nrf desktop in ncs SDK cant work when onnect to cmac os
When I was developing a keyboard using the nRF52840 with the NCS SDK, I found that the keyboard couldn't type on macOS when connected via USB or BLE. However, it worked perfectly on Windows and Android. I tried modifying the CONFIG_DESKTOP_DEVICE_VID and CONFIG_DESKTOP_DEVICE_PID to Apple's IDs, but it still didn't work. Could you help me solve this problem?
  • Usage Page (Generic Desktop) 05 01
    Usage (Keyboard) 09 06
    Collection (Application) A1 01
        Report ID (2) 85 02
        Usage Page (Keyboard/Keypad) 05 07
        Usage Minimum (Keyboard Left Control) 19 E0
        Usage Maximum (Keyboard Right GUI) 29 E7
        Logical Minimum (0) 15 00
        Logical Maximum (1) 25 01
        Report Size (1) 75 01
        Report Count (8) 95 08
        Input (Data,Var,Abs,NWrp,Lin,Pref,NNul,Bit) 81 02
        Report Size (8) 75 08
        Report Count (1) 95 01
        Input (Cnst,Ary,Abs) 81 01
        Usage Minimum (Undefined) 19 00
        Usage Maximum (Keypad =) 29 67
        Report Count (104) 95 68
        Input (Data,Ary,Abs) 81 00
        Report ID (5) 85 05
        Usage Page (LEDs) 05 08
        Usage Minimum (Num Lock) 19 01
        Usage Maximum (Kana) 29 05
        Report Count (5) 95 05
        Output (Data,Var,Abs,NWrp,Lin,Pref,NNul,NVol,Bit) 91 02
        Report Size (3) 75 03
        Output (Cnst,Ary,Abs,NWrp,Lin,Pref,NNul,NVol,Bit) 91 01
        Report ID (6) 85 06
        Usage Page (Vendor-Defined 1) 06 00 FF
        Usage (Vendor-Defined 65281) 0A 01 FF
        Logical Maximum (255) 26 FF 00
        Report Count (62) 95 3E
        Feature (Data,Var,Abs,NWrp,Lin,Pref,NNul,NVol,Bit) B1 02
    End Collection C0
    Usage (System Control) 09 80
        Report ID (3) 85 03
        Logical Maximum (1023) 26 FF 03
        Usage Maximum 2A FF 03
        Report Size (16) 75 10
    End Collection C0
    Usage Page (Consumer Devices) 05 0C
    Usage (Consumer Control) 09 01
        Report ID (4) 85 04
    End Collection C0
    i modify the report desc.this is my report desc,and my keyboard can work in windowns well.
  • Configuration Descriptor 1
    Offset Field Size Value Description
    0 bLength 1 09h
    1 bDescriptorType 1 02h Configuration
    2 wTotalLength 2 0096h
    4 bNumInterfaces 1 05h
    5 bConfigurationValue 1 01h
    6 iConfiguration 1 04h "Default configuration"
    7 bmAttributes 1 E0h Self Powered, Remote Wakeup
    4..0: Reserved ...00000
    5: Remote Wakeup ..1.....  Yes
    6: Self Powered .1......  Yes
    7: Reserved (set to one)
    (bus-powered for 1.0)
    1.......
    8 bMaxPower 1 FAh 500 mA
    Interface Descriptor 0/0 HID, 1 Endpoint
    0 bLength 1 09h
    1 bDescriptorType 1 04h Interface
    2 bInterfaceNumber 1 00h
    3 bAlternateSetting 1 00h
    4 bNumEndpoints 1 01h
    5 bInterfaceClass 1 03h HID
    6 bInterfaceSubClass 1 01h Boot Interface
    7 bInterfaceProtocol 1 01h Keyboard
    8 iInterface 1 00h
    HID Descriptor
    0 bLength 1 09h
    1 bDescriptorType 1 21h HID
    2 bcdHID 2 0111h 1.11
    4 bCountryCode 1 00h
    5 bNumDescriptors 1 01h
    6 bDescriptorType 1 22h Report
    7 wDescriptorLength 2 003Fh 63 bytes
    Endpoint Descriptor 81 1 In, Interrupt, 1 ms
    0 bLength 1 07h
    1 bDescriptorType 1 05h Endpoint
    2 bEndpointAddress 1 81h 1 In
    3 bmAttributes 1 03h Interrupt
    1..0: Transfer Type ......11  Interrupt
    7..2: Reserved 000000..
