IO expander control with TWI
I've been trying to control MCP23017 IO expander with TWI using nRF52832. When I execute the code it stops at nrf_drv_twi_tx. The address pins A(0:2) are 0.
Any idea on what may not work here?
Code:
#define I2C_SCL_PIN 			(21)
#define I2C_SDA_PIN 			(20)
#define I2C_EXPANDER_ADD 	        (0x40)
const int resetPin = 19;
const int ledPin = 26;
static const nrf_drv_twi_t twi = NRF_DRV_TWI_INSTANCE(0);
static ret_code_t i2cSend(size_t target_register, uint8_t data_to_write) {
		uint8_t buffer[2];
		buffer[0] = target_register;
		buffer[1] = data_to_write;
		return nrf_drv_twi_tx(&twi, I2C_EXPANDER_ADD, buffer, 0x02, false);
int main(){
	ret_code_t err_code;
	uint8_t data;
	size_t addr;
	nrf_gpio_cfg_output(resetPin);	//Expander reset pin
	nrf_gpio_cfg_output(ledPin);
	nrf_gpio_pin_set(resetPin);
	nrf_gpio_pin_set(ledPin);          //Expander inactive state
  const nrf_drv_twi_config_t twi_config = {
    .scl                       = I2C_SCL_PIN,
    .sda                      = I2C_SDA_PIN,
    .frequency            = NRF_TWI_FREQ_400K,
    .interrupt_priority = APP_IRQ_PRIORITY_HIGH
	err_code = nrf_drv_twi_init(&twi, &twi_config, NULL, NULL);
	nrf_drv_twi_enable(&twi);
  i2cSend(0x01, 0x00);                     //Access direction register of PortB
	while(1){
		nrf_delay_ms(500);
		i2cSend(0x13, 0x02);	           //Access PortB, Turn LED2 ON
		nrf_gpio_pin_set(ledPin);     //Turn LED1 OFF
		nrf_delay_ms(500);
		i2cSend(0x13, 0x00);            //Access PortB, Turn LED2 OFF
		nrf_gpio_pin_clear(ledPin);  //Turn LED1 ON
