Hi there!
May I know how to have UART00 on P2 like what is shown below as I wanted to have higher speed.
Is it the same as other UART assignments on P0 and P1?
Thanks!
Hi there!
Thanks!
I'm not with Nordic... May be Kenneth can comment
Please see the cross power-domain section of the pin assignment documentation for the nRF54L15.
What pins specifically are you trying to use? Have you used a logic analyzer to see if any of the pins are doing anything?
Edvin
Hi there!
I have read the link you shared before. I know it mentions dedicated pins in pin assignment table but I still want to know if I can use any P2 pins for UARTE00. For example, is it possible to use P2.06 to P2.09 for UART with flow control? I understand UART is not mentioned under description and dedicated function of P2.06 but I wanted to know if I can use it by configuration of certain registers.
Yes. My interpretation is that you can:
https://docs.nordicsemi.com/bundle/ps_nrf54L15/page/uarte.html#d1900e814
But I must admit I have not tested it. Do you have an application that you can't get working with UARTE00 on P2? If so, feel free to upload it, so that I can have a look.
Edvin
Hi there!
I have tried to add UARTE21 to P1 and UARTE00 to P2 respectively.
UARTE21 works well but TX of UARTE00 only shows garbled code and RX of UARTE00 is not able to toggle LED of the DK. Could you give me some hints what did I miss?
Here is the sample I follow
Following is the application I have, including main.c, CMakelist, cong and dts I am using.
* Copyright (c) 2016 Intel Corporation
/* Controlling LEDs through UART. Press 1-3 on your keyboard to toggle LEDS 1-3 on your development
* kit */
#include <zephyr/kernel.h>
#include <zephyr/device.h>
/* STEP 3 - Include the header file of the UART driver in main.c */
#include <zephyr/drivers/uart.h>
/* 1000 msec = 1 sec */
#define SLEEP_TIME_MS 1000
/* STEP 10.1.1 - Define the size of the receive buffer */
#define RECEIVE_BUFF_SIZE 10
/* STEP 10.2 - Define the receiving timeout period */
#define RECEIVE_TIMEOUT 100
/* STEP 5.1 - Get the device pointers of the LEDs through gpio_dt_spec */
/* The nRF7002dk has only 2 LEDs so this step uses a compile-time condition to reflect the DK you
* are building for */
#if defined(CONFIG_BOARD_NRF7002DK_NRF5340_CPUAPP) || defined(CONFIG_BOARD_NRF7002DK_NRF5340_CPUAPP_NS)
static const struct gpio_dt_spec led0 = GPIO_DT_SPEC_GET(DT_ALIAS(led0), gpios);
static const struct gpio_dt_spec led1 = GPIO_DT_SPEC_GET(DT_ALIAS(led1), gpios);
#else
static const struct gpio_dt_spec led2 = GPIO_DT_SPEC_GET(DT_ALIAS(led2), gpios);
/* STEP 4.1 - Get the device pointer of the UART hardware */
#if defined(CONFIG_BOARD_NRF54L15DK_NRF54L15_CPUAPP) || defined(CONFIG_BOARD_NRF54L15DK_NRF54L15_CPUAPP_NS)
//const struct device *uart = DEVICE_DT_GET(DT_NODELABEL(uart20));
const struct device *uart = DEVICE_DT_GET(DT_NODELABEL(uart00));
#else
const struct device *uart = DEVICE_DT_GET(DT_NODELABEL(uart0));
/* STEP 9.1 - Define the transmission buffer, which is a buffer to hold the data to be sent over
* UART */
static uint8_t tx_buf[] = {
"nRF Connect SDK Fundamentals Course\r\n"
"Press 1-2 on your keyboard to toggle LEDS 1-2 on your development kit\r\n"};
#elif defined(CONFIG_BOARD_NRF54L15DK_NRF54L15_CPUAPP) || defined(CONFIG_BOARD_NRF54L15DK_NRF54L15_CPUAPP_NS)
"Press 0-2 on your keyboard to toggle LEDS 0-2 on your development kit\r\n"};
#else
"Press 1-3 on your keyboard to toggle LEDS 1-3 on your development kit\r\n"};
/* STEP 10.1.2 - Define the receive buffer */
static uint8_t rx_buf[RECEIVE_BUFF_SIZE] = {0};
/* STEP 7 - Define the callback function for UART */
static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data)
switch (evt->type) {
case UART_RX_RDY:
if ((evt->data.rx.len) == 1) {
if (evt->data.rx.buf[evt->data.rx.offset] == '1') {
gpio_pin_toggle_dt(&led0);
} else if (evt->data.rx.buf[evt->data.rx.offset] == '2') {
gpio_pin_toggle_dt(&led1);
if (evt->data.rx.buf[evt->data.rx.offset] == '0') {
} else if (evt->data.rx.buf[evt->data.rx.offset] == '1') {
gpio_pin_toggle_dt(&led2);
#else
} else if (evt->data.rx.buf[evt->data.rx.offset] == '3') {
case UART_RX_DISABLED:
uart_rx_enable(dev, rx_buf, sizeof rx_buf, RECEIVE_TIMEOUT);
int ret;
/* STEP 4.2 - Verify that the UART device is ready */
if (!device_is_ready(uart)) {
printk("UART device not ready\n");
return 1;
/* STEP 5.2 - Verify that the LED devices are ready */
if (!device_is_ready(led0.port)) {
printk("GPIO device is not ready\n");
return 1;
/* STEP 6 - Configure the GPIOs of the LEDs */
#if defined(CONFIG_BOARD_NRF7002DK_NRF5340_CPUAPP) || \
ret = gpio_pin_configure_dt(&led0, GPIO_OUTPUT_ACTIVE);
if (ret < 0) {
return 1;
ret = gpio_pin_configure_dt(&led1, GPIO_OUTPUT_ACTIVE);
if (ret < 0) {
return 1;
#else
if (ret < 0) {
return 1;
if (ret < 0) {
return 1;
ret = gpio_pin_configure_dt(&led2, GPIO_OUTPUT_ACTIVE);
if (ret < 0) {
return 1;
/* STEP 8 - Register the UART callback function */
ret = uart_callback_set(uart, uart_cb, NULL);
if (ret) {
return 1;
/* STEP 9.2 - Send the data over UART by calling uart_tx() */
ret = uart_tx(uart, tx_buf, sizeof(tx_buf), SYS_FOREVER_MS);
if (ret) {
return 1;
/* STEP 10.3 - Start receiving by calling uart_rx_enable() and pass it the address of the
* receive buffer */
ret = uart_rx_enable(uart, rx_buf, sizeof rx_buf, RECEIVE_TIMEOUT);
if (ret) {
return 1;
while (1) {
k_msleep(SLEEP_TIME_MS);
# Copyright (c) 2016 Intel Corporation
cmake_minimum_required(VERSION 3.20.0)
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
project(UART)
target_sources(app PRIVATE src/main.c)
