BLE Mesh DFU failed to update
I run this sample https://github.com/nrfconnect/sdk-nrf/tree/main/samples/bluetooth/mesh/dfu/distributor on two NRF52840DK, but I cpouldn't do the update, here is the log:
*** Booting MCUboot v2.1.0-dev-12e5ee106034 ***
*** Using nRF Connect SDK v2.9.0-7787b2649840 ***
*** Using Zephyr OS v3.7.99-1f8f3dc29142 ***
I: Starting bootloader
I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Boot source: none
I: Image index: 0, Swap type: none
I: Bootloader chainload address offset: 0xc000
*** Booting Mesh DFU Distributor v2.9.0-7787b2649840 ***
Initializing...
Current image version: 1.0.0+0
[00:00:00.008,819] <inf> fs_nvs: 2 Sectors of 4096 bytes
[00:00:00.008,850] <inf> fs_nvs: alloc wra: 0, fa0
[00:00:00.008,850] <inf> fs_nvs: data wra: 0, 68
[00:00:00.009,185] <inf> bt_sdc_hci_driver: SoftDevice Controller build revision:
                                            2d 79 a1 c8 6a 40 b7 3c  f6 74 f9 0b 22 d3 c4 80 |-y..j@.< .t.."...
                                            74 72 82 ba                                      |tr..
[00:00:00.011,383] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:00:00.011,383] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
[00:00:00.011,413] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 45.41337 Build 3074452168
[00:00:00.011,657] <inf> bt_hci_core: No ID address. App must call settings_load()
Bluetooth initialized
[00:00:00.011,810] <wrn> bt_mesh_access: Unused space in relation list: 7
[00:00:00.266,448] <inf> bt_hci_core: Identity[0]: E4:86:0D:85:49:FD (random)
[00:00:00.266,540] <inf> bt_hci_core: Identity[1]: F7:5B:FB:6F:BF:CB (random)
[00:00:00.266,571] <inf> bt_hci_core: HCI: version 6.0 (0x0e) revision 0x106b, manufacturer 0x0059
[00:00:00.266,601] <inf> bt_hci_core: LMP: version 6.0 (0x0e) subver 0x106b
[00:00:00.269,897] <inf> bt_mesh_provisionee: Device UUID: cf0cca08-c9c3-40d7-b0f3-35f7363c0f28
Mesh initialized
Authentication for SMP over BLE is disabled
Recovered identity for SMP: 1
[00:00:00.275,238] <wrn> bt_mesh_dfu_srv: Wrong state
[00:00:10.291,717] <wrn> bt_l2cap: Ignoring data for unknown channel ID 0x003a
[00:00:14.548,522] <inf> bt_mesh_main: Primary Element: 0x0047
[00:00:14.548,522] <dbg> bt_mesh_main: bt_mesh_provision: net_idx 0x0000 flags 0x00 iv_index 0x0000
[00:00:14.863,952] <dbg> bt_mesh_health_srv: attention_off:
[00:00:16.709,228] <wrn> bt_l2cap: Ignoring data for unknown channel ID 0x003a
[00:00:17.670,440] <dbg> bt_mesh_cfg_srv: dev_comp_data_get: net_idx 0x0000 app_idx 0xfffe src 0x0001 len 1: 00
[00:00:17.670,440] <dbg> bt_mesh_cfg_srv: dev_comp_data_get: Preparing Composition data page 0
[00:00:17.971,282] <dbg> bt_mesh_cfg_srv: default_ttl_get: net_idx 0x0000 app_idx 0xfffe src 0x0001 len 0:
[00:00:21.780,487] <dbg> bt_mesh_cfg_srv: app_key_add: AppIdx 0x0000 NetIdx 0x0000
[00:00:31.530,181] <dbg> bt_mesh_cfg_srv: get_model: ID 0x1401 addr 0x0047
[00:00:31.530,212] <dbg> bt_mesh_cfg_srv: mod_bind: model 0x20001588 key_idx 0x000
[00:00:31.530,212] <dbg> bt_mesh_cfg_srv: mod_bind: model 0x20001588 id 0x1401 i 0 key 0xffff
[00:00:31.530,242] <dbg> bt_mesh_cfg_srv: mod_app_bind: status 0x00
