I wanted to reach out about the issue I've been running into regarding the UART Async API. I am having trouble narrowing down what the cause could be.
I am using an nRF9161 DK and the v2.9 SDK. The communication below is using UART2.
Right now I have the 9161 connected to an external device (pin pad / card reader). I can successfully send data over the TX line and receive data over the RX line, but there are times when when no data comes back over the RX line. Specifically when a card is presented rather than a key pressed.
TX timeout - SYS_FOREVER_MS
RX timeout - 16000 micro seconds (I have tried ranges from 2000 to 16000)
The sequence of events is as follows:
A button on the pin pad is pressed.
The 9161 is triggered via an interrupt pin.
An ISR puts a operation into the work queue.
UART ASYNC API is called to enable TX pin (uart_tx).
Jack
