The state status is Unknown(147) after FOTA DFU on 54L15
Hello there,
Working on bringing up the FOTA feature on the 54L15. I began with the LBS example.  I was using the Nordic "Device Manage" to push the FOTA build.
The state flow changes as:  "Uploading"  /  "Resetting"  /  "Confirming" / "UNKNOWN(147)".  The build has been uploaded successfully, but this "unknown" state bothers me.
Then I used "nRF Connect" to build the connection and run the same DFU for the progress log (attached below).  I wonder if this "unknown state" is something I need concern.
Thank you in advance.
nRF Connect, 2025-02-20
Nordic_LBS (EA:0B:16:96:F4:6D)
V 10:12:51.625 [McuMgr] Connecting...
D 10:12:51.629 [McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M)
D 10:12:51.659 [McuMgr] [Callback] Connection state changed with status: 0 and new state: 2 (CONNECTED)
I 10:12:51.661 [McuMgr] Connected to EA:0B:16:96:F4:6D
D 10:12:51.662 [McuMgr] wait(300)
V 10:12:51.965 [McuMgr] Discovering services...
D 10:12:51.975 [McuMgr] gatt.discoverServices()
I 10:12:51.999 [McuMgr] Services discovered
V 10:12:52.003 [McuMgr] Primary service found
V 10:12:52.007 [McuMgr] Requesting new MTU...
D 10:12:52.010 [McuMgr] gatt.requestMtu(498)
I 10:12:52.090 [McuMgr] MTU changed to: 498
D 10:12:52.100 [McuMgr] gatt.setCharacteristicNotification(da2e7828-fbce-4e01-ae9e-261174997c48, true)
V 10:12:52.103 [McuMgr] Enabling notifications for da2e7828-fbce-4e01-ae9e-261174997c48
D 10:12:52.105 [McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00)
I 10:12:52.208 [McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb
V 10:12:52.219 [McuMgr] Waiting for value change...
V 10:12:52.223 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
D 10:12:52.225 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x000000010000FF06A0, WRITE COMMAND)
I 10:12:52.234 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48
I 10:12:52.296 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-19-00-00-FF-06-BF-68-62-75-66-5F-73-69-7A-65-19-09-AB-69-62-75-66-5F-63-6F-75-6E-74-04-FF
I 10:12:52.298 [McuMgr] Wait for value changed complete
A 10:12:52.300 [McuMgr] Received Header (Version: 0, Op: 1, Flags: 0, Len: 25, Group: 0, Seq: 255, Command: 6) CBOR {"buf_size":2475,"buf_count":4}
I 10:12:52.309 [McuMgr] SMP reassembly supported with buffer size: 2475 bytes and count: 4
V 10:12:52.311 [McuMgr] Requesting connection priority: HIGH (11.25–15ms, 0, 5s)...
D 10:12:52.312 [McuMgr] gatt.requestConnectionPriority(HIGH)
A 10:12:52.328 [McuMgr] Sending (9 bytes) Header (Version: 1, Op: 0, Flags: 0, Len: 1, Group: 0, Seq: 0, Command: 8) CBOR {}
V 10:12:52.516 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
D 10:12:52.530 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0800000100000008A0, WRITE COMMAND)
I 10:12:52.553 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48
I 10:12:52.603 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 09-00-00-15-00-00-00-08-BF-6A-62-6F-6F-74-6C-6F-61-64-65-72-67-4D-43-55-62-6F-6F-74-FF
I 10:12:52.604 Connection parameters updated (interval: 11.25ms, latency: 0, timeout: 420ms)
I 10:12:52.609 [McuMgr] Connection parameters updated (interval: 11.25ms, latency: 0, timeout: 420ms)
A 10:12:52.612 [McuMgr] Received Header (Version: 1, Op: 1, Flags: 0, Len: 21, Group: 0, Seq: 0, Command: 8) CBOR {"bootloader":"MCUboot"}
A 10:12:52.619 [McuMgr] Sending (20 bytes) Header (Version: 1, Op: 0, Flags: 0, Len: 12, Group: 0, Seq: 1, Command: 8) CBOR {"query":"mode"}
V 10:12:52.623 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
