I have tried building the mentioned sample application for nrf7002dk_nrf5340_cpuapp_ns board and i am getting below error at runtime.
[00:00:01.438,110] <err> os: ***** SECURE FAULT ***** [00:00:01.438,110] <err> os: Address: 0x3 [00:00:01.438,140] <err> os: Attribution unit violation
So, my question is that can we successfully build and run the mentioned sample application for nrf7002dk_nrf5340_cpuapp_ns board or in general _ns board type ?
Also, I want to use the MbedTLS in my project. We are not able to build the project for nrf7002dk_nrf5340_cpuapp board when MbedTLS is enabled.
Got these errors :
In file included from /home/guest/ncs/v2.7.0/modules/crypto/mbedtls/library/pk_internal.h:26, from /home/guest/ncs/v2.7.0/modules/crypto/mbedtls/library/pk_wrap.c:14: /home/guest/ncs/v2.7.0/modules/crypto/mbedtls/library/pk_wrap.c: In function 'mbedtls_pk_psa_rsa_sign_ext': /home/guest/ncs/v2.7.0/modules/crypto/mbedtls/library/pk_internal.h:29:67: error: 'psa_to_pk_rsa_errors' undeclared (first use in this function); did you mean 'psa_to_md_errors'? 29 | psa_to_pk_rsa_errors, \ | ^~~~~~~~~~~~~~~~~~~~ /home/guest/ncs/v2.7.0/modules/crypto/oberon-psa-crypto/library/psa_util_internal.h:103:35: note: in definition of macro 'PSA_TO_MBEDTLS_ERR_LIST' 103 | psa_status_to_mbedtls(status, error_list, \ | ^~~~~~~~~~ /home/guest/ncs/v2.7.0/modules/crypto/mbedtls/library/pk_wrap.c:331:15: note: in expansion of macro 'PSA_PK_RSA_TO_MBEDTLS_ERR' 331 | ret = PSA_PK_RSA_TO_MBEDTLS_ERR(status); | ^~~~~~~~~~~~~~~~~~~~~~~~~ /home/guest/ncs/v2.7.0/modules/crypto/mbedtls/library/pk_internal.h:29:67: note: each undeclared identifier is reported only once for each function it appears in 29 | psa_to_pk_rsa_errors, \ | ^~~~~~~~~~~~~~~~~~~~ /home/guest/ncs/v2.7.0/modules/crypto/oberon-psa-crypto/library/psa_util_internal.h:103:35: note: in definition of macro 'PSA_TO_MBEDTLS_ERR_LIST' 103 | psa_status_to_mbedtls(status, error_list, \ | ^~~~~~~~~~ /home/guest/ncs/v2.7.0/modules/crypto/mbedtls/library/pk_wrap.c:331:15: note: in expansion of macro 'PSA_PK_RSA_TO_MBEDTLS_ERR' 331 | ret = PSA_PK_RSA_TO_MBEDTLS_ERR(status); | ^~~~~~~~~~~~~~~~~~~~~~~~~ [108/960] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/home/guest/ncs/v2.7.0/modules/crypto/mbedtls/library/rsa.c.obj ninja: build stopped: subcommand failed. FATAL ERROR: command exited with status 1: /home/guest/ncs/toolchains/e9dba88316/usr/local/bin/cmake --build /home/guest/Documents/Codes/mx-ng/build
So, another question is can we build the project for secure board configuration (nrf7002dk_nrf5340_cpuapp) when MbedTLS is enabled ?
In short what i want to ask is that can these two functionalities work together or not ?
Thank you.
