periodic_sync_rsp error code pawr
I am trying to experiment the PaWR using the sample projects in NCS.
I flashed periodic_adv_rsp example in nRF52840DK and periodic_sync_rsp in nrf52832 DK. I can see proper debug messages for example periodic_adv_rsp but I get error message for periodic_sync_rsp example on bootup on nRF52832DK. Could you please have a look into the below logs and let me know what's happening ?
*** Booting nRF Connect SDK v2.7.0-rc3-cb7b6efdf17a ***
*** Using Zephyr OS v3.6.99-3e80418dd59f ***
Starting Periodic Advertising with Responses Synchronization Demo
[00:00:05.404,479] <inf> bt_sdc_hci_driver: SoftDevice Controller build revision:
                                            d6 da c7 ae 08 db 72 6f  2a a3 26 49 2a 4d a8 b3 |......ro *.&I*M..
                                            98 0e 07 7f                                      |....
[00:00:05.407,531] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:00:05.407,562] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
[00:00:05.407,592] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 214.51162 Build 1926957230
[00:00:05.408,569] <inf> bt_hci_core: Identity: F5:77:91:DE:B5:65 (random)
[00:00:05.408,599] <inf> bt_hci_core: HCI: version 5.4 (0x0d) revision 0x11fb, manufacturer 0x0059
[00:00:05.408,630] <inf> bt_hci_core: LMP: version 5.4 (0x0d) subver 0x11fb
Waiting for periodic sync...
Timed out while synchronizing
[00:00:25.410,583] <wrn> bt_hci_core: opcode 0x2036 status 0x0c
Advertising failed to start (err -13)
  • Hello DanisXZ,
    Welcome to the world of BLE PAwR!
    Perhaps the error handling/reporting can be improved in the `periodic_sync_rsp` example a bit. But I think that the devicies will have a higher chance to synchronize if you load the firmware `periodic_adv_rsp` on the other board instead of `periodic_adv`. Give it a try and write again here after you have tested. Good luck!
    The log message indicates that the PAwR Synchronization device did not find any PAwR Advertiser to synchronize to. Please note that in order for the samples to work as intended, those two samples are the ones to pair up. While there are samples for other types of periodic advertising (without responses), those are note expected to work with the periodic advertising with responses samples.
    Terje
  • Hi   and  ,
    Thank you for your replies. Sorry, that was a typo in my post - I actually flashed periodic_adv_rsp and not periodic_adv. I have now updated my post.
    On the advertising side, the output is as shown below:
    Starting Periodic Advertising Demo
    [00:00:01.449,798] <inf> bt_sdc_hci_driver: SoftDevice Controller build revision:
                                                98 0e 07 7f                                      |....
    [00:00:01.452,667] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
    [00:00:01.452,697] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
    [00:00:01.452,728] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 214.51162 Build 1926957230
    [00:00:01.453,674] <inf> bt_hci_core: Identity: C4:C1:82:92:F3:CA (random)
    [00:00:01.453,704] <inf> bt_hci_core: HCI: version 5.4 (0x0d) revision 0x11fb, manufacturer 0x0059
    [00:00:01.453,735] <inf> bt_hci_core: LMP: version 5.4 (0x0d) subver 0x11fb
    Start Periodic Advertising
    Scanning successfully started
    Subevent data set 3
    Subevent data set 5
    Subevent data set 8
    Subevent data set 10
    Subevent data set 13
    Subevent data set 15
    Subevent data set 18
    I am using the examples as it is, I have not edited anything
  • I see. Confusing indeed. Then I would suggest you to upgrade from nRF Connect SDK 2.7.0 rc3 to 2.9.0. A lot of updates have been introduced since the summer.
  • Updated, still the same
    *** Booting nRF Connect SDK v2.9.0-7787b2649840 ***
    *** Using Zephyr OS v3.7.99-1f8f3dc29142 ***
    [00:00:01.919,250] <inf> bt_sdc_hci_driver: SoftDevice Controller build revision:
                                                2d 79 a1 c8 6a 40 b7 3c  f6 74 f9 0b 22 d3 c4 80 |-y..j@.< .t.."...
                                                74 72 82 ba                                      |tr..
    [00:00:01.922,058] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
    [00:00:01.922,058] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
    [00:00:01.922,088] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 45.41337 Build 3074452168
    [00:00:01.923,126] <inf> bt_hci_core: Identity: C4:C1:82:92:F3:CA (random)
    [00:00:01.923,156] <inf> bt_hci_core: HCI: version 6.0 (0x0e) revision 0x106b, manufacturer 0x0059
    [00:00:01.923,187] <inf> bt_hci_core: LMP: version 6.0 (0x0e) subver 0x106b
    [00:00:21.925,292] <wrn> bt_hci_core: opcode 0x2036 status 0x0c
    [00:00:11.572,509] <inf> bt_sdc_hci_driver: SoftDevice Controller build revision:
                                                74 72 82 ba                                      |tr..
    [00:00:11.575,347] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
    [00:00:11.575,378] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
    [00:00:11.575,408] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 45.41337 Build 3074452168
    [00:00:11.576,446] <inf> bt_hci_core: Identity: F5:77:91:DE:B5:65 (random)
    [00:00:11.576,477] <inf> bt_hci_core: HCI: version 6.0 (0x0e) revision 0x106b, manufacturer 0x0059
    [00:00:11.576,507] <inf> bt_hci_core: LMP: version 6.0 (0x0e) subver 0x106b
    Subevent data set 3
    Subevent data set 5
    Subevent data set 8
