how to get a correct flash partition id ?
SDK : NCS v2.8.0
SoC : nRF52840
HW : custom board
I was trying to use settings subsystem, and I managed to make setting_write() and settings_read() work. Now, I am trying to clear a settings with following code, but have gotten errors:
void settings_clear() {
  const struct flash_area *fa;
  int err;
  err = flash_area_open(DT_NODELABEL(settings_partition), &fa);
  if (err) {
      printk("Failed to open settings storage: %d\n", err);
      return;
  err = flash_area_erase(fa, 0, fa->fa_size);
  if (err) {
      printk("Failed to erase settings storage: %d\n", err);
  } else {
      printk("Settings storage erased!\n");
  flash_area_close(fa);
When I tried this code, I got following errors:
D:/ncs/xcam5/build/xcam5/zephyr/include/generated/zephyr/devicetree_generated.h:10178:43: error: 'DT_N_S_soc_S_flash_controller_4001e000_S_flash_0_S_partitions_S_partition_f8000' undeclared (first use in this function); did you mean 'DT_N_S_soc_S_flash_controller_4001e000_S_flash_0_S_partitions_S_partition_f8000_ORD'?
10178 | #define DT_N_NODELABEL_settings_partition DT_N_S_soc_S_flash_controller_4001e000_S_flash_0_S_partitions_S_partition_f8000
D:/ncs/xcam5/build/xcam5/zephyr/include/generated/zephyr/devicetree_generated.h:10178:43: note: in definition of macro 'DT_N_NODELABEL_settings_partition'
C:/DevTools/nRF/ncs/v2.8.0/zephyr/include/zephyr/devicetree.h:200:29: note: in expansion of macro 'DT_CAT'
200 | #define DT_NODELABEL(label) DT_CAT(DT_N_NODELABEL_, label)
D:/ncs/xcam5/src/main.c:168:31: note: in expansion of macro 'DT_NODELABEL'
168 | err = flash_area_open(DT_NODELABEL(settings_partition), &fa);
My board.dts file:
&flash0 {
  partitions {
  #address-cells = <1>;
  #size-cells = <1>;
  boot_partition: partition@0 {
    label = "mcuboot";
    reg = <0x00000000 DT_SIZE_K(48)>;
  slot0_partition: partition@c000 {
    label = "image-0";
    reg = <0x0000c000 DT_SIZE_K(472)>;
  slot1_partition: partition@82000 {
    label = "image-1";
    reg = <0x00082000 DT_SIZE_K(472)>;
  settings_partition: partition@f8000 {
    label = "settings";
    reg = <0x000F8000 DT_SIZE_K(16)>;
  storage_partition: partition@fc000 {
    label = "storage";
    reg = <0x000FC000 DT_SIZE_K(16)>;
my proj.conf file has:
CONFIG_SETTINGS=y
CONFIG_SETTINGS_NVS=y
CONFIG_NVS=y
CONFIG_FLASH_MAP=y
Question:
How can I get the correct "settings_partition" ID, which is to be used in flash_area_open() function?
Robin
