Issue Integrating Mesh with Broadcast Source and Central & Peripheral HR on nRF5340
I am working on an nRF5340-based project where I successfully integrated the broadcast_source and central_and_peripheral_hr examples from SDK 2.6.0. Both functionalities are working correctly. However, when I try to add the mesh functionality, I encounter the following error:
[00:00:00.710,754] bt_hci_core: opcode 0x2036 status 0x07
[00:00:00.710,784] bt_mesh_pb_adv: Failed enabling advertiser
[00:00:00.710,845] bt_mesh_adv_ext: Mesh advertiser not enabled
I am using SDK 2.6.0 because SDK 2.9.0 did not work correctly with the broadcast_source example.
Additionally, I noticed that in the mesh_light_switch example, ipc_radio is used in the core network, whereas in the other examples, hci_ipc is used instead. Could this be a potential cause of the issue? If so, what would be the recommended approach to align these components correctly?
Do I need to make any specific configurations or modifications to enable the mesh advertiser properly in this context?
Thanks in advance for your support!
UPDATE
I have identified that the opcode 0x2036 - 0x07 error was caused by a lack of resources for ext advertise. I noticed that it was using hci_ipc (still on SDK version 2.6.0), so I modified the sysbuild.cmake to use the configuration file nrf5340_cpunet_bt_mesh-bt_ll_sw_split.conf (instead of nrf5340_cpunet_iso-bt_ll_sw_split.conf), adding:
CONFIG_BT_EXT_ADV_MAX_ADV_SET=10
With this configuration, the previous error disappeared. However, I am now encountering a new issue:
[00:00:00.681,488] <inf> bt_mesh_provisionee: Device UUID: 11bcda3f-1161-448b-ae43-25c0ee9e4b74
Mesh initialized
Failed to set periodic advertising parameters (err -134)
Do you have any insights on what might be causing this new error?
Thanks
    If your Bluetooth mesh device running as an ADV-bearer with BIS, Please be aware that Bluetooth mesh is not based on a synchronization mechanism, which means there could be packets from other devices at any time. That's why the RX window is turned on all the time from a normal mesh node. Therefore, the collision between BIS ISO and mesh packets would be expected and cause the audio quality to be poor, or cannot receive every packet from the mesh network.
    Do you mean the applications/nrf5340_audio/broadcast_source? Usually, I would suggest using the latest version to get better support. You could raise a new support case for v2.9.0 Audio issues.
    Since nRF Connect SDK v2.7.0, the nRF Bluetooth and mesh samples previously used the HCI IPC (also known as hci_ipc) radio core firmware, which has been updated to use the IPC radio firmware.
    This change is part of an effort to standardize the radio core firmware across different types of samples. The IPC radio firmware (ipc_radio) is a more versatile solution that can support multiple protocols, including Bluetooth and IEEE 802.15.4.
    Try to increase CONFIG_BT_CTLR_ADV_DATA_LEN_MAX. You could also refer to nrf5340_cpunet_iso-bt_ll_sw_split.conf. It might help.
    Amanda H.
    First of all, thank you for your previous response!
    I have a question regarding the core network configuration for hci_ipc. Why are there multiple configuration files available? Specifically, what is the difference between nrf5340_cpunet_bt_mesh-bt_ll_sw_split.conf and nrf5340_cpunet_iso-bt_ll_sw_split.conf? When should each one be used, and how do we specify which one to use?
    Additionally, I have fixed the previous errors by adding the following missing configurations in mesh.conf:
    CONFIG_BT_PER_ADV=y
    CONFIG_BT_BUF_ACL_RX_SIZE=251
    CONFIG_BT_BUF_ACL_TX_SIZE=251
    CONFIG_BT_PER_ADV_RSP=y
    CONFIG_BT_CTLR_ADV_EXT=y
    CONFIG_BT_CTLR_ADV_DATA_CHAIN=y
    CONFIG_BT_CTLR_ADV_DATA_LEN_MAX=191
    CONFIG_BT_CTLR_SCAN_DATA_LEN_MAX=191
    CONFIG_BT_CTLR_ADV_ISO=y
    These additional configurations have resolved all the previous issues. However, I am now encountering a new error:
    [00:00:00.721,801] <wrn> bt_hci_core: opcode 0x2068 status 0x07
    Unable to start broadcast source: -5
    Do you have any insights into what might be causing this new error? This is related to
    SDC_HCI_OPCODE_CMD_LE_CREATE_BIG with memory issue i think (on network core I presume).
    Thanks for your support
    UPDATE
    From previous conf file I also added and changed the following params but the issue is still there.
    CONFIG_BT_CTLR_ADVANCED_FEATURES=y
    CONFIG_BT_CTLR_ADV_DATA_LEN_MAX=750
    CONFIG_BT_CTLR_SCAN_DATA_LEN_MAX=750
    It's still something related to network core I think (ipc_hci fw)
    The multiple configuration files available for the network core are designed to support different features and use cases, such as using the Zephyr Bluetooth LE Controller. (indicated by the "bt_ll_sw_split" part of the filename).
     If you are using the nrf5340_cpunet_bt_mesh-bt_ll_sw_split.conf or nrf5340_cpunet_iso-bt_ll_sw_split.conf, both are enabled with the Zephyr Bluetooth LE Controller. Why would you think that related to SDC_HCI_OPCODE_CMD_LE_CREATE_BIG, which is the Softdevice controller API?
    error -5 is EIO, meaning I/O error. Please check and ensure that you're calling the broadcast start function correctly.
    The issue -5 (aka EIO) is after a core log message [00:00:00.721,801] <wrn> bt_hci_core: opcode 0x2068 status 0x07 that means SDC_HCI_OPCODE_CMD_LE_CREATE_BIG with memory allocation issue. I think that -5 is related to the previous memory error. Additionally that error code (SDC_HCI_OPCODE_CMD_LE_CREATE_BIG) is an standard error code provided by BT specification and it is not just related to Softdevice or Zephyr Controller; is my assumption correct?
    As far as I understood this is the main issue here. I saw these type of logs when something on network core is not "working as expected" and this is why I have to change *.conf file in network core in the hci_ipc project.
    About that: when do I need to use one of them? I mean, is it correct select nrf5340_cpunet_bt_mesh-bt_ll_sw_split.conf to use mesh functionalities or is not necessary? Can the SoftDevice controller be used for Mesh features just like the Zephyr one?
    Thanks for your support.
    opcode 0x2068 is BT_HCI_OP_LE_CREATE_BIG, and the status code can be found in the specification. See Vol. 1, Part F, Chapter 2.
    Are you using the nrf/applications/nrf5340_audio/broadcast_source or zephyrsamples/bluetooth/broadcast_audio_source? If it's broadcast_audio_source, you can refer to overlay-bt_ll_sw_split.conf to adjust the configurations.
    Do you get the same issue with nrf5340_cpunet_iso-bt_ll_sw_split.conf? If not, you refer to it to see what is missing.
    In the NCS Bluetooth Mesh samples, the SoftDevice controller is used as the default for Mesh samples. You can use child_image/hci_ipc.conf to adjust the configs for /hci_ipc such as this example. Of course, you could use the Zephyr Bluetooth LE Controller if you want. but I usually suggest using the SoftDevice controller if you want to use the QDID for certification.
    -Amanda H.
