nRF5340 DK BLE code crashing while integration.
I am facing an issue while integrating BLE with the rest of my code. The code crashes when I try to start BLE outside of main().
Currently, I have placed the BLE initialization at the beginning of main(), and it starts and advertises successfully. However, the code crashes during the bonding process.
  • I am using two threads in my application.
I am using nrf5340, 2.6.1 SDK and 2.6.1 toolchain manager.
This are my configuration.
this is BLE start code
Please help me resolve this issue, as I am in the final stage of my project completion!
  • Hi!
    So you are seeing 2 different crashes.
    Could you post the crash info for this? Any log output, etc that shows this?
    In the first case, when BLE is initialized outside main(), the logs stop without any error.
    In the second case, during the bonding process, after entering the BLE-generated passcode, the bonding completes on the application side but not on the controller side. At this point, the logs stop without any error.
    I’m wondering if I haven’t properly configured the heap, stack, or something else.
    My code is relatively large, but it only occupies 20% of the flash.
    Do I need to make any configuration changes?
    Or is there anything I can test to identify the issue?
    Please help me resolve this!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • Hi!
    What makes you think it "crashes" then ?
    What do you mean by "controller" side? Could you explain this some more?
    I am integrating this BLE code with other code, where the logs from the other code run in a separate task. However, I noticed that the logs have stopped printing.
    In the NRF Connect application, after entering the key, I see the "Delete bond information" option. At the same time, the controller stops printing logs, and I am unable to perform any other operations (such as button input).
1 2 3
