I am using a customized PCB (nrf52840) and I have been successfully set up the SPI communication in between the nrf and lsm6dso
I used 0.11 as clk , 0.27 as MISO and 0.25 as MOSI , I have attached the code i used in the overlay file, and it was working
&spi0{
compatible = "nordic,nrf-spi";
status = "okay";
// cs-gpios = < &gpio0 13 GPIO_ACTIVE_LOW>;
pinctrl-0 = <&spi0_default>;
pinctrl-1 = <&spi0_sleep>;
pinctrl-names = "default","sleep";
&spi1{
status = "okay";
// cs-gpios = < &gpio0 4 GPIO_ACTIVE_LOW>;
pinctrl-0 = <&spi1_default>;
pinctrl-1 = <&spi1_sleep>;
&pinctrl {
spi0_default: spi0_default {
group1{
psels = <NRF_PSEL(SPIM_SCK, 0, 11)>,
<NRF_PSEL(SPIM_MISO, 0, 27)>,
<NRF_PSEL(SPIM_MOSI, 0, 25)>;
spi0_sleep: spi0_sleep {
group1{
spi1_default: spi1_default {
group1{
psels = <NRF_PSEL(SPIM_SCK, 0, 6)>,
<NRF_PSEL(SPIM_MISO, 0, 8)>,
<NRF_PSEL(SPIM_MOSI, 0, 7)>;
spi1_sleep: spi1_sleep {
group1{
However, when I modify my PCB and change to the following list of pins , it stops working , and gives 0xFF
0.11 as clk, 0.7 as MISO , 0.25 as MOSI
Any pin that I should not use or need to have additional setup ?
&spi0{
status = "okay";
&pinctrl {
group1{
<NRF_PSEL(SPIM_MISO, 0, 7)>,
group1{
I am using nRF Connect SDK v2.5.2
2. Another question that I asked before and is solved by I did not get the reason, hope to clarify again
user_dbg_pin: user-dbg-pin {
compatible = "nordic,gpio-pins";
gpios = <&gpio0 8 GPIO_ACTIVE_HIGH>;
status = "okay";
&gpio0 {
status = "okay";
// &gpiote0 {
// status = "okay";
I used the above way to pull up P0.08 but the gpiote0 set up does not work. and I commented it out and it works.
undefined node label 'gpiote0'
in which case I can use the set up below to turn on P0.08
#define MY_GPIO0 DT_NODELABEL(gpio0)
#define MY_GPIO1 DT_NODELABEL(gpio1)
gpio_pin_configure(gpio0_dev, GPIO_0_CS, GPIO_OUTPUT);
gpio_pin_configure(gpio1_dev, GPIO_1_INT1, GPIO_OUTPUT);
// gpio_pin_set(gpio0_dev, GPIO_0_CS, 1);
gpio_pin_set(gpio1_dev, GPIO_1_INT1, 0);