[00:00:38.055,511] <dbg> bt_mesh_cfg_srv: get_model: ID 0x1403 addr 0x0047
[00:00:38.055,541] <dbg> bt_mesh_cfg_srv: mod_bind: model 0x200015b0 key_idx 0x000
[00:00:38.055,572] <dbg> bt_mesh_cfg_srv: mod_bind: model 0x200015b0 id 0x1403 i 0 key 0xffff
[00:00:38.055,603] <dbg> bt_mesh_cfg_srv: mod_app_bind: status 0x00
[00:00:42.644,439] <dbg> bt_mesh_cfg_srv: get_model: ID 0x1400 addr 0x0047
[00:00:42.644,470] <dbg> bt_mesh_cfg_srv: mod_bind: model 0x200015d8 key_idx 0x000
[00:00:42.644,500] <dbg> bt_mesh_cfg_srv: mod_bind: model 0x200015d8 id 0x1400 i 0 key 0xffff
[00:00:42.644,531] <dbg> bt_mesh_cfg_srv: mod_app_bind: status 0x00
[00:00:47.369,445] <dbg> bt_mesh_cfg_srv: get_model: ID 0x1404 addr 0x0047
[00:00:47.369,445] <dbg> bt_mesh_cfg_srv: mod_bind: model 0x20001600 key_idx 0x000
[00:00:47.369,476] <dbg> bt_mesh_cfg_srv: mod_bind: model 0x20001600 id 0x1404 i 0 key 0xffff
[00:00:47.369,506] <dbg> bt_mesh_cfg_srv: mod_app_bind: status 0x00
[00:00:53.804,382] <dbg> bt_mesh_cfg_srv: get_model: ID 0x1400 addr 0x0048
[00:00:53.804,412] <dbg> bt_mesh_cfg_srv: mod_bind: model 0x200014d0 key_idx 0x000
[00:00:53.804,412] <dbg> bt_mesh_cfg_srv: mod_bind: model 0x200014d0 id 0x1400 i 0 key 0xffff
[00:00:53.804,443] <dbg> bt_mesh_cfg_srv: mod_app_bind: status 0x00
[00:00:57.945,037] <dbg> bt_mesh_cfg_srv: get_model: ID 0x1402 addr 0x0048
[00:00:57.945,068] <dbg> bt_mesh_cfg_srv: mod_bind: model 0x200014f8 key_idx 0x000
[00:00:57.945,098] <dbg> bt_mesh_cfg_srv: mod_bind: model 0x200014f8 id 0x1402 i 0 key 0xffff
[00:00:57.945,098] <dbg> bt_mesh_cfg_srv: mod_app_bind: status 0x00
Connected to SMP service: err 0 id 1
[00:01:45.838,867] <wrn> bt_l2cap: Ignoring data for unknown channel ID 0x003a
[00:02:03.166,900] <inf> mcuboot_util: Image index: 0, Swap type: none
[00:02:03.713,043] <inf> mcuboot_util: Image index: 0, Swap type: none
[00:02:03.713,104] <inf> mcuboot_util: Image index: 0, Swap type: none
[00:04:02.647,338] <dbg> bt_mesh_dfu_slot: bt_mesh_dfu_slot_reserve: Reserved slot #0
[00:04:02.658,416] <dbg> bt_mesh_dfu_slot: bt_mesh_dfu_slot_commit: Stored slot #0: 0100000000000000
[00:04:37.405,456] <dbg> bt_mesh_dfd_srv: bt_mesh_dfd_srv_receiver_add: Added receiver 0x0045 img: 0
[00:04:37.405,517] <dbg> bt_mesh_dfd_srv: bt_mesh_dfd_srv_receiver_add: Added receiver 0x0047 img: 0
Starting the firmware distribution.
Slot:
        FWID:     0100000000000000
        Metadata: 0100000000000000735d06013e9ffbc50200
[00:05:09.445,129] <dbg> bt_mesh_dfd_srv: bt_mesh_dfd_srv_start: Distribution Start: slot: 0, appidx: 0, tb: 0, addr: 0000, ttl: 255, apply: 1
Distribution phase changed to Transfer Active
[00:05:09.445,281] <dbg> bt_mesh_dfu_cli: initiate:
[00:05:09.445,312] <dbg> bt_mesh_blob_cli: blob_cli_broadcast: 2 targets
[00:05:19.576,599] <dbg> bt_mesh_blob_cli: retry_timeout: 5
[00:05:30.956,573] <dbg> bt_mesh_blob_cli: retry_timeout: 4
[00:05:41.148,986] <dbg> bt_mesh_blob_cli: retry_timeout: 3
[00:05:52.650,268] <dbg> bt_mesh_blob_cli: retry_timeout: 2
[00:06:02.811,767] <dbg> bt_mesh_blob_cli: retry_timeout: 1
[00:06:02.811,798] <dbg> bt_mesh_blob_cli: retry_timeout: Transfer timed out.
