Issues with PPK2
I'm facing issues with my brand new PPK2 tool
What I've done so far, my setup :
* Ubuntu, linux
* I installed latest nrf connect application from official
* Installed Power profiler on startup screen
* installed SEGGER package/driver
* Installed nrf** udev rules from official github/releases
With all that Power profiler does not recognize ppk2 at all, no device is seen, although ppk2 dv when connected is blinking green
I tried different usb cables/ports, nothing worked
  • My log is here:
    2025-02-27T19:48:00.518Z INFO Initialising the bundled nrfutil device
    2025-02-27T19:48:00.523Z DEBUG Started watching devices
    2025-02-27T19:48:00.641Z ERROR Error while updating the bundled core for nrfutil device.
    2025-02-27T19:48:00.649Z INFO Using the bundled core version for nrfutil device: 7.13.0
    2025-02-27T19:48:00.757Z INFO Using nrfutil-device version: 2.7.5
    2025-02-27T19:48:00.757Z INFO Using nrf-device-lib version: 0.17.41
    2025-02-27T19:48:00.758Z INFO Using nrfjprog DLL version: 10.24.2
    2025-02-27T19:48:00.758Z INFO Using JLink version: JLink_V8.16
    2025-02-27T19:48:00.759Z INFO Your version of SEGGER J-Link (8.16) is newer than the one this app was tested with (7.94i). The tested version is not required, and your J-Link version will most likely work fine. If you get issues related to J-Link with your devices, use the tested version.
    I managed to bring ppk2 in bootloader mode (blinking red), but it didn't appear anyways
    this is some kind of nonsense to me...
  • The solution was - both cables have no data lines, please use proper usb cable...
    shame on my head
  • It sounds like your Power Profiler Kit 2 (PPK2) is not being recognized by nRF Connect on Ubuntu. Since the LED is blinking green, it suggests the hardware is powered but not detected properly.
    slither io