D 10:12:52.645 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0800000C00000108A1657175657279646D6F6465, WRITE COMMAND)
I 10:12:52.654 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48
I 10:12:52.695 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 09-00-00-08-00-00-01-08-BF-64-6D-6F-64-65-03-FF
A 10:12:52.700 [McuMgr] Received Header (Version: 1, Op: 1, Flags: 0, Len: 8, Group: 0, Seq: 1, Command: 8) CBOR {"mode":3}
I 10:12:52.718 Connection parameters updated (interval: 15.0ms, latency: 0, timeout: 5000ms)
A 10:12:52.724 [McuMgr] Sending (9 bytes) Header (Version: 1, Op: 0, Flags: 0, Len: 1, Group: 1, Seq: 2, Command: 0) CBOR {}
V 10:12:52.731 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
D 10:12:52.735 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0800000100010200A0, WRITE COMMAND)
I 10:12:52.742 [McuMgr] Connection parameters updated (interval: 15.0ms, latency: 0, timeout: 5000ms)
I 10:12:52.748 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48
I 10:12:52.794 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 09-00-00-86-00-01-02-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-65-32-2E-39-2E-30-64-68-61-73-68-58-20-17-CB-1E-84-51-5E-24-82-5C-1A-FB-A8-42-82-50-16-25-2A-65-D7-A1-C8-6F-8F-AD-C5-74-1F-F3-EE-CF-77-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75-73-00-FF
A 10:12:52.798 [McuMgr] Received Header (Version: 1, Op: 1, Flags: 0, Len: 134, Group: 1, Seq: 2, Command: 0) CBOR {"images":[{"slot":0,"version":"2.9.0","hash":"F8sehFFeJIJcGvuoQoJQFiUqZdehyG+PrcV0H/Puz3c=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false}],"splitStatus":0}
V 10:12:52.822 [McuMgr] Uploading firmware...
A 10:12:56.735 [McuMgr] 223448 bytes sent in 3802 ms (58.77 kB/s)
V 10:12:56.802 [McuMgr] New state: TEST
A 10:12:56.814 [McuMgr] Sending (57 bytes) Header (Version: 1, Op: 2, Flags: 0, Len: 49, Group: 1, Seq: 97, Command: 0) CBOR {"confirm":false,"hash":"HzzGrL14Rm51milVEjNuA/2+Fyci1kDIK4VYA/trUQM="}
V 10:12:56.819 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
D 10:12:56.848 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0A00003100016100A267636F6E6669726DF4646861736858201F3CC6ACBD78466E759A295512336E03FDBE172722D640C82B855803FB6B5103, WRITE COMMAND)
I 10:12:56.868 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48
I 10:12:56.894 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 0B-00-00-F4-00-01-61-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-65-32-2E-39-2E-30-64-68-61-73-68-58-20-17-CB-1E-84-51-5E-24-82-5C-1A-FB-A8-42-82-50-16-25-2A-65-D7-A1-C8-6F-8F-AD-C5-74-1F-F3-EE-CF-77-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-BF-64-73-6C-6F-74-01-67-76-65-72-73-69-6F-6E-65-32-2E-39-2E-30-64-68-61-73-68-58-20-1F-3C-C6-AC-BD-78-46-6E-75-9A-29-55-12-33-6E-03-FD-BE-17-27-22-D6-40-C8-2B-85-58-03-FB-6B-51-03-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F5-69-63-6F-6E-66-69-72-6D-65-64-F4-66-61-63-74-69-76-65-F4-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75-73-00-FF
A 10:12:56.903 [McuMgr] Received Header (Version: 1, Op: 3, Flags: 0, Len: 244, Group: 1, Seq: 97, Command: 0) CBOR {"images":[{"slot":0,"version":"2.9.0","hash":"F8sehFFeJIJcGvuoQoJQFiUqZdehyG+PrcV0H/Puz3c=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false},{"slot":1,"version":"2.9.0","hash":"HzzGrL14Rm51milVEjNuA/2+Fyci1kDIK4VYA/trUQM=","bootable":true,"pending":true,"confirmed":false,"active":false,"permanent":false}],"splitStatus":0}
V 10:12:56.920 [McuMgr] New state: RESET
