Unable to change CONFIG_HEAP_MEM_POOL_SIZE in prj.conf
To preface:
  • nRF Connect SDK 2.9.0
  • nRF9151 DK
  • Windows 11 PC
I have been developing in the nRF Connect SDK for a few weeks now so I am fairly new. I have encountered a strange issue I don't understand. Whenever I change CONFIG_HEAP_MEM_POOL_SIZE in my prj.conf file and build the project, it never updates to the new value. It remains at a default value of 4096 as seen when I search for the config in menuconfig. Whether I do a pristine or regular build makes no difference. The same issue occurs when I try to set CONFIG_MAIN_STACK_SIZE. Other Kconfig changes work as expected. I was able to reproduce this using a nRF Connect SDK example as detailed below. Note that you don't need the actual devkit to reproduce, you just need to build the project.
Example: HTTPS Client
Steps to reproduce:
1. Open a new instance of VS Code
2. Select the nRF Connect extension -> Create a new application -> Copy a sample -> nRF Connect SDK v2.9.0 -> Filter for board "nrf9151 Non Secure" and select the DK -> HTTPS client sample
3. Select a destination for the new project. I used c:\ncs_workspace\https_client
4. Open the project when prompted
5. Select the nRF Connect extension -> Add build configuration -> Select the following:
  • SDK v2.9.0  - Toolchain: v2.9.0
  • Board target: nRF9151dk/nrf9151/ns
  • Optimization level: Optimize for debugging
  • Leave everything else as default (System build should be left to the default of "Build system default")
6. Click the blue "Build Configuration" button and wait for the build to complete.
7. Open prj.conf in VS code and observe that the current value of CONFIG_HEAP_MEM_POOL_SIZE is set to 1024. However, when you hover your mouse over it or check its value in menuconfig it actually has a value of 4096. I assume it is overridden to a higher value by a library.
8. Change CONFIG_HEAP_MEM_POOL_SIZE to the following:
CONFIG_HEAP_MEM_POOL_SIZE=8192
9. Select the nRF Connect extension -> Actions -> Build (NOT pristine), and wait for the build to finish.
10. In prj.conf, mouse over CONFIG_HEAP_MEM_POOL_SIZE and observe that it is still assigned a value of 4096  (Or use menuconfig to confirm)
11. Select the nRF Connect extension -> Actions -> Pristine Build, and wait for the build to finish.
12. In prj.conf, mouse over CONFIG_HEAP_MEM_POOL_SIZE and observe that it is still assigned a value of 4096  (Or use menuconfig to confirm)
13. At this point, no matter what value you change CONFIG_HEAP_MEM_POOL_SIZE to, or whether you use 'pristine' build or not, CONFIG_HEAP_MEM_POOL_SIZE will always have a value of 4096.
Question: Why are my changes to CONFIG_HEAP_MEM_POOL_SIZE in prj.conf not being reflected in the final build output?
Derek
    Could you try to generate a new build, ie. not use pristine, and see if this helps?
    You can also check your build-folder/app-name/zephyr/.config file to verify if the configuration did indeed get set to your wanted value
    Håkon
  • Hey Håkon,
    Sorry for the delayed reply.
    What exactly do you mean by generate a new build that does not use "pristine"? My understanding is that there are 2 build methods:
    1. Non-pristine
    2. Pristine
    Do you mean create an entirely new build configuration?
    Edit:
    I tried creating a new build configuration ('build_1' in the screenshot below) , built the project, and the issue persists:
    What am I missing?
    Derek
  • Hi Derek,
    Could this be a problem with how the sample is setup?
    HEAP_MEM_POOL_SIZE is set explicitly in both the boards/nrf9151dk_nrf9151_ns.conf file as well as the prj.conf file.
    The loaded configuration from the boards folder will override what is stated in the prj.conf
    Håkon
  • Hey Håkon,
    No idea, I am new to Zephyr Slight smile.
    If this is true, then why does the Nordic Dev Academy state otherwise?
    Source: https://academy.nordicsemi.com/courses/nrf-connect-sdk-fundamentals/lessons/lesson-3-elements-of-an-nrf-connect-sdk-application/topic/configuration/
    From the link above:
    "Configuration options can be set both in the application configuration file and the board configuration file. In the example, CONFIG_GPIO symbol is set in both files. In this case, the value in the application configuration file always takes precedence."
    "You should never modify any board configuration files. Instead, rely on the application configuration file to set new configurations and subsequently overwrite any default board configurations if needed."
    What am I missing? I thought prj.conf took precedence over anything else in the project. If this is not the case, it is not clearly explained in the Dev Academy course unless I am missing something.
    The only possible explanation that I see is that the Dev Academy comments above are referring to the 'defconfig' board configuration files, and not the .conf files.
    Derek
  • Hi Derek,
    I see the confusion, as this section of the course does not distinguish between a "boards" directory configuration overload/append and the actual declaration of the board itself.
    This is a generic comment on that you should not change the ../ncs/zephyr/boards/nordic/ files directly, but rather add your configuration local to the application, and thus append to the chosen board configuration.
    Within the "application scope", we include the my_appliaction/boards/ folder.
    This is the same situation as above, the board, for instance "nrf52840dk/nrf52840", will have a default configuration, like shown here:
    https://github.com/nrfconnect/sdk-zephyr/blob/main/boards/nordic/nrf52840dk/nrf52840dk_nrf52840_defconfig
    Håkon
