In SDK v2.6.1, commenting out the following code in websocket.c allows successful connection to the WebSocket. However, in SDK v2.7.0, even after commenting out the same code, I am still unable to connect to the WebSocket.
Are you using an SDK sample, or is it a custom project?
Please share the device logs.
I recommend fixing the issue causing the WebSocket handshake to fail rather than commenting out the check.
Marte
Please share the full logs from the device.
Marte
[00:00:00.502,746] <inf> fs_nvs: 2 Sectors of 4096 bytes
[00:00:00.502,746] <inf> fs_nvs: alloc wra: 0, fd0
[00:00:00.502,777] <inf> fs_nvs: data wra: 0, c8
*** Booting nRF Connect SDK v3.5.99-ncs1-1 ***
[00:00:02.055,969] <inf> wifi_mgmt_ext: Connection requested
[00:00:02.056,732] <inf> Lesson5_Exercise1: Connecting to Wi-Fi
[00:00:04.606,048] <inf> wifi_mgmt_ext: Connection requested
[00:00:07.159,393] <inf> wifi_mgmt_ext: Connection requested
[00:00:09.713,409] <inf> wifi_mgmt_ext: Connection requested
[00:00:12.267,883] <inf> wifi_mgmt_ext: Connection requested
[00:00:14.834,533] <inf> wifi_mgmt_ext: Connection requested
[00:00:17.400,695] <inf> wifi_mgmt_ext: Connection requested
[00:00:19.947,631] <inf> wifi_mgmt_ext: Connection requested
[00:00:22.501,220] <inf> wifi_mgmt_ext: Connection requested
[00:00:25.055,206] <inf> wifi_mgmt_ext: Connection requested
[00:00:27.609,893] <inf> wifi_mgmt_ext: Connection requested
[00:00:30.181,518] <inf> wifi_mgmt_ext: Connection requested
[00:00:30.264,404] <inf> Lesson5_Exercise1: Network connected
[00:00:32.203,094] <inf> Lesson5_Exercise1: IPv4 address of HTTP server found 54.240.174.114
[00:00:33.456,909] <inf> Lesson5_Exercise1: Connected to server
[00:00:33.456,939] <inf> Lesson5_Exercise1: HTTP POST request
[00:00:33.571,350] <inf> Lesson5_Exercise1: Response status: Created
[00:00:33.571,380] <inf> Lesson5_Exercise1: Successfully acquired client ID: /fb269045-2f73-4068-8064-b227e8a6cf70
[00:00:33.571,411] <inf> Lesson5_Exercise1: Closing socket: 9
[00:00:36.434,722] <err> Lesson5_Exercise1: Cannot connect to IPv4 remote (-116)
[00:00:36.435,150] <err> Lesson5_Exercise1: Cannot connect to echo.thingy.rocks:80
[00:00:36.435,241] <err> Lesson5_Exercise1: No IPv4 or IPv6 connectivity
You connect to echo.thingy.rocks and not a dedicated websocket. Have you tried connecting to a server using websocket instead?
Is there a reason you want to use a websocket instead of a regular socket?
Marte
