NRF5340 - PRE KERNEL1 timer
I'm trying to implement a PRE_KERNEL1 timer (with top priority 0) to toggle an LED.
I’m able to control the LED using registers, and now I want to add a timer layer.
I've tried using both registers and NRFX for this task. Both solutions compiled and flashed successfully, but they don’t seem to do anything. :(
In the NRFX solution, it looks like the program gets stuck during timer initialization (code below).
What do you think might be the issue?
// Base addresses - NRF5340
#define TIMER1_BASE 0x50010000UL
#define CLOCK_BASE 0x50005000UL
#define OSC_BASE 0x50004000UL
#define NRF_P0_BASE 0x50842500UL
// LED definitions
#define NRF_GPIO_DIRSET (*(volatile uint32_t *)(NRF_P0_BASE + 0x018))
#define NRF_GPIO_DIRCLR (*(volatile uint32_t *)(NRF_P0_BASE + 0x01C))
#define NRF_GPIO_OUTSET (*(volatile uint32_t *)(NRF_P0_BASE + 0x008))
#define NRF_GPIO_OUTCLR (*(volatile uint32_t *)(NRF_P0_BASE + 0x00C))
#define NRF_GPIO_IN (*(volatile uint32_t *)(NRF_P0_BASE + 0x010))
#define NRF_GPIO_PIN_CNF(PIN) (*(volatile uint32_t *)(NRF_P0_BASE + 0x700 + PIN * 4))
#define PIN_LED 3 // P0.03
// Timer registers (offsets from TIMER1_BASE)
#define TIMER_TASKS_START (*(volatile uint32_t *)(TIMER1_BASE + 0x000))
#define TIMER_TASKS_STOP (*(volatile uint32_t *)(TIMER1_BASE + 0x004))
#define TIMER_TASKS_CLEAR (*(volatile uint32_t *)(TIMER1_BASE + 0x008))
#define TIMER_TASKS_CAPTURE0 (*(volatile uint32_t *)(TIMER1_BASE + 0x018))
#define TIMER_TASKS_CAPTURE1 (*(volatile uint32_t *)(TIMER1_BASE + 0x01C))
#define TIMER_EVENTS_COMPARE0 (*(volatile uint32_t *)(TIMER1_BASE + 0x140))
#define TIMER_EVENTS_COMPARE1 (*(volatile uint32_t *)(TIMER1_BASE + 0x144))
#define TIMER_SHORTS (*(volatile uint32_t *)(TIMER1_BASE + 0x200))
#define TIMER_INTENSET (*(volatile uint32_t *)(TIMER1_BASE + 0x304))
#define TIMER_INTENCLR (*(volatile uint32_t *)(TIMER1_BASE + 0x308))
#define TIMER_MODE (*(volatile uint32_t *)(TIMER1_BASE + 0x504))
#define TIMER_BITMODE (*(volatile uint32_t *)(TIMER1_BASE + 0x508))
#define TIMER_PRESCALER (*(volatile uint32_t *)(TIMER1_BASE + 0x510))
#define TIMER_CC0 (*(volatile uint32_t *)(TIMER1_BASE + 0x514))
#define TIMER_CC1 (*(volatile uint32_t *)(TIMER1_BASE + 0x518))
// Clock registers (offsets from CLOCK_BASE)
#define CLOCK_TASKS_HFCLKSTART (*(volatile uint32_t *)(CLOCK_BASE + 0x000))
#define CLOCK_HFCLKSTAT (*(volatile uint32_t *)(CLOCK_BASE + 0x40C))
// NVIC_BASE comes from <core_cm33.h>
#define NVIC_ISER0 (*(volatile uint32_t *)(NVIC_BASE + 0x000)) // Interrupt Set Enable Register 0
#define NVIC_ICER0 (*(volatile uint32_t *)(NVIC_BASE + 0x080)) // Interrupt Clear Enable Register 0
#define NVIC_IPR0 (*(volatile uint8_t *)(NVIC_BASE + 0x400))   // Interrupt Priority Register 0 (byte access)
#define SCB_SCR (*(volatile uint32_t *)(SCB_BASE + 0x010)) // System Control Register
//////// Register test /////// - please run just one at the time
// Interrupt handler for TIMER1
void TIMER1_IRQHandler(void)
    static bool led_status = false;
    NRF_GPIO_OUTSET = (1 << PIN_LED);
    // Check if COMPARE0 event caused the interrupt
    if (TIMER_EVENTS_COMPARE0)
        // Clear the event
        TIMER_EVENTS_COMPARE0 = 0;
        // Toggle the LED
        led_status = !led_status;
        if (led_status)
            NRF_GPIO_OUTCLR = (1 << PIN_LED);
void timer_init()
    // Start high-frequency clock (if not already running)
    CLOCK_TASKS_HFCLKSTART = 1;
    while (!(CLOCK_HFCLKSTAT & 1))
        ; // Wait for HFCLK to start
    // NRF_GPIO_OUTSET = (1 << PIN_LED); // for testing, can be removed
    // Configure Timer
    TIMER_TASKS_STOP = 1;  // Ensure timer is stopped before configuring
    TIMER_TASKS_CLEAR = 1; // Clear timer
    TIMER_MODE = 0x00;      // Timer mode
    TIMER_BITMODE = 0x02;   // 32-bit timer
    TIMER_PRESCALER = 0x04; // Prescaler.  32MHz / (2^4) = 2MHz timer clock.  Each tick is 0.5 us.