[00:06:02.811,828] <dbg> bt_mesh_blob_cli: drop_remaining_targets:
[00:06:02.811,828] <wrn> bt_mesh_blob_cli: Dropping 0x0045: 9
[00:06:02.811,828] <err> bt_mesh_dfu_cli: Target 0x0045 failed: 3
[00:06:02.811,859] <wrn> bt_mesh_blob_cli: Dropping 0x0047: 9
[00:06:02.811,859] <err> bt_mesh_dfu_cli: Target 0x0047 failed: 3
[00:06:02.811,889] <dbg> bt_mesh_blob_cli: broadcast_complete: continuing
[00:06:02.811,889] <dbg> bt_mesh_dfu_cli: transfer:
[00:06:02.811,920] <dbg> bt_mesh_dfu_cli: dfu_failed: 3
[00:06:02.811,950] <dbg> bt_mesh_dfd_srv: dfu_ended: reason: 3, phase: 1, apply: 1
Distribution phase changed to Failed
[00:06:49.363,220] <dbg> bt_mesh_dfd_srv: bt_mesh_dfd_srv_receiver_add: Added receiver 0x0045 img: 0
Slot:
[00:06:59.283,416] <dbg> bt_mesh_dfd_srv: bt_mesh_dfd_srv_start: Distribution Start: slot: 0, appidx: 0, tb: 0, addr: 0000, ttl: 255, apply: 1
[00:06:59.283,599] <dbg> bt_mesh_dfu_cli: initiate:
[00:06:59.283,599] <dbg> bt_mesh_blob_cli: blob_cli_broadcast: 1 targets
[00:07:09.110,687] <dbg> bt_mesh_blob_cli: retry_timeout: 5
[00:07:19.072,235] <dbg> bt_mesh_blob_cli: retry_timeout: 4
[00:07:28.882,812] <dbg> bt_mesh_blob_cli: retry_timeout: 3
[00:07:38.268,249] <dbg> bt_mesh_blob_cli: retry_timeout: 2
[00:07:47.646,148] <dbg> bt_mesh_blob_cli: retry_timeout: 1
[00:07:47.646,179] <dbg> bt_mesh_blob_cli: retry_timeout: Transfer timed out.
[00:07:47.646,209] <dbg> bt_mesh_blob_cli: drop_remaining_targets:
[00:07:47.646,209] <wrn> bt_mesh_blob_cli: Dropping 0x0045: 9
[00:07:47.646,209] <err> bt_mesh_dfu_cli: Target 0x0045 failed: 3
[00:07:47.646,240] <dbg> bt_mesh_blob_cli: broadcast_complete: continuing
[00:07:47.646,270] <dbg> bt_mesh_dfu_cli: transfer:
[00:07:47.646,270] <dbg> bt_mesh_dfu_cli: dfu_failed: 3
[00:07:47.646,301] <dbg> bt_mesh_dfd_srv: dfu_ended: reason: 3, phase: 1, apply: 1
[00:12:58.438,079] <dbg> bt_mesh_dfd_srv: bt_mesh_dfd_srv_receiver_add: Added receiver 0x0047 img: 0
Slot:
[00:13:06.357,116] <dbg> bt_mesh_dfd_srv: bt_mesh_dfd_srv_start: Distribution Start: slot: 0, appidx: 0, tb: 0, addr: 0000, ttl: 255, apply: 1
[00:13:06.357,299] <dbg> bt_mesh_dfu_cli: initiate:
[00:13:06.357,299] <dbg> bt_mesh_blob_cli: blob_cli_broadcast: 1 targets
[00:13:15.638,519] <dbg> bt_mesh_blob_cli: retry_timeout: 5
[00:13:24.919,830] <dbg> bt_mesh_blob_cli: retry_timeout: 4
[00:13:34.201,446] <dbg> bt_mesh_blob_cli: retry_timeout: 3
[00:13:43.482,513] <dbg> bt_mesh_blob_cli: retry_timeout: 2
[00:13:52.763,519] <dbg> bt_mesh_blob_cli: retry_timeout: 1
[00:13:52.763,549] <dbg> bt_mesh_blob_cli: retry_timeout: Transfer timed out.
[00:13:52.763,549] <dbg> bt_mesh_blob_cli: drop_remaining_targets:
[00:13:52.763,580] <wrn> bt_mesh_blob_cli: Dropping 0x0047: 9
[00:13:52.763,580] <err> bt_mesh_dfu_cli: Target 0x0047 failed: 3
[00:13:52.763,610] <dbg> bt_mesh_blob_cli: broadcast_complete: continuing
[00:13:52.763,610] <dbg> bt_mesh_dfu_cli: transfer:
[00:13:52.763,641] <dbg> bt_mesh_dfu_cli: dfu_failed: 3
[00:13:52.763,702] <dbg> bt_mesh_dfd_srv: dfu_ended: reason: 3, phase: 1, apply: 1
I tried to upload the firmware to self address and to other node but the result is the same. What could be wrong?
