NCS and toolchain version in CMakePresets.json
Hi
In the newer versions of nRF Connect for VS Code, the NCS and toolchain version can be configured per build-configuration.
Is it possible to configure the desired versions in the CMakePresets.json so that the correct version is chosen when a new build-configuration is created?
Many thanks in advance.
Best regards
Remo
    You can have a look at this discussion about CMakePresets.json. Please let me know if you have any further questions.
    Dejan
  • Hi Dejan
    I've read the linked discussion, but it doesn't say anything about pre-setting the versions of the NCS and the toolchain in CMakePresets.json. Have I missed something?
    Best regards
    Remo
  • Hi Remo,
    I misread your question somehow. I am sorry for that.
    Is there a reason why you want to use CMakePresets instead of west workspaces for having persistent NCS and Toolchain versions?
    Can you elaborate on your desired way of using CMakePresets.json?
    Dejan
  • Hi Dejan
    No problem.
    To be honest, I don't know west workspaces. We have used the CMakePresets so that every of our developers can create a build-configuration for our own target-board based on one of the presets (so that e.g. the target CPU, the Kconfig file, the overlay file and optimization-level are already defined).
    Therefore, it would have been nice if also the NCS and toolchain version could have been defined CMakePresets. Is this currently not possible?
    Best regards
    Remo
  • Hi Remo,
    I will check this internally. I expect to provide update by the end of this week.
    Dejan
1 2
