Issues when powering thingy:91 from solar panel
Hi!
I am trying to power the thingy:91 from solar panels and have some issues with the thingy:91 restarting when the solar panel receives a medium amount of light. The solar panel charges the device properly in full sun and does not interfere with the device when there is no sun. However, it starts rebooting when there is some light. I assume that this is because the USB solar panel outputs a voltage lower than 5V, but high enough that the regulators turn on so that the nrf9160 is supplied with too low voltage. I have tried with multiple USB-solar panels which most often are used to charge surveillance cameras.
Do you have any tips on how to run the thingy:91 from a USB solar panel properly?
Jonathan
Parents Reply
  • I have been testing with several solar panels and looking at voltages today. It seems like the beginning of the problem is that when the Thingy begins doing something that draws more power (like connecting to cell network), the input voltage (VBUS)  from the solar panel which is running at 5 volts, can dip below 4.4 volts.I'm just using a meter on TP12 to watch this.
    With the scope I see that Test points 3V3 and 1V8 and Li-Po and nRF52 are stable. nRF91 is bouncing around as the current draw does.
    Since we only have high power draw a few moments per hour, is there a way we can disable the power charging before we do the cell transfers. It seems like this is the only time it is a problem.
    Rich
    p.s. - I am testing this using a 250W heat lamp aimed at the solar panel. That give me a lot of control. Everything works great when the panel is near the lamp or completely dark. Failure is when the panel voltage drops to about 4.7 volts and then drops further when cell is enabled.
