TLS handshake fails with Alert (Level: Fatal, Description: Unknown CA):
It seems I cannot post a full explanation of context so here is the short version. Ill add detail after.
Devices in field all suddenly unable to connect to GCP host.
Problem simplified to https_client sample with url changed to run.app and certificate changed to WR2.
Modem trace shows handshake terminating with TLSv1.2 Record Layer: Alert (Level: Fatal, Description: Unknown CA)
Given that I can connect with the same certificate and cipher using curl. Is this a bug? How should I proceed?
  • Here is the curl line:
    curl -v --tlsv1.2 --ciphers ECDHE-ECDSA-AES128-GCM-SHA256 --cacert wr2.pem --request POST --data 'test' https://run.app/
    The certificate is here (It seems I cannot attach it):
    https://i.pki.goog/wr2.pem
    I downloaded wr2.pem from here:
    https://pki.goog/repository/
    Did a quickfix to avoid changing main.c:
    diff --git a/samples/net/https_client/CMakeLists.txt b/samples/net/https_client/CMakeLists.txt
    index 2a937786ed..975b511569 100644
    --- a/samples/net/https_client/CMakeLists.txt
    +++ b/samples/net/https_client/CMakeLists.txt
    @@ -14,7 +14,7 @@ set(gen_dir ${CMAKE_CURRENT_BINARY_DIR}/certs)
     zephyr_include_directories(${gen_dir})
     generate_inc_file_for_target(
         app
    -    cert/DigiCertGlobalG2.pem
    +    cert/wr2.pem
         ${gen_dir}/DigiCertGlobalG2.pem.inc
    and set CONFIG_HTTPS_HOSTNAME="run.app"
    Here's the output:
    *** Using Zephyr OS v3.7.99-1f8f3dc29142 ***
    HTTPS client sample started
    Bringing network interface up
    [00:00:00.536,163] <inf> nrf_modem_lib_trace: Trace thread ready
    [00:00:00.543,640] <inf> nrf_modem_lib_trace: Trace level override: 2
    Provisioning certificate
    Certificate match
    Connecting to the network
    +CEREG: 2,"8169","014ACE00",7
    +CSCON: 1
    +CSCON: 0
    +CSCON: 1
    +CGEV: ME PDN ACT 0
    %MDMEV: SEARCH STATUS 2
    +CEREG: 1,"8169","014ACE00",7,,,"00001010","11000001"
    Network connectivity established and IP address assigned
    Looking up run.app
    +CGEV: IPV6 0
    Resolved 216.239.32.53 (AF_INET)
    Connecting to run.app:443
    Sent 57 bytes
    Received 207 bytes
    >        HTTP/1.1 404 Not Found
    Finished, closing socket.
    +CGEV: ME PDN DEACT 0
    +CEREG: 0
    +CGEV: ME DETACH
    +CSCON: 0
    Network connectivity lost
    Disconnected from the network
    And pcapng: 341496_.pcapng
    Q1: What mfw are you using?
    Q2: Have you checked that the wr2.pem is updated on your end?
    Your comment indicate that you use the latest.
    Q3: Could you add a top-level root CA to another tag in addition? wr2 is a intermediate cert.
    Håkon
