Flash size of BLE Applications
We are currently developing an application where we use a nrf52811.
Currently i am working on integrating the BLE-Stack as this is the last part missing.
I am constantly running out of flash as well as RAM. Therefor we also scrapped a FOTA-Update via BLE as there was no way of implementing this with this few Flash.
Can someone please verify that BLE as a central wich scans for devices with a certain Complete-Name in its advertising data takes up almost XX% of Flash and XX% of RAM?
without BLE:
  FLASH: 190644B - 96.97%
  RAM: 23432B - 95.35%
with BLE:
  FLASH: 52724B - 26.82%
  RAM: 4968B - 20.21%
Also my program crashes when i start the scanning. I believe this is due to a lack of memory. I reduced several queues and stack in order to fit everything in the ram.
My curent configuration is as follows:
CONFIG_SIZE_OPTIMIZATIONS=y
CONFIG_POWEROFF=y
CONFIG_BT=y
CONFIG_BT_GATT_CLIENT=y
CONFIG_BT_CENTRAL=y
CONFIG_BT_SMP=y
CONFIG_BT_OBSERVER=y
CONFIG_BT_SCAN=y
CONFIG_BT_GATT_DM=y
CONFIG_BT_FAST_PAIR=n
CONFIG_HEAP_MEM_POOL_SIZE=512
CONFIG_BT_DEBUG_NONE=y
CONFIG_BT_ASSERT=n
CONFIG_BT_DATA_LEN_UPDATE=n
CONFIG_BT_PHY_UPDATE=n
CONFIG_BT_GATT_SERVICE_CHANGED=n
CONFIG_BT_DEVICE_NAME="SL_RC"
CONFIG_BT_CTLR_LE_ENC=n
CONFIG_BT_CTLR_ECDH=n
CONFIG_BT_CTLR_EXT_REJ_IND=n
CONFIG_BT_CTLR_CONN_RSSI=n
CONFIG_MINIMAL_LIBC=y
CONFIG_BT_CTLR_EXT_SCAN_FP=n
CONFIG_MAIN_STACK_SIZE=512
CONFIG_IDLE_STACK_SIZE=128
CONFIG_ISR_STACK_SIZE=256
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=512
Apart from that i am using 1 PWM-Peripheral, 1 SAADC-Channel, 2 RGB-LED and 4 Buttons.
I have a hard time believing that these rather few peripherals make me run out of Memory
EDIT:
To make my usecase clearer:
On button press i want to scan for all devices with a certain complete name in its Advertising Data.
I then want to connect to the device with the best RSSI-Value over a certain timeperiod (e.g. 5 seconds)
After connecting i want to set a certain GATT-Service to 0 or 1 depending on the Button pressed.
