you need to write a flag in flash to tell the bootloader a valid app is present on the device. search dev zone for this