A 10:12:56.943 [McuMgr] Sending (9 bytes) Header (Version: 1, Op: 2, Flags: 0, Len: 1, Group: 0, Seq: 98, Command: 5) CBOR {}
V 10:12:56.949 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
D 10:12:56.952 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0A00000100006205A0, WRITE COMMAND)
I 10:12:56.959 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48
I 10:12:56.999 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 0B-00-00-02-00-00-62-05-BF-FF
A 10:12:57.005 [McuMgr] Received Header (Version: 1, Op: 3, Flags: 0, Len: 2, Group: 0, Seq: 98, Command: 5) CBOR {}
D 10:13:02.283 [Server callback] Connection state changed with status: 0 and new state: DISCONNECTED (0)
I 10:13:02.283 [Server] Device disconnected
D 10:13:02.294 [Callback] Connection state changed with status: 8 and new state: DISCONNECTED (0)
E 10:13:02.294 Error 8 (0x8): GATT CONN TIMEOUT
I 10:13:02.294 Disconnected
D 10:13:02.321 [McuMgr] [Callback] Connection state changed with status: 8 and new state: 0 (DISCONNECTED)
W 10:13:02.324 [McuMgr] Error: (0x8): GATT CONN TIMEOUT
I 10:13:02.326 [McuMgr] Disconnected
D 10:13:02.330 [McuMgr] gatt.close()
D 10:13:02.333 [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
V 10:13:07.025 [McuMgr] Connecting...
D 10:13:07.037 [McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M)
V 10:13:07.052 [McuMgr] New state: CONFIRM
D 10:13:37.110 [Server callback] Connection state changed with status: 0 and new state: DISCONNECTED (0)
I 10:13:37.110 [Server] Device disconnected
D 10:13:37.115 [McuMgr] [Callback] Connection state changed with status: 147 and new state: 0 (DISCONNECTED)
W 10:13:37.126 [McuMgr] Error: (0x93): UNKNOWN (147)
W 10:13:37.130 [McuMgr] Connection attempt timed out
D 10:13:37.136 [McuMgr] gatt.close()
D 10:13:37.146 gatt.close()
D 10:13:37.148 wait(200)
V 10:13:37.350 Connecting to EA:0B:16:96:F4:6D...
D 10:13:37.351 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
D 10:13:59.616 [Server callback] Connection state changed with status: 0 and new state: CONNECTED (2)
I 10:13:59.617 [Server] Device with address EA:0B:16:96:F4:6D connected
D 10:13:59.643 [Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
I 10:13:59.643 Connected to EA:0B:16:96:F4:6D
V 10:13:59.644 Discovering services...
D 10:13:59.644 gatt.discoverServices()
D 10:13:59.649 [Callback] Services discovered with status: 0
I 10:13:59.649 Services discovered
V 10:13:59.652 Generic Attribute (0x1801)
- Service Changed [I] (0x2A05)
   Client Characteristic Configuration (0x2902)
- Client Supported Features [R W] (0x2B29)
- Database Hash [R] (0x2B2A)
Generic Access (0x1800)
- Device Name [R] (0x2A00)
- Appearance [R] (0x2A01)
- Peripheral Preferred Connection Parameters [R] (0x2A04)
Nordic LED Button Service (00001523-1212-efde-1523-785feabcd123)
- Button [N R] (00001524-1212-efde-1523-785feabcd123)
- LED [W] (00001525-1212-efde-1523-785feabcd123)
SMP Service (8d53dc1d-1db7-4cd3-868b-8a527460aa84)
- SMP Characteristic [N WNR] (da2e7828-fbce-4e01-ae9e-261174997c48)
D 10:13:59.653 gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
D 10:13:59.654 gatt.setCharacteristicNotification(00001524-1212-efde-1523-785feabcd123, true)
I 10:14:00.016 [Server] PHY updated (TX: LE 2M, RX: LE 2M)
I 10:14:00.016 PHY updated (TX: LE 2M, RX: LE 2M)
D 10:14:00.127 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
  • I don't know if I need open a new thead. Since it has not been replied, I just attched it to my last question.
    So, my statement about "The build has been uploaded successfully" was not completely true in my previous question.
