CMake Error at C:/ncs/v2.9.0/zephyr/cmake/modules/boards.cmake:196 (message): Error finding board: nrf52833dk
Hi guys, I am using the SDK v2.9.0 and the toolchains b620d30767. To add the build configuration for the sample peripheral_uart, the console print some error log.The log as below:
uilding peripheral_uart
Loading Zephyr module(s) (Zephyr base): sysbuild_default
-- Found Python3: C:/ncs/toolchains/b620d30767/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.8") found components: Interpreter
-- Cache files will be written to: C:/ncs/v2.9.0/zephyr/.cache
Error message: Traceback (most recent call last):
File "C:\ncs\v2.9.0\zephyr\scripts\list_boards.py", line 469, in <module>
dump_v2_boards(args)
File "C:\ncs\v2.9.0\zephyr\scripts\list_boards.py", line 416, in dump_v2_boards
boards = find_v2_boards(args)
File "C:\ncs\v2.9.0\zephyr\scripts\list_boards.py", line 341, in find_v2_boards
b, e = load_v2_boards(args.board, board_yml, systems)
File "C:\ncs\v2.9.0\zephyr\scripts\list_boards.py", line 230, in load_v2_boards
b = yaml.load(f.read(), Loader=SafeLoader)
UnicodeDecodeError: 'gbk' codec can't decode byte 0xa2 in position 46:
illegal multibyte sequence
cmake/modules/sysbuild_default.cmake:15 (include)
C:/ncs/v2.9.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
C:/ncs/v2.9.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
C:/ncs/v2.9.0/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
template/CMakeLists.txt:10 (find_package)
See also "C:/ncs/v2.9.0/nrf/samples/bluetooth/peripheral_uart/build_6/CMakeFiles/CMakeOutput.log".
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\b620d30767\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/toolchains/b620d30767/opt/bin/python.exe '-Bc:\ncs\v2.9.0\nrf\samples\bluetooth\peripheral_uart\build_6' -GNinja -DBOARD=nrf52833dk/nrf52820 -DNCS_TOOLCHAIN_VERSION=NONE '-SC:\ncs\v2.9.0\zephyr\share\sysbuild' '-DAPP_DIR:PATH=c:\ncs\v2.9.0\nrf\samples\bluetooth\peripheral_uart'
* The terminal process terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it.
Could you help me to fix it? thank you!the window
