USB-UART baud rate in nrf51 dongle pca10031
Hey everyone, I am using nrf51 dongle pca 10031. Nordic promised to have 1Mbps data rate. when i was trying to transfer data through UART. data is validated until 401600 (400kbps). when i configured UART to 1 Mbps, data is corrupted. when i was trying to transmit data (0x01-0x0f) on uart, on serial console i am recieving (0x80-0x8f). Can we achieve UART-USB data rate of 1 mbps with proper data validation?
    Sorry for the slow response. Master control panel is using 1Mbaud, but was actually able to reproduce the behavior you described using the SDK example. It appears to be a SW issue and not HW. Tried the same with the simple uart module found in SDK 7.0.0, and got a throughput of ~40K characters per second running at 1MBaud with HWFC without any data loss.
    To test this I modified the SDK example do not exit upon receiving the 'Q/q' character, then used Real term and sent a larger text file while having capture enabled. Afterwards I did a 'diff' of the input and output file to verify the data.
    I've reported this as a bug internally.