    Yes, the blinking speed changed and the new build has been uploaded.  I also changed the device name each time as a secondary verification.   HOWEVER, once i reset or power cycle the DK board, the LED does NOT blink for a short peiord (30-60 seconds ish), then the build was rolled back.  Both the device name and blinking speed changed back.
    I followed the Nordic Hand-on video tutorial on youtube.  Then I verified my setup by with Exercise 5 (FOTA over BLuetooth  LOW Energy) from the Nordic Academy.  I am using the nRF64L15-DK, and the SDK is 2.9.0.
    What could I miss?
    Thank you very much
    Have you tried the solution provided in the Developer Academy course? Does the same issue occur with that application as well? To rule out the possibility that the issue is not coming from the application, I recommend testing the solution and observing the results. Additionally, I suggest collecting logs from the nRF side to get a better understanding of the issue.
    Kind Regards,
    Abhijith
  • Hello Abhijith,
    Thank you for the reply!
    As your suggestion, I reload a fresh LBS example, followed the course exactly, and verified the LBS functioned.  It still doesn't work.
    I tried a different cell phone just in case.  This time, the phone shows "Connection timed out".
    Then I tried a brand new nRF54L15 DK board hoping the old hardware is not perfect.  No luck.
    Then I tried a nRF54840DK board.  It works, yes, the different board works. Only difference was to set a new config.  In the config, everything is kept the default for both board types.
    I used "nRF Connect" app and slide the side to get the log.  Is this the right way to collect the logs?
    The log is as follow:
    nRF Connect, 2025-02-26
    Nordic_LBSm (E3:A3:EA:52:01:F2)
    V 13:22:38.374 Connecting to E3:A3:EA:52:01:F2...
    D 13:22:38.374 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
    D 13:22:38.651 [Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
    I 13:22:38.651 Connected to E3:A3:EA:52:01:F2
    V 13:22:38.652 Discovering services...
    D 13:22:38.652 gatt.discoverServices()
    D 13:22:38.662 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
    D 13:22:38.769 [Callback] Services discovered with status: 0
    I 13:22:38.769 Services discovered
    V 13:22:38.774 Generic Attribute (0x1801)
    D 13:22:38.774 gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
    D 13:22:38.776 gatt.setCharacteristicNotification(00001524-1212-efde-1523-785feabcd123, true)
    I 13:22:39.311 PHY updated (TX: LE 2M, RX: LE 2M)
    I 13:22:43.899 Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 420ms)
    V 13:22:44.693 [McuMgr] Connecting...
    D 13:22:44.697 [McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M)
    D 13:22:44.723 [McuMgr] [Callback] Connection state changed with status: 0 and new state: 2 (CONNECTED)
    I 13:22:44.726 [McuMgr] Connected to E3:A3:EA:52:01:F2
    D 13:22:44.728 [McuMgr] wait(300)
    V 13:22:45.033 [McuMgr] Discovering services...
    D 13:22:45.045 [McuMgr] gatt.discoverServices()
    I 13:22:45.058 [McuMgr] Services discovered
    V 13:22:45.064 [McuMgr] Primary service found
    V 13:22:45.070 [McuMgr] Requesting new MTU...
    D 13:22:45.075 [McuMgr] gatt.requestMtu(498)
    I 13:22:45.160 [McuMgr] MTU changed to: 498
    D 13:22:45.168 [McuMgr] gatt.setCharacteristicNotification(da2e7828-fbce-4e01-ae9e-261174997c48, true)
    V 13:22:45.179 [McuMgr] Enabling notifications for da2e7828-fbce-4e01-ae9e-261174997c48
    D 13:22:45.185 [McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00)
    I 13:22:45.341 [McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb
    V 13:22:45.350 [McuMgr] Waiting for value change...
