How to get Bluetooth Bootloader up and running??
I am having BIG problems getting the Bluetooth Dual Bank Bootloader sample to work!
I am using Keil 5.18 and using SDK version 9.0.0 and also tried 10.0.0. I have S310 working together with a application using both ANT+ and BT. No problems what soever...
But now I want to add a bootloader functionality so that I can update the firmware remotely if I need to.
I use the following recipee:
  • First I clear the CPU using nRFStudio
  • Then I install Softdevice S310 v3.0.0 in the device (116KB)
  • I use the sample BLE_DFU_DUALBANK_S310 (not sure this is the exact name :))
  • From either V9 or V10 SDK
  • Build the project (which takes 3 compile iterations optimizing for size)
  • I have then tried installing the bootloader 2 ways.
  • One way is just clicking upload in Keil which uses jrfprog
  • Second way is using nRFStudio and install the bootloader here by using the .hex file
I reset the board and then use "NRF Toolbox" on my Android Phone to try and search for the device. But it never comes up.
Actually I think it crashes becuase I cant even lit a LED....
I am pretty stuck here. I cant seem to be able to single step the bootloader for some reason. This way I could possible identify what is going wrong...
Please help
