I am working on an nRF52-based device using nRF Connect SDK (NCS) version 2.7.0. The device is configured to enter deep sleep every 60 seconds and wake up via a GPIO interrupt. However, after 2-3 hours of operation, the device stops waking up from deep sleep using the GPIO pin. But works fine before 2-3 hours.
The device works as expected for the first 2-3 hours, waking up from deep sleep every 60 seconds using the GPIO interrupt.
After 2-3 hours, the device no longer wakes up from deep sleep, even though the GPIO signal is still active.
The device does not reset or crash; it simply remains in deep sleep.
void setup_pins_wakeup_source(void)
gpio_pin_configure_dt(&button0, GPIO_INPUT);
gpio_pin_configure_dt(&button1, GPIO_INPUT);
gpio_pin_configure_dt(&button2, GPIO_INPUT);
gpio_pin_configure_dt(&button3, GPIO_INPUT);
gpio_pin_configure_dt(&button4, GPIO_INPUT);
// Enable button interrupts
gpio_pin_interrupt_configure(button0.port, button0.pin, GPIO_INT_LEVEL_INACTIVE);
gpio_pin_interrupt_configure(button1.port, button1.pin, GPIO_INT_LEVEL_INACTIVE);
gpio_pin_interrupt_configure(button2.port, button2.pin, GPIO_INT_LEVEL_INACTIVE);
gpio_pin_interrupt_configure(button3.port, button3.pin, GPIO_INT_LEVEL_INACTIVE);
gpio_pin_interrupt_configure(button4.port, button4.pin, GPIO_INT_LEVEL_INACTIVE);
void enter_deep_sleep_mode(void)
LOG_INF("enter_deep_sleep_mode");
setup_pins_wakeup_source();
// enter deep sleep mode to save power
sys_poweroff();
