Description:
I am working with an nRF52840 custom board. I have encountered an issue where the board is not detected by the J-Link debugger after flashing the firmware a second time.
Issue Details:
Behavior:
- The first time I flash the board without specifying the Zigbee channel (
CONFIG_ZIGBEE_CHANNEL), it works as expected. - After the second flash (again without specifying the channel), the device is no longer detected by J-Link.
Workaround:
- If I add the CONFIG_ZIGBEE_CHANNEL=15 line to
prj.conf, the board works properly even after multiple flashes: - However, I would like to understand why specifying the channel is necessary and how I can recover the board without relying on this setting.
prj.conf Content:
# # Copyright (c) 2020 Nordic Semiconductor ASA # # SPDX-License-Identifier: LicenseRef-Nordic-5-Clause # CONFIG_NCS_SAMPLES_DEFAULTS=y CONFIG_SERIAL=y CONFIG_GPIO=y # Make sure printk is not printing to the UART console CONFIG_CONSOLE=y CONFIG_UART_CONSOLE=y CONFIG_MAIN_THREAD_PRIORITY=7 CONFIG_ZIGBEE=y CONFIG_ZIGBEE_APP_UTILS=y CONFIG_ZIGBEE_ROLE_COORDINATOR=y # Enable DK LED and Buttons library CONFIG_DK_LIBRARY=y # This example requires more workqueue stack CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096 # Enable nRF ECB driver CONFIG_CRYPTO=y CONFIG_CRYPTO_NRF_ECB=y CONFIG_CRYPTO_INIT_PRIORITY=80 # Networking CONFIG_NET_IPV6=n CONFIG_NET_IP_ADDR_CHECK=n CONFIG_NET_UDP=n CONFIG_NO_OPTIMIZATIONS=y CONFIG_UART_INTERRUPT_DRIVEN=n CONFIG_UART_ASYNC_API=y CONFIG_UART_1_ASYNC=y # Enable API for powering down unused RAM parts CONFIG_RAM_POWER_DOWN_LIBRARY=y # Networking CONFIG_NET_IPV6=n CONFIG_NET_IP_ADDR_CHECK=n CONFIG_NET_UDP=n CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC=y CONFIG_ZIGBEE_SCENES=y CONFIG_ZIGBEE_CHANNEL=15 CONFIG_FLASH=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_NVS=y CONFIG_LOG=y CONFIG_LOG_BACKEND_FS=y #CONFIG_LOG_MODE_IMMEDIATE=y #CONFIG_LOG_MODE_DEFERRED=y CONFIG_NVS_LOG_LEVEL_DBG=y CONFIG_REBOOT=y CONFIG_MPU_ALLOW_FLASH_WRITE=y CONFIG_MAIN_STACK_SIZE= 8192 CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=8192 CONFIG_NEWLIB_LIBC=y CONFIG_HEAP_MEM_POOL_SIZE= 8192 CONFIG_CBPRINTF_FP_SUPPORT=y CONFIG_NEWLIB_LIBC_FLOAT_PRINTF=y CONFIG_ZBOSS_DEFAULT_THREAD_STACK_SIZE=4096 CONFIG_SYS_HEAP_RUNTIME_STATS=y CONFIG_COMMON_LIBC_MALLOC=y
Questions:
- Why does specifying
CONFIG_ZIGBEE_CHANNELprevent the detection issue after multiple flashes? - How can I recover the board when it is no longer detected by J-Link?
- What is the best practice for handling Zigbee channel configurations to avoid such detection issues?
- Is there a known bug or hardware dependency that could be causing this behavior?
