Error to use RTT and Debug
While using nRF Connect, I encountered an error when attempting to enter Debug mode with RTT active. Here are my J-Link specifications and log details:
My Jlink especifications:
Application log started
- J-Flash V8.12 (J-Flash compiled Dec 18 2024 15:44:37)
- JLinkARM.dll V8.12 (DLL compiled Dec 18 2024 15:43:28)
Reading flash device list [/home/santos/Documents/JLink/ETC/JFlash/Flash.csv] ...
- List of flash devices read successfully (225 Devices)
Reading MCU device list ...
- List of MCU devices read successfully (11667 Devices)
When I have an RTT session open and then attempt to switch to Debug mode in nRF Connect, an error occurs. Any suggestions on how to resolve this issue?
-- west flash: rebuilding
[0/5] Performing build step for 'nrfconnect'
ninja: no work to do.
[2/5] No install step for 'nrfconnect'
[3/5] Completed 'nrfconnect'
[4/5] cd /home/santos/Documents/nrfconnect/build/_sysbuild && /home/santos/ncs/toolchains/b77d8c1312/usr/local/bin/cmake -E true
-- west flash: using runner nrfjprog
-- runners.nrfjprog: reset after flashing requested
-- runners.nrfjprog: Flashing file: /home/santos/Documents/nrfconnect/build/merged.hex
[error] [  JLink] - Failed to initialize CPU module in firmware because probe is low on memory (heap).
[error] [ Client] - Encountered error -11: Command read_device_info executed for 596 milliseconds with result -11
[error] [ Worker] - Could not connect to CPU core. This may indicate that AP protection is enabled.
Emulator does not have enough memory to perform the requested operation.
[error] [ Client] - Encountered error -104: Command read_memory_descriptors executed for 14 milliseconds with result -104
Failed to read device memories.
[error] [  nRF52] - Device memory generation failed.
[error] [ Worker] - JLinkARM.dll ReadMemU32 detected a read error 1.
 This typically indicates the read was blocked by a memory protection mechanism.
ERROR: nrfjprog failed for an unknown reason. Run the same command again with
ERROR: argument --log, contact Nordic Semiconductor and provide the generated
ERROR: log.log file to them.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
FATAL ERROR: command exited with status 65: nrfjprog --program /home/santos/Documents/nrfconnect/build/merged.hex --sectoranduicrerase --verify -f NRF52 --snr 805251123
 *  The terminal process terminated with exit code: 65.
My prj.conf
# Enable logging and RTT DEBUG output
CONFIG_LOG=y
CONFIG_LOG_MODE_IMMEDIATE=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=1
CONFIG_LOG_PRINTK=y
CONFIG_LOG_MODE_DEFERRED=n
CONFIG_UART_CONSOLE=n
# Hardware info
CONFIG_HWINFO=y
# Debug
CONFIG_DEBUG_THREAD_INFO=y
CONFIG_DEBUG_OPTIMIZATIONS=y
CONFIG_LOG=y
CONFIG_LOG_PRINTK=y
# LVGL
CONFIG_LV_Z_MEM_POOL_SIZE=16384
CONFIG_LV_Z_SHELL=y
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_DISPLAY=y
CONFIG_DISPLAY_LOG_LEVEL_ERR=y
CONFIG_LOG=y
CONFIG_SHELL=y
CONFIG_LVGL=y
CONFIG_LV_USE_LOG=y
CONFIG_LV_USE_LABEL=y
CONFIG_LV_USE_ARC=y
CONFIG_LV_USE_MONKEY=y
CONFIG_LV_FONT_MONTSERRAT_14=y
CONFIG_LV_LOG_LEVEL_TRACE=y
CONFIG_LV_LOG_LEVEL_INFO=y
CONFIG_LV_LOG_LEVEL_WARN=y
CONFIG_LV_LOG_LEVEL_ERROR=y
CONFIG_LV_LOG_PRINTF=y
CONFIG_ST7789V=y
CONFIG_PRINTK=y
# Debug
CONFIG_DEBUG=y
# MIPI
CONFIG_MIPI_DBI=y
CONFIG_PWM=y
CONFIG_LED=y
CONFIG_GPIO=y
# SPI
CONFIG_SPI=y
CONFIG_SPI_NRFX=y
CONFIG_NRF_APPROTECT_LOCK=n
CONFIG_TRUSTED_EXECUTION_NONSECURE=y
CONFIG_NEWLIB_LIBC=y
CONFIG_LOG_BACKEND_UART=n
    Since both RTT and the debugger use Serial Wire Debug, there could be conflicts when accessing the same resources simultaneously. While checking the logs you shared, please verify if APP protection is enabled and causing the issue. Try performing a full chip erase, and does disabling RTT resolve your issue?
    Kind Regards,
    Abhijith
