KMU import ECDSA public key
Hi Nordic Team,
in our project we want to write/read cryptographic keys to/from the KMU.
One of the algorithms we are going to use is ECDSA.
My naive approach was to just modify the existing nrf/samples/crypto/ecdsa code.
Another ticket in the developer zone (see https://devzone.nordicsemi.com/f/nordic-q-a/118434/kmu-psa-persistent-key-generation) reveals, that there's a bug in SDK v2.9.0.
Therefore, I switched ncs to the main branch (commit a95e127c906afef92e36e79120d2ec127c250b87).
My prj.conf equals:
# Copyright (c) 2024 Nordic Semiconductor ASA
# The Zephyr CMSIS emulation assumes that ticks are ms, currently
CONFIG_SYS_CLOCK_TICKS_PER_SEC=1000
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_HEAP_MEM_POOL_SIZE=4096
CONFIG_REBOOT=y
# Enable logging
CONFIG_CONSOLE=y
CONFIG_LOG=y
# Enable nordic security backend and PSA APIs
CONFIG_NRF_SECURITY=y
CONFIG_MBEDTLS_PSA_CRYPTO_C=y
# Enable persistent storage APIs
CONFIG_MBEDTLS_PSA_CRYPTO_STORAGE_C=y
# Mbedtls configuration
CONFIG_MBEDTLS_ENABLE_HEAP=y
CONFIG_MBEDTLS_HEAP_SIZE=8192
# Using hardware crypto accelerator
CONFIG_PSA_CRYPTO_DRIVER_OBERON=n
CONFIG_PSA_CRYPTO_DRIVER_CRACEN=y
CONFIG_PSA_WANT_GENERATE_RANDOM=y
# ECDSA support
CONFIG_PSA_WANT_ALG_ECDSA=y
CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_GENERATE=y
CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_IMPORT=y
CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_EXPORT=y
CONFIG_PSA_WANT_ECC_SECP_R1_256=y
CONFIG_PSA_WANT_ALG_SHA_256=y
# Use TRUSTED_STORAGE because this is a non-TF-M board target.
CONFIG_TRUSTED_STORAGE=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_ZMS=y
CONFIG_SETTINGS=y
CONFIG_DEBUG=y
 My modified generate_ecdsa_keypair() succeeds to generate a new keypair in the KMU resp. read an existing keypair from the KMU:
int generate_ecdsa_keypair(void)
    psa_status_t status;
    size_t olen;
    LOG_INF("Generating/read random persistent ECDSA key pair...");
    /* Configure the key attributes */
    psa_key_attributes_t key_attributes = PSA_KEY_ATTRIBUTES_INIT;
    psa_set_key_usage_flags(&key_attributes, PSA_KEY_USAGE_SIGN_HASH | PSA_KEY_USAGE_SIGN_MESSAGE);
    psa_set_key_algorithm(&key_attributes, PSA_ALG_ECDSA(PSA_ALG_ANY_HASH));
    psa_set_key_type(&key_attributes, PSA_KEY_TYPE_ECC_KEY_PAIR(PSA_ECC_FAMILY_SECP_R1));
    psa_set_key_bits(&key_attributes, 256);
    psa_set_key_lifetime(
        &key_attributes,
        PSA_KEY_LIFETIME_FROM_PERSISTENCE_AND_LOCATION(
            PSA_KEY_PERSISTENCE_DEFAULT,
            PSA_KEY_LOCATION_CRACEN_KMU
    psa_set_key_id(
        &key_attributes,
        PSA_KEY_HANDLE_FROM_CRACEN_KMU_SLOT(
            CRACEN_KMU_KEY_USAGE_SCHEME_RAW,
            8
    status = psa_generate_key(&key_attributes, &ecdsa_keypair_id);
    if(status == PSA_SUCCESS) {
        // nothing to do
    else if(status == PSA_ERROR_ALREADY_EXISTS) {
        LOG_INF("ECDSA keypair already exists!");
        ecdsa_keypair_id = PSA_KEY_HANDLE_FROM_CRACEN_KMU_SLOT(CRACEN_KMU_KEY_USAGE_SCHEME_RAW, 8);
    else {
        LOG_INF("psa_generate_key failed! (Error: %d)", status);
        return APP_ERROR;
    /* Export the public ECDSA key */
    status = psa_export_public_key(ecdsa_keypair_id, m_ecdsa_pub_key, sizeof(m_ecdsa_pub_key), &olen);
    if(status != PSA_SUCCESS) {
        LOG_INF("failed to export ECDSA public key (Error: %d)", status);
        return APP_ERROR;
    PRINT_HEX("ECDSA pub key", m_ecdsa_pub_key, sizeof(m_ecdsa_pub_key));
    /* After the key handle is acquired the attributes are not needed */
    psa_reset_key_attributes(&key_attributes);
    LOG_INF("ECDSA keypair generated/read successfully!");
    return APP_SUCCESS;
But my modified import_ecdsa_pub_key() function fails:
int import_ecdsa_pub_key(void)
	psa_set_key_usage_flags(&key_attributes, PSA_KEY_USAGE_VERIFY_HASH | PSA_KEY_USAGE_VERIFY_MESSAGE);
	    &key_attributes,
	psa_set_key_type(&key_attributes, PSA_KEY_TYPE_ECC_PUBLIC_KEY(PSA_ECC_FAMILY_SECP_R1));
    psa_set_key_id(
        &key_attributes,
            8
	status = psa_import_key(&key_attributes, m_ecdsa_pub_key, sizeof(m_ecdsa_pub_key), &ecdsa_pub_key_id);
	if (status != PSA_SUCCESS) {
		LOG_INF("psa_import_key failed! (Error: %d)", status);
		return APP_ERROR;
	/* Reset key attributes and free any allocated resources. */
	return APP_SUCCESS;
psa_import_key() returns PSA_ERROR_INVALID_ARGUMENT.
The error code comes from nrf/subsys/nrf_security/src/drivers/cracen/cracenpsa/src/kmu.c:837ff
case CRACEN_KMU_KEY_USAGE_SCHEME_RAW:
		push_address = (uint8_t *)kmu_push_area;
		if (key_buffer_size != 16 && key_buffer_size != 24 && key_buffer_size != 32) {
			return PSA_ERROR_INVALID_ARGUMENT;
The buffer size for the ECDSA public key (i.e. m_ecdsa_pub_key) is 65 bytes.
Am I doing something wrong?
Christian
