app_timer_start in radio notification event handler
I have tried to create delay_timer function using app_uart as nrf_delay replacement in order to save power as much as possible in a short delay existed in any part of my code. (similar to this)
APP_TIMER_DEF(m_delay_timer_id);
then call timers_init in the beginning of main code just after ble_stack_init() enabling lfclk.
void timers_init(void)
    // Initialize timer module.
    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
    enter code here
    // Create timers.
    uint32_t err_code;
    err_code = app_timer_create(&m_meas_timer_id, APP_TIMER_MODE_REPEATED, meas_timer_timeout_handler);
    err_code = app_timer_create(&m_led_timer_id, APP_TIMER_MODE_REPEATED, led_timer_timeout_handler);
	err_code = app_timer_create(&m_delay_timer_id, APP_TIMER_MODE_SINGLE_SHOT, delay_timer_timeout_handler);
in timeout handler (timer callback), just simply changing flag state.
void delay_timer_timeout_handler(void * p_context)
    delay_flag = false;
And, delay_timer() execute the delay in millisecond.
void delay_timer (uint32_t time)
    uint32_t err_code;
    delay_flag = true;
    err_code = app_timer_start(m_delay_timer_id, APP_TIMER_TICKS(time, APP_TIMER_PRESCALER), NULL);
    while (delay_flag)
        err_code = sd_app_evt_wait();
This code is perfectly working if I call delay_timer somewhere in main code.
However, if I called delay_timer() from the radio notification event handler, delay_timer_timeout_handler was never called, and could not exit from while loop since the state of delay_flag was never changed.
// Radio notification initialize.
    err_code = ble_radio_notification_init(NRF_APP_PRIORITY_LOW, NRF_RADIO_NOTIFICATION_DISTANCE_800US, meas_update);
void meas_update(bool radio_active)
    if (radio_active) {
    	// Do something
    led_on(PIN_LED_GREEN);
    delay_timer(30);
    led_off(PIN_LED_GREEN);
Are there any difference in calling app_timer_start in main code and radio_notification event handler? I need help to solve this issue. Or any good suggestion on how to get the device in low power state while in the short delay (such as 30ms) instead of using nrf_delay?
I am using S110, SDK10 on nrf51822.
