I am using nRF Connect SDK v2.9.0. While working on the nRF52840 board, I used sys_poweroff() to put the board in deep sleep mode. But before calling it, I called
Yes, I added it in the prj.conf file. But the system_off sample I used is from nrf/samples/nfc/system_off/
I will try another system_off sample now
Einar Thorsrud The example in zephyr/samples/boards/nordic/system_off/ worked for me. But I need to know what the difference is between nrf_power_rampower_mask_on and the code in the example. Are they both used to keep the RAM content in Deep Sleep mode?
The nrf_power_rampower_mask_on() function is more low level and is used under the hood. The method demonstrated in the System OFF sample is using the Zephyr APIs. The retained region is specified in the devicetree (see the overlay file for the board under "boards", where yuo have this for the nRF54L15 DK:
cpuapp_sram@2002e000 {
compatible = "zephyr,memory-region", "mmio-sram";
reg = <0x2002e000 DT_SIZE_K(4)>;
zephyr,memory-region = "RetainedMem";
status = "okay";
retainedmem0: retainedmem {
compatible = "zephyr,retained-ram";
status = "okay";
aliases {
retainedmemdevice = &retainedmem0;
&cpuapp_sram {
/* Shrink SRAM size to avoid overlap with retained memory region */
reg = <0x20000000 DT_SIZE_K(184)>;
ranges = <0x0 0x20000000 0x2e000>;
This is the recommende approach.
If you are interested, you can follow this further down by inspecting code or debugging, and then you should see that then the implementation for nrf for the Zephyr retained mem driver in zephyr/drivers/retained_mem/retained_mem_nrf_ram_ctrl.c is used, and this calls nrfx_ram_ctrl_retention_enable_set(). In there, you can see that a function pointer to ram_ctrl_block_section_retention_enable_set() is passed to ram_ctrl_block_section_iterate(), and within nrfx_ram_ctrl_section_retention_mask_enable_set(), nrf_power_rampower_mask_on() is called.
OK, thank you for this information.
But I have another question, please, if I need to implement a function that enters the system in sleep mode, is there any way rather than calling k_sleep(K_FOREVER);
By sleep, do you mean system OFF sleep mode (where wakeup is in form of a reset), normal system ON sleep mode?
System On sleep is auomatically entered by the Zephyr idle thread, whenever there is no work to be done. That is for instance if all threads call k_sleep or are waiting for something.
For system off you can call sys_poweroff() as is demonstrated in the system off sample you have been looking at.