    V 13:22:45.357 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
    D 13:22:45.362 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x000000010000FF06A0, WRITE COMMAND)
    I 13:22:45.372 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48
    I 13:22:45.433 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-19-00-00-FF-06-BF-68-62-75-66-5F-73-69-7A-65-19-09-AB-69-62-75-66-5F-63-6F-75-6E-74-04-FF
    I 13:22:45.441 [McuMgr] Wait for value changed complete
    A 13:22:45.450 [McuMgr] Received Header (Version: 0, Op: 1, Flags: 0, Len: 25, Group: 0, Seq: 255, Command: 6) CBOR {"buf_size":2475,"buf_count":4}
    I 13:22:45.467 [McuMgr] SMP reassembly supported with buffer size: 2475 bytes and count: 4
    V 13:22:45.473 [McuMgr] Requesting connection priority: HIGH (11.25–15ms, 0, 5s)...
    D 13:22:45.478 [McuMgr] gatt.requestConnectionPriority(HIGH)
    A 13:22:45.495 [McuMgr] Sending (9 bytes) Header (Version: 1, Op: 0, Flags: 0, Len: 1, Group: 0, Seq: 0, Command: 8) CBOR {}
    V 13:22:45.690 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
    D 13:22:45.701 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0800000100000008A0, WRITE COMMAND)
    I 13:22:45.716 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48
    I 13:22:45.800 Connection parameters updated (interval: 11.25ms, latency: 0, timeout: 420ms)
    I 13:22:45.807 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 09-00-00-15-00-00-00-08-BF-6A-62-6F-6F-74-6C-6F-61-64-65-72-67-4D-43-55-62-6F-6F-74-FF
    I 13:22:45.811 [McuMgr] Connection parameters updated (interval: 11.25ms, latency: 0, timeout: 420ms)
    A 13:22:45.819 [McuMgr] Received Header (Version: 1, Op: 1, Flags: 0, Len: 21, Group: 0, Seq: 0, Command: 8) CBOR {"bootloader":"MCUboot"}
    A 13:22:45.865 [McuMgr] Sending (20 bytes) Header (Version: 1, Op: 0, Flags: 0, Len: 12, Group: 0, Seq: 1, Command: 8) CBOR {"query":"mode"}
    V 13:22:45.872 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
    D 13:22:45.876 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0800000C00000108A1657175657279646D6F6465, WRITE COMMAND)
    I 13:22:45.893 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48
    I 13:22:45.893 Connection parameters updated (interval: 15.0ms, latency: 0, timeout: 5000ms)
    I 13:22:45.902 [McuMgr] Connection parameters updated (interval: 15.0ms, latency: 0, timeout: 5000ms)
    I 13:22:45.911 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 09-00-00-08-00-00-01-08-BF-64-6D-6F-64-65-03-FF
    A 13:22:45.920 [McuMgr] Received Header (Version: 1, Op: 1, Flags: 0, Len: 8, Group: 0, Seq: 1, Command: 8) CBOR {"mode":3}
    A 13:22:45.935 [McuMgr] Sending (9 bytes) Header (Version: 1, Op: 0, Flags: 0, Len: 1, Group: 1, Seq: 2, Command: 0) CBOR {}
    V 13:22:45.940 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
    D 13:22:45.942 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0800000100010200A0, WRITE COMMAND)
    I 13:22:45.962 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48
    I 13:22:45.970 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 09-00-00-86-00-01-02-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-65-33-2E-30-2E-30-64-68-61-73-68-58-20-A2-38-BF-7E-02-5E-44-EE-4A-D4-37-1A-65-A0-D8-56-75-45-FA-6F-76-08-4B-EC-DC-2F-E6-63-12-E9-73-19-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75-73-00-FF
    A 13:22:45.974 [McuMgr] Received Header (Version: 1, Op: 1, Flags: 0, Len: 134, Group: 1, Seq: 2, Command: 0) CBOR {"images":[{"slot":0,"version":"3.0.0","hash":"oji/fgJeRO5K1DcaZaDYVnVF+m92CEvs3C/mYxLpcxk=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false}],"splitStatus":0}
    V 13:22:45.987 [McuMgr] Uploading firmware...
