Send the packet from peripheral to central, why see the current pulse about 1000ms later
ncs v2.9.0
peripheral_uart (nRF52840) modified code
central_uart (nRF52832) unmodified code
using power monitor for current consumption
When I send the packet from peripheral to central, except empty PDU packet, I also see the current pulse in the power monitor screenshot about 1000ms later, how to explain it?
pulse 1 and 4 are empty PDU, pulse 2 is sending the packet from peripheral, and pulse 3 is unknown current pulse.
zoom in for pulse 2
zoom in for pulse 3, seem has 3 spikes.
From the wireshark I see the data packet only except empty PDU.
    I am not sure exactly how you measure this other than looking at the current draw, but looking at the sniffer trace it seems the connection interval is about 1.8 seconds, so I would seg a high latency is expected here. If you need a short(er) latency, you need to reduce the connection interval.
    1) The long connection interval is clear to identify the TX and unknown current pulses, otherwise they may overlay with empty PDU current pulses. Using the shorter connection interval parameters still have unknown current pulse 1000ms later. The settings are as the following,
    CONFIG_BT_PERIPHERAL_PREF_LATENCY=0
    CONFIG_BT_PERIPHERAL_PREF_TIMEOUT=400
    CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=y
    2) Is there a simpler sample than peripheral_uart and central_uart to just send the packet periodically, I can check if it has unexpected current pulse or not.
    I am not sure I understand how to read the latency from these current measuremetns. Can you elaborate mor on how you test? At which points in the code do you consider the data sent and received, and can you toggle GPIO's on those and meaure with a logic analyze or similar?
    The central /periphearl UART (NUS) samples are probably the simpest samples for exchagning data in a connection.
