How can the matter project be configured to support this feature of Multi-fabric/multi-admin
After I added the device on the Samsung platform, I shared the QR code, and then added it with Apple, but the device could not be found.The log prompt is as follows:
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
I: 5168517 [ZCL]Received command to close commissioning window
E: 5168523 [ZCL]Commissioning window is currently not open
I: 5168529 [EM]<<< [E:3095r S:3467 M:246486538 (Ack:31565426)] (S) Msg TX to 2:8F0FCE11460ADF1A [DA3A] [UDP:[fd88:64c:e4cb:1:fe0c:61b0:d430:eafb]:32958] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 5168585 [EM]>>> [E:3095r S:3467 M:31565427 (Ack:246486538)] (S) Msg RX from 2:8F0FCE11460ADF1A [DA3A] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 5169100 [EM]>>> [E:3096r S:3467 M:31565428] (S) Msg RX from 2:8F0FCE11460ADF1A [DA3A] --- Type 0001:02 (IM:ReadRequest)
D: 5169111 [IM]Received Read request
I: 5169115 [EM]<<< [E:3096r S:3467 M:246486539 (Ack:31565428)] (S) Msg TX to 2:8F0FCE11460ADF1A [DA3A] [UDP:[fd88:64c:e4cb:1:fe0c:61b0:d430:eafb]:32958] --- Type 0001:05 (IM:ReportData)
I: 5169178 [EM]>>> [E:3096r S:3467 M:31565429 (Ack:246486539)] (S) Msg RX from 2:8F0FCE11460ADF1A [DA3A] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 5169606 [EM]>>> [E:3097r S:3467 M:31565430] (S) Msg RX from 2:8F0FCE11460ADF1A [DA3A] --- Type 0001:0a (IM:TimedRequest)
I: 5169618 [EM]<<< [E:3097r S:3467 M:246486540 (Ack:31565430)] (S) Msg TX to 2:8F0FCE11460ADF1A [DA3A] [UDP:[fd88:64c:e4cb:1:fe0c:61b0:d430:eafb]:32958] --- Type 0001:01 (IM:StatusResponse)
I: 5169696 [EM]>>> [E:3097r S:3467 M:31565431 (Ack:246486540)] (S) Msg RX from 2:8F0FCE11460ADF1A [DA3A] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 5169709 [ZCL]Received command to open commissioning window
D: 5169715 [IN]SecureSession[0x200044b0]: Allocated Type:1 LSID:3472
I: 5169721 [DIS]Updating services using commissioning mode 2
D: 5169727 [DL]Using Thread extended MAC for hostname.
I: 5169732 [DIS]Advertise operational node 83D3E351D740C0E0-000000002087F2CF
D: 5169739 [DL]Using Thread extended MAC for hostname.
I: 5169744 [DIS]Advertise operational node FC685F0AC4FFDA3A-1D5E111EA24E23E0
D: 5169751 [DL]Using Thread extended MAC for hostname.
I: 5169755 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=1195/04 cm=2 cp=0
I: 5169765 [DL]advertising srp service: 62FAD845FD4B1641._matterc._udp
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
  • The version of the phone is 18.0.1.
    The firmware version of the HomePod is 18.3.
    The iOS app version of Samsung SmartThings is 1.7.26.112.
  • I have tried the products made by other manufacturers and they are OK. Do you need to set any parameters?
    As far as I know, it should not be necessary to set any parameters.
    I have forwarded this information to the developers and am waiting for their response.
    Marte
    Can you clarify what you mean by other manufacturers? Are these also Thread/Matter over Thread devices with test VID?
    Marte
    The developers have not been able to reproduce the issue. They tested with the following setup:
    HomePod 18.3
    iOS 18.3.1 with Home app
    SmartThings app version 1.8.28.21 on Pixel with Android 13
    Marte
1 2
