BT shell - board resources used
Hello
I started developing a BT shell based app on the nRf52840DK board and then moved to a custom board.
In the overlay file, I've deleted every nRf52840DK node I could think of (except of UART0) to prevent contention with the board's peripherals.
Still, I see gpios toggling 'on their own'.
My question is - what HW resources does the BT shell uses (other than UART0) and how to disable these?
Thanks
    This sample does not configure any GPIOs or peripherals that will toggle any output signa as far as I can tell(apart from the UART of course). You could check the generated zephyr.dts file for your application to confirm that the nodes are deleted, but I don't see any nodes that would have to be disabled or removed. Which GPIOS are you seeing this on? Did you check the signal wilth a scope or logic analyzer?
    Vidar
