Issue creating and using binding files for SPI
Hi all, will need to post short as I am getting a "cannot create ticket" error.
Hi all,
I'm quite new to nrf, zephyr and embedded of this complexity but have completed the fundamentals and intermediate courses.
My intention is to get SPI set up for a TI ADS1298 chip connected to my nrf52DK/52832 board. The only way I know to do this is via bindings and as shown in the lessons and if there is a better way for a custom device with this SPI device connected and an SPI SD card (backup for later BLE comms), please let me know..
I am trying to create a new binding file for the ADS1298 so I can get communication in a similar way to the intermediate course SPI module.
I am working on SDK v2.8.0 in VSCode.
I have created a new blank project and tried to create my own binding file, keeping it simple. Basic file structure within the project is as follows:
my_app
|___ build |___ src |___ prj.conf |___ CMakeLists.txt |___ dts |___ bindings |___ sensor
|___ ti,ads1298.yaml
I have not edited the CMakeLists.txt file.
  • FYI, I have some clarification and proof about the multibyte delay:
    9.5.2.9: ADS129x Datasheet
    However, if SCLK is 4 MHz, one byte is transferred in 2 µs. Because this transfer time exceeds the tSDECODE specification, the processor can send subsequent bytes without delay. In the second scenario, the serial port can be programmed to use multiple byte transfers instead of the single-byte transfers required to meet the timing of the first scenario.
    I have scoped the ADS1298 PDK running using the TI evaluation software.
    The attached image shows the PDK outputting a two byte command read and getting a response whilst using a 4MHz clock. The need to run with a 4* t_CLK space is not required. I would assume that the ADS129x spi rx register can still receive spi data but cannot act upon the next byte received within 4* t_CLK, this clarifies this section.
  • Thank you for your answer, I have dug through the zephyr and cmake documentation and through long hours have somehow managed to get a grip on the errors I have caused and why.
    Yes, I cannot change a required to not required, and errant spaces are an issue!
    I am in the process of getting my SPI driver running now, and will highlight your reply as an answer if I have things functioning.
  • Hi Hieu,
    I have managed to get the SPI driver to at least stop producing an error on build and I think I now understand the bindings.
    I am currently not producing any SPI SCLK or MOSI on my logic analyser right now but that is another issue.
    The main issue behind this ticket is solved, thank you.
