I am facing an issue while integrating BLE with the rest of my code. The code crashes when I try to start BLE outside of main().
Currently, I have placed the BLE initialization at the beginning of main(), and it starts and advertises successfully. However, the code crashes during the bonding process.
- I am using two threads in my application.
I am using nrf5340, 2.6.1 SDK and 2.6.1 toolchain manager.
This are my configuration.
# Enable the UART driver CONFIG_UART_ASYNC_API=y # CONFIG_NRFX_UARTE0=y # CONFIG_SERIAL=y # Enable GPIO CONFIG_GPIO=y CONFIG_LOG_DEFAULT_LEVEL=4 # Configure printk to use UART console # CONFIG_CONSOLE=y # CONFIG_UART_CONSOLE=y # Configure heap memory CONFIG_HEAP_MEM_POOL_SIZE=8192 # Bluetooth configuration CONFIG_BT=y CONFIG_BT_PERIPHERAL=y CONFIG_BT_DEVICE_NAME="XXXXXXXXXX" CONFIG_BT_MAX_CONN=1 CONFIG_BT_MAX_PAIRED=1 CONFIG_MAIN_STACK_SIZE=8192 CONFIG_BT_RX_STACK_SIZE=4096 # Enable the NUS service CONFIG_BT_NUS=y # Enable bonding and settings CONFIG_BT_SETTINGS=y CONFIG_FLASH=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_FLASH_MAP=y CONFIG_NVS=y CONFIG_SETTINGS=y # Enable DK LED and Buttons library CONFIG_DK_LIBRARY=y # Increase stack sizes CONFIG_MAIN_STACK_SIZE= 12288 CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE= 12288 # Configure logging CONFIG_LOG=y CONFIG_USE_SEGGER_RTT=y CONFIG_LOG_BACKEND_RTT=y CONFIG_LOG_BACKEND_UART=y CONFIG_LOG_PRINTK=y # Enable assertions CONFIG_ASSERT=y # Enable Security Management Protocol CONFIG_BT_SMP=y # Enable filtering accept list and privacy CONFIG_BT_FILTER_ACCEPT_LIST=y CONFIG_BT_PRIVACY=y CONFIG_BT_SMP_ENFORCE_MITM=y CONFIG_BT_SMP_SC_ONLY=y # enabling this because to disable the legacy paring. # Enable NUS service authentication CONFIG_BT_NUS_AUTHEN=y CONFIG_BT_SMP_APP_PAIRING_ACCEPT=y CONFIG_BT_ECC=y # Enable bonding support CONFIG_BT_BONDABLE=y CONFIG_BT_GATT_SERVICE_CHANGED=y CONFIG_BT_L2CAP_TX_MTU=247 CONFIG_BT_BUF_ACL_RX_SIZE=255 CONFIG_BT_BUF_ACL_TX_SIZE=251 CONFIG_BT_DATA_LEN_UPDATE=y # Enable nordic security backend and PSA APIs CONFIG_NRF_SECURITY=y CONFIG_MBEDTLS_PSA_CRYPTO_C=y CONFIG_MBEDTLS_ENABLE_HEAP=y CONFIG_MBEDTLS_HEAP_SIZE= 12288 CONFIG_PSA_WANT_GENERATE_RANDOM=y CONFIG_PSA_WANT_KEY_TYPE_AES=y CONFIG_PSA_WANT_ALG_CBC_NO_PADDING=y CONFIG_PSA_CRYPTO_DRIVER_OBERON=y CONFIG_PSA_CRYPTO_DRIVER_CC3XX=y ########################################### CONFIG_I2C=y CONFIG_THREAD_ANALYZER=y CONFIG_THREAD_ANALYZER_AUTO=y CONFIG_FPU=y CONFIG_FP_HARDABI=y ###################################### # power management.... CONFIG_POWEROFF=y CONFIG_PM=n CONFIG_BT_CTLR_LOW_LAT=n # CONFIG_BT_LL_SOFT=n CONFIG_BT_LL_SW_SPLIT=y CONFIG_CLOCK_CONTROL=y CONFIG_CLOCK_CONTROL_NRF=y # CONFIG_BT_CTLR_CLOCK_CONTROL=y CONFIG_INIT_STACKS=y CONFIG_THREAD_ANALYZER=y CONFIG_THREAD_ANALYZER_AUTO=y CONFIG_FAULT_DUMP=2 # CONFIG_BT_LOG_LEVEL=4
this is BLE start code
int BLE_Start()
int err;
err = bt_enable(NULL);
if (err) {
LOG_ERR("Bluetooth initialization failed (err: %d)", err);
return err;
LOG_INF("Bluetooth initialized");
err = bt_nus_init(&nus_cb);
if (err) {
LOG_ERR("Failed to initialize NUS service (err: %d)", err);
return err;
LOG_INF("NUS service initialized");
bt_conn_cb_register(&connection_callbacks);
bt_conn_auth_cb_register(&conn_auth_callbacks);
bt_conn_auth_info_cb_register(&conn_auth_callbacks_info);
LOG_INF("Bluetooth callbacks registered");
if (IS_ENABLED(CONFIG_SETTINGS)) {
err = settings_load();
if (err) {
LOG_ERR("Settings load failed (err: %d)", err);
return err;
LOG_INF("Settings loaded");
return 0;
Please help me resolve this issue, as I am in the final stage of my project completion!
