Failed to star advertising after dissconnect error -12
Hi im having problems with restarting advertising after disconnect. I tried NUS example, simple peripheral example but none of them works.
I modified NUS example with some  extra  functions but i cannot get it to work.
Unreferencing current connection as advised on forum doesnt help either.
 * Copyright (c) 2024 Croxel, Inc.
#include <zephyr/kernel.h>
#include <zephyr/bluetooth/services/nus.h>
#define DEVICE_NAME		"XX45"
#define DEVICE_NAME_LEN		(sizeof(DEVICE_NAME) - 1)
static struct bt_conn *current_conn;
static const struct bt_data ad[] = {
	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
	BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
static const struct bt_data sd[] = {
	BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_NUS_SRV_VAL),
static void notif_enabled(bool enabled, void *ctx)
	ARG_UNUSED(ctx);
	printk("%s() - %s\n", __func__, (enabled ? "Enabled" : "Disabled"));
static void received(struct bt_conn *conn, const void *data, uint16_t len, void *ctx)
	char message[CONFIG_BT_L2CAP_TX_MTU + 1] = "";
	ARG_UNUSED(conn);
	ARG_UNUSED(ctx);
	memcpy(message, data, MIN(sizeof(message) - 1, len));
	printk("%s() - Len: %d, Message: %s\n", __func__, len, message);
struct bt_nus_cb nus_listener = {
	.notif_enabled = notif_enabled,
	.received = received,
int advertising_start()
	int err;
		err = bt_le_adv_start(BT_LE_ADV_CONN_ONE_TIME, ad, ARRAY_SIZE(ad), sd, ARRAY_SIZE(sd));
	if (err) {
		printk("Failed to start advertising: %d\n", err);
		return err;
return 0;
static void connected(struct bt_conn *conn, uint8_t err)
	if (err) {
		printk("Connection failed, err 0x%02x", err);
		return;
	printk("Connected %s", addr);
	current_conn = bt_conn_ref(conn);
	//dk_set_led_on(CON_STATUS_LED);
	printk("Disconnected: %s, reason 0x%02x ", addr, reason );
	if (current_conn) {
		bt_conn_unref(current_conn);
		current_conn = NULL;
		//dk_set_led_off(CON_STATUS_LED);
		printk("Dereferenced current_conn\n");
		advertising_start();
BT_CONN_CB_DEFINE(conn_callbacks) = {
	.connected    = connected,
	.disconnected = disconnected,
	int err;
	printk("Sample - Bluetooth Peripheral NUS\n");
	err = bt_nus_cb_register(&nus_listener, NULL);
	if (err) {
		printk("Failed to register NUS callback: %d\n", err);
		return err;
	err = bt_enable(NULL);
	if (err) {
		printk("Failed to enable bluetooth: %d\n", err);
		return err;
	printk("Initialization complete\n");
	while (true) {
		const char *hello_world = "Hello World!\n";
		k_sleep(K_SECONDS(3));
		err = bt_nus_send(NULL, hello_world, strlen(hello_world));
		printk("Data send - Result: %d\n", err);
		if (err < 0 && (err != -EAGAIN) && (err != -ENOTCONN)) {
			return err;
	return 0;
Data send - Result: -128
Connected 5B:4F:15:AE:C7:0B (random)Data send - Result: -128
notif_enabled() - Enabled
notif_enabled() - Disabled
Disconnected: 5B:4F:15:AE:C7:0B (random), reason 0x13 Dereferenced current_conn
Failed to start advertising: -12