    4 wMaxPacketSize 2 0040h 64 bytes
    6 bInterval 1 01h 1 ms
    Interface Descriptor 1/0 HID, 1 Endpoint
    0 bLength 1 09h
    2 bInterfaceNumber 1 01h
    8 iInterface 1 00h
    HID Descriptor
    0 bLength 1 09h
    7 wDescriptorLength 2 0030h 48 bytes
    Endpoint Descriptor 82 2 In, Interrupt, 1 ms
    0 bLength 1 07h
    2 bEndpointAddress 1 82h 2 In
    Interface Descriptor 2/0 HID, 1 Endpoint
    0 bLength 1 09h
    2 bInterfaceNumber 1 02h
    7 bInterfaceProtocol 1 00h
    8 iInterface 1 00h
    HID Descriptor
    0 bLength 1 09h
    7 wDescriptorLength 2 0022h 34 bytes
    Endpoint Descriptor 83 3 In, Interrupt, 1 ms
    0 bLength 1 07h
    2 bEndpointAddress 1 83h 3 In
    Interface Association Descriptor Abstract Control Model
    0 bLength 1 08h
    1 bDescriptorType 1 0Bh Interface Association
    2 bFirstInterface 1 03h
    3 bInterfaceCount 1 02h
    4 bFunctionClass 1 02h CDC Control
    5 bFunctionSubClass 1 02h Abstract Control Model
    6 bFunctionProtocol 1 01h AT Commands: V.250 etc
    7 iFunction 1 00h
    Interface Descriptor 3/0 CDC Control, 1 Endpoint
    0 bLength 1 09h
    2 bInterfaceNumber 1 03h
    5 bInterfaceClass 1 02h CDC Control
    6 bInterfaceSubClass 1 02h Abstract Control Model
    7 bInterfaceProtocol 1 01h AT Commands: V.250 etc
    8 iInterface 1 00h
    Header Functional Descriptor
    0 bFunctionLength 1 05h
    1 bDescriptorType 1 24h CS Interface
    2 bDescriptorSubtype 1 00h Header
    3 bcdCDC 2 0110h 1.10
    Call Management Functional Descriptor
    2 bDescriptorSubtype 1 01h Call Management
    3 bmCapabilities 1 03h
    1: Data Ifc Usage ......1.  Call management over Data Ifc
    0: Call Management .......1  Handles call management itself
    4 bDataInterface 1 04h
    Abstract Control Management Functional Descriptor
    0 bFunctionLength 1 04h
    2 bDescriptorSubtype 1 02h Abstract Control Management
    3 bmCapabilities 1 02h
    7..4: Reserved 0000....
    3: Connection ....0...
    2: Send Break .....0..
    1: Line Coding ......1.  Line Coding requests and Serial State notification supported
    0: Comm Features .......0
    Union Functional Descriptor
    2 bDescriptorSubtype 1 06h Union
    3 bControlInterface 1 03h
    4 bSubordinateInterface0 1 04h CDC Data
    Endpoint Descriptor 84 4 In, Interrupt, 16 ms
    0 bLength 1 07h
    2 bEndpointAddress 1 84h 4 In
    6 bInterval 1 10h 16 ms
    Interface Descriptor 4/0 CDC Data, 2 Endpoints
    0 bLength 1 09h
    2 bInterfaceNumber 1 04h
    4 bNumEndpoints 1 02h
    5 bInterfaceClass 1 0Ah CDC Data
    6 bInterfaceSubClass 1 00h
    8 iInterface 1 00h
    Endpoint Descriptor 85 5 In, Bulk, 64 bytes
    0 bLength 1 07h
    2 bEndpointAddress 1 85h 5 In
    3 bmAttributes 1 02h Bulk
    1..0: Transfer Type ......10  Bulk
    6 bInterval 1 00h
    Endpoint Descriptor 01 1 Out, Bulk, 64 bytes
    0 bLength 1 07h
    2 bEndpointAddress 1 01h 1 Out
    6 bInterval 1 00h
    Interface 0 HID Report Descriptor Keyboard
    Item Tag (Value) Raw Data
        Input (Cnst,Var,Abs,NWrp,Lin,Pref,NNul,Bit) 81 03
        Output (Cnst,Var,Abs,NWrp,Lin,Pref,NNul,NVol,Bit) 91 03
        Report Count (224) 95 E0
        Usage Maximum (Undefined) 29 DF
    End Collection C0
    Interface 1 HID Report Descriptor Consumer Control
        Report ID (2) 85 02
        Usage Minimum (Consumer Control) 19 01
        Usage Maximum 2A FF 02
        Logical Maximum (668) 26 9C 02
        Report Count (2) 95 02
    End Collection C0
        Report ID (3) 85 03
        Usage Minimum (System Power Down) 19 81
        Usage Maximum 29 B8
        Report Count (56) 95 38
    End Collection C0
    Interface 2 HID Report Descriptor Vendor-Defined 1
    Usage (Vendor-Defined 1) 09 01
        Report Count (64) 95 40
        Usage (Vendor-Defined 2) 09 02
    End Collection C0
    and this is the desc i modify in nrf5 sdk.it can work in mac os well.
    Could you share your entire project code here? (along with any modifications that you have made)
    -Priyanka
