hci_lpuart - v290 - 91x - RAM overflowed
hci_lpuart builds fine in VS v290 with thingy91/nrf52840.
If trying with thingy91x/nrf5340/cpuapp/ns,
build is going ok until the very end when RAM overflowed message stops the build,
region `RAM' overflowed by 267184 bytes
collect2: error: ld returned 1 exit status
This case mentions Case ID's of ongoing hci_lpuart issues, maybe its 91x:
339543
338886
(not sure how to search for Case ID, in search box or by URL string)
The docs for hci_lpuart mentions thingy91, maybe ok for 91x too.
thank-you,
    Yes, it should work for the Thingy:91x as well.
    I also see this issue, but building for thingy91x/nrf5340/cpuapp does not give this issue. You should be able to use this build for the nRF5340 on the Thingy:91x. Did you try this? I did not test on my side unfortunately.
    The cases that are mentioned in this ticket are private tickets from the same customer.
    Øyvind
  • I did try thingy91x/nrf5340/cpuapp, but this would have led to my next case.
    Was looking at keeping these two issues separate.
    Once the non ns hci_lpuart sysbuild is compiled and in the process of being flashed from VS,
    nrfutil not found error comes up,
    -- west flash: using runner nrfutil
    -- runners.nrfutil: mass erase requested
    -- runners.nrfutil: reset after flashing requested
    FATAL ERROR: required program nrfutil not found; install it or add its location to PATH
    Tried flashing 91x on VS Win11 and Ubuntu 24.04.2 LTS and same nrfutil result.
    If you then try to flash nrf9160-dk or thingy:91 on VS, no issues with nrfutil and flashing is normal.
    Tried also with blinky, wifi_scan, lte_ble_gateway sysbuild for 91x and all end up with nrfutil not found.
    thank-you,
    Have you installed nrfutil on your computer? nrfjprog is officially deprecated and is being replaced by nRF Util.
    Please download and retry.
    Øyvind
  • Now when trying to flash non ns thingy91x/nrf5340/cpuapp sysbuild on VS v290 and switch set to nrf53,
    -- runners.nrfutil: Flashing file: /home/simon/ncs_apps/hci_lpuart-91x-v290/build_3a/merged_CPUNET.hex
    -- runners.nrfutil: Erasing flash and UICR
    -- runners.nrfutil: Programming image
    Error: One or more batch tasks failed:
     * 960023012: [Probe] Device error: Memory access error at 0x01008800. Probably a memory protection issue. Probe access is Secure (Generic)
    FATAL ERROR: command exited with status 1: nrfutil --json device x-execute-batch --batch-path /home/simon/ncs_apps/hci_lpuart-91x-v290/build_3a/generated_nrfutil_batch.json --serial-number 960023012
     *  The terminal process terminated with exit code: 1.
     *  Terminal will be reused by tasks, press any key to close it
    Gave a try using v3.0.0-preview1 thingy91x/nrf5340/cpuapp/ns, and same ram overflowed.
    /home/simon/ncs/toolchains/aedb4c0245/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/zephyr_pre0.elf section `bss' will not fit in region `RAM'
    /home/simon/ncs/toolchains/aedb4c0245/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: region `RAM' overflowed by 267168 bytes
    thank-you,
    I see from the board files, particularly the file:
    NCS v2.9.0\nrf\boards\nordic\thingy91x\board.cmake
    Line 8-12 should be:
    elseif(CONFIG_BOARD_THINGY91X_NRF5340_CPUAPP OR CONFIG_BOARD_THINGY91X_NRF5340_CPUAPP_NS)
      board_runner_args(nrfjprog)
      board_runner_args(nrfutil "--nrf-family=NRF53")
      board_runner_args(jlink "--device=nrf5340_xxaa_app" "--speed=4000")
    elseif(CONFIG_BOARD_THINGY91X_NRF5340_CPUNET)
    Note that there are two corrections on line 8.
    Try this, and see if it helps.
    Edvin
