How can the matter project be configured to support this feature of Multi-fabric/multi-admin
After I added the device on the Samsung platform, I shared the QR code, and then added it with Apple, but the device could not be found.The log prompt is as follows:
I: 5168517 [ZCL]Received command to close commissioning window
E: 5168523 [ZCL]Commissioning window is currently not open
I: 5168529 [EM]<<< [E:3095r S:3467 M:246486538 (Ack:31565426)] (S) Msg TX to 2:8F0FCE11460ADF1A [DA3A] [UDP:[fd88:64c:e4cb:1:fe0c:61b0:d430:eafb]:32958] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 5168585 [EM]>>> [E:3095r S:3467 M:31565427 (Ack:246486538)] (S) Msg RX from 2:8F0FCE11460ADF1A [DA3A] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 5169100 [EM]>>> [E:3096r S:3467 M:31565428] (S) Msg RX from 2:8F0FCE11460ADF1A [DA3A] --- Type 0001:02 (IM:ReadRequest)
D: 5169111 [IM]Received Read request
I: 5169115 [EM]<<< [E:3096r S:3467 M:246486539 (Ack:31565428)] (S) Msg TX to 2:8F0FCE11460ADF1A [DA3A] [UDP:[fd88:64c:e4cb:1:fe0c:61b0:d430:eafb]:32958] --- Type 0001:05 (IM:ReportData)
I: 5169178 [EM]>>> [E:3096r S:3467 M:31565429 (Ack:246486539)] (S) Msg RX from 2:8F0FCE11460ADF1A [DA3A] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 5169606 [EM]>>> [E:3097r S:3467 M:31565430] (S) Msg RX from 2:8F0FCE11460ADF1A [DA3A] --- Type 0001:0a (IM:TimedRequest)
I: 5169618 [EM]<<< [E:3097r S:3467 M:246486540 (Ack:31565430)] (S) Msg TX to 2:8F0FCE11460ADF1A [DA3A] [UDP:[fd88:64c:e4cb:1:fe0c:61b0:d430:eafb]:32958] --- Type 0001:01 (IM:StatusResponse)
I: 5169696 [EM]>>> [E:3097r S:3467 M:31565431 (Ack:246486540)] (S) Msg RX from 2:8F0FCE11460ADF1A [DA3A] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 5169709 [ZCL]Received command to open commissioning window
D: 5169715 [IN]SecureSession[0x200044b0]: Allocated Type:1 LSID:3472
I: 5169721 [DIS]Updating services using commissioning mode 2
D: 5169727 [DL]Using Thread extended MAC for hostname.
I: 5169732 [DIS]Advertise operational node 83D3E351D740C0E0-000000002087F2CF
D: 5169739 [DL]Using Thread extended MAC for hostname.
I: 5169744 [DIS]Advertise operational node FC685F0AC4FFDA3A-1D5E111EA24E23E0
D: 5169751 [DL]Using Thread extended MAC for hostname.
I: 5169755 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=1195/04 cm=2 cp=0
I: 5169765 [DL]advertising srp service: 62FAD845FD4B1641._matterc._udp
I: 5169772 [ZCL]Commissioning window is now open
I: 5169777 [EM]<<< [E:3097r S:3467 M:246486541 (Ack:31565431)] (S) Msg TX to 2:8F0FCE11460ADF1A [DA3A] [UDP:[fd88:64c:e4cb:1:fe0c:61b0:d430:eafb]:32958] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 5169859 [EM]>>> [E:3097r S:3467 M:31565432 (Ack:246486541)] (S) Msg RX from 2:8F0FCE11460ADF1A [DA3A] --- Type 0000:10 (SecureChannel:StandaloneAck)
D: 5170943 [DL]SRP update succeeded
I: 5183838 [EM]<<< [E:52421i S:3467 M:246486542] (S) Msg TX to 2:8F0FCE11460ADF1A [DA3A] [UDP:[fd88:64c:e4cb:1:fe0c:61b0:d430:eafb]:32958] --- Type 0001:05 (IM:ReportData)
I: 5183886 [EM]>>> [E:52421i S:3467 M:31565433 (Ack:246486542)] (S) Msg RX from 2:8F0FCE11460ADF1A [DA3A] --- Type 0001:01 (IM:StatusResponse)
