Im having problems running DFU serial examples.
i use one of the examples of the SDK but it seems like board doesnt leave the bootloader mode and memory value doesnt change. im using the dfu_test_softdevice_b.zip package to upload.
im using Linux OS
im using Linux OS
Unfortunately, the bootlaoder doesn't appear to work when built with GCC in this alpha release. Please try with the attached bootloader that I built with ARMCC and see if you get the same result.
I was able to make it work with the Keil compiled version. Here are the command line arguments I used:
vidar@ubuntu:~/nrfutil/pc-nrfutil/nordicsemi$ sudo python __main__.py dfu serial -p
/dev/ttyACM0
-pkg /home/vidar/SDK/nRF5_SDK_11.0.0-
2.alpha_bc3f6a0/examples/dfu/hci_dfu_send_hex/test_images_dual_bank_update_nrf52/dfu_test_app_hrm_s132.zip
Bootloader : nrf52832_xxaa.hex
I'm having the same issue both with the hex file you provided and the gcc build from NRF5_SDK 11.
I'm on OSX using nrfutil v0.3.0
$ nrfutil version
nrfutil version 0.3.0
$ nrfjprog --family nrf52 --program ~/Downloads/nrf52832_xxaa.hex --chiperase
Parsing hex file.
Erasing code and UICR flash areas.
Applying system reset.
Checking that the area to write is not protected.
Programing device.
$ nrfjprog --family nrf52 --reset
Run.
$ nrfutil dfu serial -p /dev/tty.usbmodem14121 -pkg ~/Downloads/nrf5_sdk/examples/dfu/hci_dfu_send_hex/test_images_dual_bank_update_nrf52/dfu_test_app_hrm_s132.zip
Upgrading target on /dev/tty.usbmodem14121 with DFU package /Users/justin/Downloads/nrf5_sdk/examples/dfu/hci_dfu_send_hex/test_images_dual_bank_update_nrf52/dfu_test_app_hrm_s132.zip. Flow control is disabled.
[------------------------------------] 0%Timed out waiting for acknowledgement from device.
Failed to upgrade target. Error is: No data received on serial port. Not able to proceed.
Possible causes:
- bootloader, SoftDevice or application on target does not match the requirements in the DFU package.
- baud rate or flow control is not the same as in the target bootloader.
- target is not in DFU mode. If using the SDK examples, press Button 4 and RESET and release both to enter DFU mode.
Try to replace the '--chiperase' option with '--sectorerase'. Otherwise the softdevice will be erased from the device. You need both softdevice and bootloader for DFU to work.
I tried again still no luck:
$ nrfjprog --family nrf52 --program s132_nrf52_2.0.0-7.alpha_softdevice.hex --chiperase
$ nrfjprog --family nrf52 --program ~/Downloads/nrf52832_xxaa.hex --sectorerase
$ nrfutil dfu serial -p /dev/tty.usbmodem14121 -pkg ~/Downloads/nRF5_SDK_11.0.0-2.alpha_bc3f6a0/examples/dfu/hci_dfu_send_hex/test_images_dual_bank_update_nrf52/dfu_test_app_hrm_s132.zip