    TIMER_CC0 = 2000000;    // Compare value for 1 second (2MHz * 1 second = 2000000)
    // Enable shortcut to clear timer on COMPARE0 event
    TIMER_SHORTS = (1 << 0);
    // Enable interrupt on COMPARE0 event
    TIMER_INTENSET = (1 << 16);
    NVIC_IPR0 |= (0x40 << (17 % 8) * 8); // Set priority to 0x40 (adjust as needed)
    // Enable TIMER1 interrupt in NVIC
    NVIC_ISER0 = (1 << 17); // Enable interrupt number 17 (TIMER1)
    TIMER_TASKS_START = 1;  // Start timer
/////// NRFX Test //////// - please run just one at the time
#define TIMER_INSTANCE_ID 1
static const nrfx_timer_t TIMER_INSTANCE = NRFX_TIMER_INSTANCE(TIMER_INSTANCE_ID);
#define TIMER_IRQ_NUM TIMER1_IRQn     // IRQ number for TIMER1
#define TIMER_CC_VALUE (16000000 * 5) // 5 seconds (16 MHz clock)
void timer_event_handler(nrf_timer_event_t event_type, void *context)
    if (led_status)
    // Reset the timer
    nrfx_timer_clear(&TIMER_INSTANCE);
void timer_init()
    // Timer configuration structure
    nrfx_timer_config_t timer_cfg = NRFX_TIMER_DEFAULT_CONFIG(NRF_TIMER_FREQ_16MHz);
    timer_cfg.frequency = NRF_TIMER_FREQ_16MHz;
    timer_cfg.mode = NRF_TIMER_MODE_TIMER;
    timer_cfg.interrupt_priority = 1;
    // Initialize Timer
    nrfx_timer_init(&TIMER_INSTANCE, &timer_cfg, timer_event_handler);
	// The next 2 lines are led testing - if we reach this point.
	// It looks like we stuck here, because the led is not turned on,
	// but it doest turn on if i place it before 'nrfx_timer_init' line
	NRF_GPIO_OUTSET = (1UL << PIN_LED); // for testing, should be removed
    return; // for testing, should be removed
    // Set CC0 for 5-second interval
    nrfx_timer_extended_compare(&TIMER_INSTANCE,
                                NRF_TIMER_CC_CHANNEL0,
                                TIMER_CC_VALUE,
                                NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
                                true);
    // Enable Timer Interrupt
    NVIC_ClearPendingIRQ(TIMER_IRQ_NUM);
    NVIC_EnableIRQ(TIMER_IRQ_NUM);
    // Start Timer
    nrfx_timer_enable(&TIMER_INSTANCE);
///// Register function to run before kernel 1 - MCUBOOT ///// - This should run all the time
static int gpio_early_read_write(void)
    // Set LED gpio as output
    NRF_GPIO_DIRSET = (1UL << PIN_LED);
    NRF_GPIO_OUTCLR = (1UL << PIN_LED);
	// LED Test to see if the system powered
    for (volatile int i = 0; i < 1000000; i++){};
    timer_init();
	// Wait for timer
    for (;;){};
    return 0;
SYS_INIT(gpio_early_read_write, PRE_KERNEL_1, 0);
  • Pin configs are set much later in startup process, you have to set up the PIN_CNF register manually. GPIO pins have the output disabled at reset.
    You should look up how to use a device tree overlay to set port/pin number instead of using a hard coded magic number.
  • Hi and thanks!
    i got you about magic numbers, absolutely should be taken from device tree.
    anyways, the led gpio actually works, i can make it turn on and off.
    I want to toggle it from timer isr, but i couldnt make it work, i configure the timer but nothing happens.
    the thing is that i want it to work pure hardware, before the OS starts.
    maybe i missed some basic stuff, thanks for your reply!
  • You might also have wrong magic numbers in your own register definitions. Checking would trigger my hourly rates - I am NOT a nordic employee.
    Use the compiler macros from the NRF connect SDK. NRF_P0 should be available once you
    #include <zephyr/kernel.h>
    EDIT: I am a bit blind. Your interrupt handler function TIMER1_IRQHandler is not connected to the interrupt stuff yet. You would need the IRQ_CONNECT macro in order to do that.
    Try putting a debug break point into that handler function in order to check.
    You should have gotten an unhandled interrupt exception unless the timer1 is enabled in the dts - which means it has an interrupt handler function already.
    The registers took from nrf5340 datasheet, and the gpio works, so it should be fine.
    I saw there is a macro to register "TIMER1_IRQHandler" as a week function, so it looks like it just need to be implemented, anyways, with nrfx- i register "timer_event_handler" to this timer.
    and i tried to use "IRQ_CONNECT" and enabled macro but nothing.
    at the end i managed to run something with nrfx but just after pre_kernel1, which is too late so i need to use the bare metal registers to run it before any kernel or OS.
    for some reason, the mcuboot takes ~1sec to boot Disappointed
  • Hi Yo,
    MCUBoot taking 1s sounds a bit strange. Could you check if you see the same issue with a simple sample in the SDK ?
    How large is your application ? Boot validation can take a long time on a larger application.
    You can try to turn off CONFIG_BOOT_VALIDATE_SLOT0=n to see if the boot time is reduced. See here: Boot up time of NCS application
    Another option is to have something running before MCUBoot. Check here:  RE: Modify the MCUboot's booting process