I: 5183898 [IM]Received status response, status is 0x00
I: 5183904 [EM]<<< [E:52421i S:3467 M:246486543 (Ack:31565433)] (S) Msg TX to 2:8F0FCE11460ADF1A [DA3A] [UDP:[fd88:64c:e4cb:1:fe0c:61b0:d430:eafb]:32958] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 5213856 [EM]<<< [E:52422i S:3467 M:246486544] (S) Msg TX to 2:8F0FCE11460ADF1A [DA3A] [UDP:[fd88:64c:e4cb:1:fe0c:61b0:d430:eafb]:32958] --- Type 0001:05 (IM:ReportData)
I: 5213905 [EM]>>> [E:52422i S:3467 M:31565434 (Ack:246486544)] (S) Msg RX from 2:8F0FCE11460ADF1A [DA3A] --- Type 0001:01 (IM:StatusResponse)
I: 5213917 [IM]Received status response, status is 0x00
I: 5213923 [EM]<<< [E:52422i S:3467 M:246486545 (Ack:31565434)] (S) Msg TX to 2:8F0FCE11460ADF1A [DA3A] [UDP:[fd88:64c:e4cb:1:fe0c:61b0:d430:eafb]:32958] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 5243875 [EM]<<< [E:52423i S:3467 M:246486546] (S) Msg TX to 2:8F0FCE11460ADF1A [DA3A] [UDP:[fd88:64c:e4cb:1:fe0c:61b0:d430:eafb]:32958] --- Type 0001:05 (IM:ReportData)
I: 5243929 [EM]>>> [E:52423i S:3467 M:31565435 (Ack:246486546)] (S) Msg RX from 2:8F0FCE11460ADF1A [DA3A] --- Type 0001:01 (IM:StatusResponse)
I: 5243942 [IM]Received status response, status is 0x00
I: 5243947 [EM]<<< [E:52423i S:3467 M:246486547 (Ack:31565435)] (S) Msg TX to 2:8F0FCE11460ADF1A [DA3A] [UDP:[fd88:64c:e4cb:1:fe0c:61b0:d430:eafb]:32958] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 5273892 [EM]<<< [E:52424i S:3467 M:246486548] (S) Msg TX to 2:8F0FCE11460ADF1A [DA3A] [UDP:[fd88:64c:e4cb:1:fe0c:61b0:d430:eafb]:32958] --- Type 0001:05 (IM:ReportData)
I: 5273946 [EM]>>> [E:52424i S:3467 M:31565436 (Ack:246486548)] (S) Msg RX from 2:8F0FCE11460ADF1A [DA3A] --- Type 0001:01 (IM:StatusResponse)
I: 5273958 [IM]Received status response, status is 0x00
I: 5273964 [EM]<<< [E:52424i S:3467 M:246486549 (Ack:31565436)] (S) Msg TX to 2:8F0FCE11460ADF1A [DA3A] [UDP:[fd88:64c:e4cb:1:fe0c:61b0:d430:eafb]:32958] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 5303911 [EM]<<< [E:52425i S:3467 M:246486550] (S) Msg TX to 2:8F0FCE11460ADF1A [DA3A] [UDP:[fd88:64c:e4cb:1:fe0c:61b0:d430:eafb]:32958] --- Type 0001:05 (IM:ReportData)
I: 5303958 [EM]>>> [E:52425i S:3467 M:31565437 (Ack:246486550)] (S) Msg RX from 2:8F0FCE11460ADF1A [DA3A] --- Type 0001:01 (IM:StatusResponse)
I: 5303971 [IM]Received status response, status is 0x00
I: 5303976 [EM]<<< [E:52425i S:3467 M:246486551 (Ack:31565437)] (S) Msg TX to 2:8F0FCE11460ADF1A [DA3A] [UDP:[fd88:64c:e4cb:1:fe0c:61b0:d430:eafb]:32958] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 5333928 [EM]<<< [E:52426i S:3467 M:246486552] (S) Msg TX to 2:8F0FCE11460ADF1A [DA3A] [UDP:[fd88:64c:e4cb:1:fe0c:61b0:d430:eafb]:32958] --- Type 0001:05 (IM:ReportData)
I: 5333979 [EM]>>> [E:52426i S:3467 M:31565438 (Ack:246486552)] (S) Msg RX from 2:8F0FCE11460ADF1A [DA3A] --- Type 0001:01 (IM:StatusResponse)
I: 5333991 [IM]Received status response, status is 0x00
I: 5333997 [EM]<<< [E:52426i S:3467 M:246486553 (Ack:31565438)] (S) Msg TX to 2:8F0FCE11460ADF1A [DA3A] [UDP:[fd88:64c:e4cb:1:fe0c:61b0:d430:eafb]:32958] --- Type 0000:10 (SecureChannel:StandaloneAck)