    A 13:22:49.496 [McuMgr] 223448 bytes sent in 3417 ms (65.39 kB/s)
    V 13:22:49.546 [McuMgr] New state: TEST
    A 13:22:49.551 [McuMgr] Sending (57 bytes) Header (Version: 1, Op: 2, Flags: 0, Len: 49, Group: 1, Seq: 97, Command: 0) CBOR {"confirm":false,"hash":"l+/yJI3ZNSjN49qhsLCpe+P/1SzeC3vUtZnUCIs0b90="}
    V 13:22:49.554 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
    D 13:22:49.557 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0A00003100016100A267636F6E6669726DF46468617368582097EFF2248DD93528CDE3DAA1B0B0A97BE3FFD52CDE0B7BD4B599D4088B346FDD, WRITE COMMAND)
    I 13:22:49.566 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48
    I 13:22:49.597 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 0B-00-00-F4-00-01-61-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-65-33-2E-30-2E-30-64-68-61-73-68-58-20-A2-38-BF-7E-02-5E-44-EE-4A-D4-37-1A-65-A0-D8-56-75-45-FA-6F-76-08-4B-EC-DC-2F-E6-63-12-E9-73-19-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-BF-64-73-6C-6F-74-01-67-76-65-72-73-69-6F-6E-65-33-2E-30-2E-30-64-68-61-73-68-58-20-97-EF-F2-24-8D-D9-35-28-CD-E3-DA-A1-B0-B0-A9-7B-E3-FF-D5-2C-DE-0B-7B-D4-B5-99-D4-08-8B-34-6F-DD-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F5-69-63-6F-6E-66-69-72-6D-65-64-F4-66-61-63-74-69-76-65-F4-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75-73-00-FF
    A 13:22:49.603 [McuMgr] Received Header (Version: 1, Op: 3, Flags: 0, Len: 244, Group: 1, Seq: 97, Command: 0) CBOR {"images":[{"slot":0,"version":"3.0.0","hash":"oji/fgJeRO5K1DcaZaDYVnVF+m92CEvs3C/mYxLpcxk=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false},{"slot":1,"version":"3.0.0","hash":"l+/yJI3ZNSjN49qhsLCpe+P/1SzeC3vUtZnUCIs0b90=","bootable":true,"pending":true,"confirmed":false,"active":false,"permanent":false}],"splitStatus":0}
    V 13:22:49.615 [McuMgr] New state: RESET
    A 13:22:49.627 [McuMgr] Sending (9 bytes) Header (Version: 1, Op: 2, Flags: 0, Len: 1, Group: 0, Seq: 98, Command: 5) CBOR {}
    V 13:22:49.632 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
    D 13:22:49.635 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0A00000100006205A0, WRITE COMMAND)
    I 13:22:49.643 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48
    I 13:22:49.675 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 0B-00-00-02-00-00-62-05-BF-FF
    A 13:22:49.687 [McuMgr] Received Header (Version: 1, Op: 3, Flags: 0, Len: 2, Group: 0, Seq: 98, Command: 5) CBOR {}
    D 13:22:54.915 [Callback] Connection state changed with status: 8 and new state: DISCONNECTED (0)
    E 13:22:54.915 Error 8 (0x8): GATT CONN TIMEOUT
    I 13:22:54.916 Disconnected
    D 13:22:54.917 [McuMgr] [Callback] Connection state changed with status: 8 and new state: 0 (DISCONNECTED)
    W 13:22:54.935 [McuMgr] Error: (0x8): GATT CONN TIMEOUT
    I 13:22:54.941 [McuMgr] Disconnected
    D 13:22:54.956 [McuMgr] gatt.close()
    D 13:22:54.968 [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
    V 13:22:59.716 [McuMgr] Connecting...
    D 13:22:59.727 [McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M)
    V 13:22:59.742 [McuMgr] New state: CONFIRM
  • More testing results:
    The nRF54L15 FOTA doesn't work on three Android phones, two of them are Google Pixel; but an iPhone works with the same setting and builds.
    All Android works on nRF52840.
    I just tried the sample from the exercise, and I observed a similar behavior, like an unknown state in the Device Manager app. Though the app threw this error, my DFU process still worked.
    I also tried the nRF Connect app using a Google Pixel 7 (Android 15) and didn't encounter any issues.
    Yes, that is the correct method to collect logs from the nRF Connect app, but the logs I mentioned refer to the nRF device (nRF54L15 in this case) to check if anything is going wrong there.
    I will inquire internally about the error message from the Device Manager app.
    Kind Regards,
    Abhijith
